Results 1 to 12 of 12
    Very Active Member Sopher's Avatar
    Feb 2008
    Just outside of Boston
    Default 2010 RTS wont start; full power on console
    Week before last, I rode it all week. Garaged it. with trickle charge on. Went to start it an just relay clicks. The lcd console and all electrical show normal. no codes. I checked the fuses, front and under seat. nothing obvious. Battery level shows 12.83 when not on trickle charge. Battery is about 6 months old, been riding a ton before this break.
    I'm out of ideas.
    I'm about to call AAA to have it towed to my dealer. ugh.
    RT-S # 352; Timeless Black... faster than any other color. Mods: EasternBeaver PC8 Fuse Box, 12v digital dashboard display, RearTrunk internal Lights.
    Pioneer XMP3 hardwired, KewlMetal highway foot rests, PolkAudio Speaker upgrades (dxi525 & dxi400), Custom Garmin Nuvi bracket and wiring, Panel Savers, Custom LED array third brake light and rear signal LED's. Custom mud flap lights. Daytime Running Lights (3wattsx6). Heated Corbin seat with 'Lamonster' cut. JBL 400watt Amp,
    Other secret mods.
    Active Member lil rabbit's Avatar
    Silverdale, Wa
    When you last rode your Spyder, is it still in gear. Just asking and if so apply the brake and try to start again.
    Feb 2008
    Quote Originally Posted by lil rabbit View Post
    Dang-nabit ! THAT WAS IT! It now starts. Whoo hoo! THANK YOU SO MUCH!
    I used to be glued to this board from 2008-2012ish. I really should be hanging around here more.
    Other secret mods.
    western Colorado
    also kill switch bumped?
    Oct 2013
    rome new york
    Simple things in life will get you every time
    Feb 2008
    More troubleshooting done... the bike will NOT start unless in neutral. It has never done this in its 5 year life.
    any ideas?
    Other secret mods.
    It should start in gear; as long as you've got your foot on the brake...
    Feb 2008
    That's the thing... it wont. It used to start in 1st gear with the clutch pulled in.
    I called my dealer and they said to check the micro switch that gets closed by the clutch lever. I tried that its not it.
    Other secret mods.
    Something is going on...
    There are the safety switches; I would guess that it's in them.
    Default Switch....
    It has to be in the clutch switch. Manuals will start in any gear if the clutch is pulled in. The only source for the comuter to know this the clutch switch. The switch the connections or the control unit. By age I would think its in the switch or connections...
    Feb 2008
    I played around with the microswitch. It is the source of the problem. A replacement part;
    219800083 is like $50.
    Any other source or suitable replacement?
    Other secret mods.
    Sure..try cheapcycleparts.com I order from them cheaper and faster. ..
