Results 1 to 11 of 11
Thread: Rear tire shock
    Hanover, PA
    Default Rear tire shock
    Hi all,
    I have a 2011 RT. I have a question about the rear shock. I used to hear something like an air pump going to soften or firm the shock. I haven't heard that last year. My question is how can I tell if I even have an air pump for the shock. I can add air to it an it jumps right up. Any information would be appreciated. Thanks.
    Default AIRSHOCK
    Be very very careful when filling the airbag ( it doesn't go into the shock ), it wouldn't take much to blow it up....BRP actually recommends doing it with a Hand Pump.......Mike
    Hanover, PA
    Got it, thanks for the reminder.
    Jun 2010
    Las Vegas
    With the Spyder running and in gear try changing the setting and listen for the compressor. If you don't hear it it may have died. That is not uncommon.
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    Hanover, PA
    Quote Originally Posted by SpyderAnn01 View Post
    Thanks I will try that when the weather gets a bit warmer. Looks like next week.
    Very Active Member KX5062's Avatar
    Aug 2012
    Central Coast, CA
    If you have an airbag and no on-board compressor, (which some model do come that way) lift the seat and look for a schrader valve. This is where you fill the air bag. It can be tricky, as 911 said, use a hand pump and it's easier if it has an integrated gauge. There should be a sticker underneath the seat that gives you the inflation recommendations.
    2020 RTL SE6
    Feb 2012
    Spring City,Utah
    If you used to hear an air pump(compressor) changing your ride height/firmness and now you don't then probably your compressor is burned up.This is a common occurrence I just had mine replaced and it was just under $500.00 parts and labor. If you want /can do it yourself there is an aftermarket compressor that bolts right in ,is stronger and costs less money, I don't know about the other models but I thought the RT Limited was the only one with an auto adjuster. Do you have a limited? BTW I really like your paint.
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
    May 2013
    Stanton, ca
    If the compressor is not working there is an easy way to tell.
    Start it up and use the switch. On the dash display on the left side you will see a ride adjustment scale. You should see that move up or down with the switch. If it says "manual" instead of seeing the scale, the compressor is not working or the swing arm position sensor may have become disconnected or is not functioning.
    Bob
    Hanover, PA
    I took the bike to the shop this morning. Needs an oil change, state inspection and they are checking the air suspension. I tried the switch to go from hard to soft but nothing happened. I did the the gauge on the side of the display and it moved but no air compressor sound. We will see what the deal says.
    Thanks all.
    Hanover, PA
    Default Dealer called
    The dealer called this morning and said the compressor was shot and if I ever had it changed. I said no, why and he said it was cleaner then the rest of the bike like it was new. He is changing it, covered under warranty. I will see when I get it back.
    Dec 2013
    Hopefully the Dealer would've known & tested it properly, but then you never know about some of 'em....
    Still, for anyone else who is concerned, if you've been testing to see if that compressor/ride leveller works, have you been trying while sitting on the Spyder with the engine running & the trans actually in gear?? Not positive about the in gear bit (others will be & can confirm or deny, I'm sure) but that compressor/ride levelling won't do schmik for you unless you've got the engine running & some weight on the seat.
