Results 1 to 17 of 17
    May 2009
    Appleton, WI
    Default Prob after oil change
    Did my oil change with the help of Lamont's post. This is the 3rd oil change that i have done myself but the first one with issues. First off, 08 GS. Mobil 1 racing 4t 10w40 oil. Drained both the reservoir and crank case, changed filter. Everything is tight. No leaks. Oil light will NOT go off and according to BajaRon the noise i hear is the lifters and the noise should go away when the oil light goes off but as i said it doesnt. Let it run till it was warm and oil light stays on and lifter noise is still there.
    Thinking i need to start the whole process over again.
    Any thoughts?
    Thanks in advance.
    Very Active Member GOZFST's Avatar
    Oct 2014
    SD &AZ
    Hate to ask, but are you sure you put the oil filter in the correct way?
    Bob S
    May 2009
    Appleton, WI
    Quote Originally Posted by GOZFST View Post
    Yes. I seated the filter in the cap and installed.
    Quote Originally Posted by jvicker View Post
    Which end did you put the rubber gasket into? The cap or the engine port?
    May 2009
    Appleton, WI
    Don't remember. Which way should it be? Pretty sure it was rubber gasket to engine. But i did drop it in the oil pan and may have put it in wrong.
    Thats why i think i need to start over.
    Oct 2014
    SD &AZ
    Open end goes towards engine.
    Bob S
    May 2009
    Appleton, WI
    Just pulled the filter and it was backwards. i did have it right before it fell off the cap. I must have put it on backwards after i cleaned it up.
    Runs like a champ.
    Thanks everyone
    Jun 2014
    Schenevus NY
    Runs like a champ.
    Thanks everyone
    Glad you got it resolved quickly enough to avoid any damage.
    Trb-- (Roger)
    2022 White Pearl F3T
    Spyder States Visited
    Feb 2015
    NB Canada
    You use 4t oil. I heard that wasn't good for the spyder. I could be wrong. Just heard it wasn't good for the clutch.
    Sent from my SGP521 using Tapatalk
    2011 RT Limited , White
    Oct 2011
    Kalamazoo, Mi
    Default oil change
    Runs like a champ.
    Thanks everyone
    Been there, done that, have the shirt. Was on my first oil change however, none since then
    2018 F3-T
    2018 F3-T , Pearl White
    Oct 2009
    ponte vedra beach fl
    Quote Originally Posted by IGETAROUND View Post
    I use the same oil in my 09 rs 71k change the oil at 10k no problems
    used the same in my 08 76 k wheni sold it no problems
    checked and added small amounts of oil every 2 k
    Runs like a champ.
    Thanks everyone
    All is well that ends well! Glad you caught this one quick!
    Mar 2015
    Stony Mtn, Manitoba
    Default I did the same!
    But......no offense intended here....... people should not be telling others on this site the "oil light will go out after a bit"!! It goes out so quickly it is unnoticed if the oil filter is in correctly. Fortunately I was skeptical when I was told this and just took it back apart. Engine damage occurs very quickly when little to no oil pressure is present!
    Mar 2015
    Stony Mtn, Manitoba
    Quote Originally Posted by Trbayth View Post
    This depends on how long it ran, I was told to rev the engine to build oil pressure, which was terrible advice that I ignored!!
    Oct 2011
    Kalamazoo, Mi
    Default Problem after oil change
    Quote Originally Posted by hecoon View Post
    ​Well now Hecoon, that's nice to know. I have a friend who changes the filters @ the recommended intervals and the oil every other filter. He also has had no problems and has been riding for 40+ years.
    Not recommending this to others and wouldn't think of doing this while under warranty; however it does get one to thinking.
    2018 F3-T
    I would say this is extremely bad advice. New filters don't regenerate the oil. The way our Spyders shred (shear) oil you're going to be running on very tired oil that will not lubricate properly. This means metal to metal contact which will put a lot more metallic particles into the oil. Of course you'll have nice new filters to catch them all!
    Default Not worth it...
    For the price and work involved it is not worth risking engine failure not replacing the filter/s with each oil change. as the filter looses it's ability to allow oil flow from dirt build up the more likely your oil pressure will suffer....collapse the filter and you will have problems....
