Page 1 of 2 12 LastLast
Results 1 to 25 of 26
    Nov 2014
    Rural Hall NC
    Default Premium Gas shortage Down South, so using 87 - OK?!
    I am not sure if any of the other southern Spyder riders are having the same problem I am, but with the pipeline leak from a couple of weeks ago that caused most of the gas stations around me to run out of gas, I am having trouble finding any premium gas to put in Cocaine. The stations around me now have regular 87 octane, but that is it. No premium 93 or mid-grade 89. I had to fill up using the 87, and I know that some people put this in their bike all the time, but it is the first time I have had too. Hopefully get a chance to ride today and see how Cocaine does on the 87 octane.
    Bossier LoUiSiAna
    Swing by autozone or Pepboys & grab some octane boost Should be ez enough to find
    2013 STL SE5 BLACK CURRANT
    SpyderPop's: LED bumpskid
    minispyder dash toy
    Lid lox
    KradelLock
    Pakitrack
    FLO (Frunk Lid Organizer)
    BRP fog lights, trailer hitch
    SENA 20S EVO
    Feb 2013
    Edinburg, TX
    I'm no automotive expert, nor have I even played one on TV. But from reading this forum I've learned 2 things:
    1. Higher octane does nothing more than prevent pre-ignition. The rest of the gasoline is the same, regardless of octane.
    2. Our Spyders' computer system senses pre-ignition and modifies spark timing to prevent it from happening. So, no engine damage, just possibly lower performance, a worthwhile sacrifice.
    I'm sure someone will correct me if I'm mistaken. In fact, I hope so!
    NEW - 2015 RT Limited SE6 Intense Red Pearl - 07/21/15
    Retained the old mirrors with TricLed Signals
    General Altimax RT43 rear tire (at...17,000 miles) Ran for 36,500 miles
    Michelin Defender.......rear tire (at...53,500 miles) Ran for 60,700 miles
    Riken Raptor HR.........rear tire (at 114,200 miles)
    Vredestein Quatrac 5 front tires (at 70,500 miles, first new fronts!)
    Gear Brake Decelerometer Module
    OLD - 2012 RT Limited SE5 Pearl White - 01/31/13 - Traded in at 32,600 miles.
    BajaRon Anti-sway Bar
    Kumho ECSTA AST rear tire (at 14,200 miles)
    TricLed Turn Signals in Mirrors
    2015 Limited , Intense Red Pearl
    May 2011
    Pinehurst,NC
    I just came back from Clearwater Florida on I-95 and I-75, and #19, plenty of gas everywhere. I left from Pinehurst, North Carolina.
    Don't worry about having to put 87 octane in your Spyder: it can adapt for it.
    It might run a bit better on the higher octane stuff, but if it can get it to burn; you're good to go!
    Aug 2013
    Northern California
    Default OK
    Our service manager at one of the best Spyder Dealers in the Country says that it is a waste of money to use the Higher Octane grades......I seem to remember Cocaine being higher Octane than 93!!!
    Jun 2015
    Ritzville, Wa
    Default I know what it's called
    Putting high octane gasoline in Cocaine is, in the parlance of the street, called a Sypder Bite.
    Greg Kamer
    USAF, 20 years, retired
    2018 Can Am Spyder RT-Limited
    Sep 2014
    USA
    I have ran 87 -89 with no problems
    Default HIGHER OCTANE
    Quote Originally Posted by missouriboy View Post
    ......And ....No you aren't mis-taken ..... the computer WILL make the adjustment IF NEEDED. I have 26,000 + miles on my 1330 using 87 octane and am quite satisfied with it even using ECO mode 75 % of the time.........Mike
    Oct 2008
    Kingsport, TN
    I stopped at my normal gas station to fill up the Spyder this past Friday. I normally run 90 octane non-ethanol gas, the station was out of it, due to the impact of the pipeline break in our state, TN. So I had to put the ethanol blend in the tank. I heard the pipeline has been repaired, I am hoping that gas supplies get back to normal soon!!! BTW, my Spyder runs great on the 90 octane!!!
