SpyderLovers Founder
Very cool
need to look at Lemonser vedio saves alot of time on removing the tupper ware. on the oil change
SO DOES THE MECHANIC THAT DID MY LAST OIL CHANGE....FOUND THAT HE HAD NOT PUT THE LONG LOWER SIDE PANEL ON CORRECTLY AND THE WHITE HAD RUBBED ONTO THE BLACK PART......AND FOUND GROMMETS MISSING......
Wow, you are far braver than me. I'm still paying the dealership for oil changes. Congratulations on a good job.
Good job!!!! It's done better and less expensive!!!
GOS member (Girls On Spyders)
Congrats on a job well done. I would never even try to attempt changing my oil but applaud you for trying it and getting it done.