    Jun 2014
    ny
    I thought it was kerosene that was in cocaine
    Very Active Member Tango's Avatar
    Apr 2012
    Florida
    It will run just fine on Reg.. Tom
    Baloo is my name. Spyders are my game. Well, it's a doo-bah-dee-doo, yes, it's a doo-bah-dee-doo, I mean a doo-bee, doo-bee, doo-bee, doo-bee, doo-bee-dee-doo. And, well, now. Ha ha! What have we here?
    2020 Petrol Blue Metallic RTL
    What they said above. Oh, and we are doing our part in Alaska to help solve the problem of the gas "shortages" down in the SE. The news said that gas would probably spike another 20 cents a gallon or so because of the situation. Ours promptly went up 20 cents a gallon the next day. $2.57 for most regular (87) now. Add 20 cents for premium (91). Our gas comes from here, is refined here, and used here.
    Default PRICE HIKE
    Interesting , I thought for sure it would rise in Vermont but it actually dropped a few cents.........Mike
    Sep 2013
    Fairburn , Ga.
    Default Gas Shortage
    Hello All, I usually run 93 octane in my Spyder, I believe that the higher octane keeps the engine cleaner, and performs better, just me, ain't nothing but a thing.
    Midnightbreeze
    Jan 2012
    Menlo, GA. 'Lookout Mountain'
    Like Bfromla says, get some octane booster. Carry it with you all the time in case there isn't any higher octane gas available when you travel.
    Mar 2015
    Advance, NC
    No problem with fuel in Western NC or Western Virginia. Goldwing folks had a stste meet in Cherokee last week and no problem.
    Nov 2014
    Rural Hall NC
    Thanks to everyone for the responses. This morning all the gas stations around me still had nothing but 87 octane but by this afternoon, all the bags were off the pumps and I am good to fill up with 93. This might be the first time that I can almost guarantee the gas will be fresh. As far as what you mix cocaine with to get a Spyder Bite, I would not have a clue what you are talking about. That's my story and I am sticking with it.
    Nov 2014
    Rural Hall NC
    Sounds about right. SMDH
    Feb 2013
    UK
    Cool The UK version....
    Our fuel octane measurement is a bit different to that which is used in the US but I've used both available grades in both of my Spyders
    and TBH I can't tell any difference in the performance. There may be a small difference in fuel economy, the higher octane giving a marginally
    better number, but the difference is almost negligible.
    What I do use religiously and at each fuel fill is Millers fuel additive and I can feel the difference using that. Not only does it boost the octane
    but it also keeps the fuel path, throttle bodies and injectors clean.
    Quote Originally Posted by Bam Bam and Pebbles View Post
    The gas companies do like to stick it to us. And they are right on with any price changes. It all happens within a couple hours--everywhere--on the price rises. Going down--they tend to take their time.
    Nov 2014
    Rural Hall NC
    I love their logic when it comes to raising and lowering the price of gas. When the cost goes down, they say they can't lower the price immediately because it is the higher price stuff in the pipelines and trucks. When the cost goes up, or there is an opportunity to screw us consumers, they jack it up even though logically, it is the lower priced gas in the works. They can do this because they know we need it and they are gonna give us the shaft every chance they get. Then they make commercials telling us how much they care about us. I guess at least they might consider that as the kiss for us before they us.
    You have hit the nail on the head.
    Very Active Member Rogue Hawk's Avatar
    Apr 2015
    Chicago
    "Gas Down South"
    I get that the morning after I go to Taco Bell.
    2019 Rally , Black
    Eastern North Carolina
    This was Tuesday at a Marathon station just down the road from me. Speedway across the street, same. One station had all three available, but I won't by gas there. It's one of those privately owned corner convenience stores They buy what is called 'low book' gas. In other words, it's what ever the distributor has left after primary sales. Also, their tanks are not cleaned regularly so it's no telling what lurks in the gas. I will buy it for my mower, but that's all.
