Page 2 of 2 FirstFirst 12
Results 26 to 50 of 50
  1. #26
    Invalid Emails
    Jun 2015
    Plymouth, Vt.
    I'd like to see:
    Better, bigger screen (so I can actually read it while driving).
    Better headlights (LED's all the way would be nice).
    Eliminate the "delay" when starting up.
    Better access to the interior mechanics.
    A Clymer manual (it's difficult to take off the Tupperware...at least for the first time).
    A bit more storage room in back.
    And last but not least.....a better horn (It's so wimpy, that I'm ashamed to use it).
  2. #27
    John:
    Remember last time you made a wish like that and failed to be precise??? Carrot Head is available.
    Cruzr Joe
  3. #28
    Sep 2014
    3rd ROCK FROM THE SUN !
    definitely a driveshaft to replace the belt... better seat & better sound system... and - REAL TIRES...
    osm
  4. #29
    Apr 2015
    Mico TX
    1. longer mud flap for rear wheel so it doesn't sling slop in rainy weather
    2. full floor boards (such as the Seal boards)
    3. MUCH better anti-sway bar and front shocks/springs (better handling)
    4. MUCH better visibility via lights from all four sides
    5. digital voltmeter and oil pressure gauge
    6. relocate rear wheel Schrader valve
    7. better seals on all bags, frunk and trunk and MUCH better latches
    8. precise alignment from the factory
  5. #30
    May 2013
    Apex, N.C.
    Quote Originally Posted by sduskin View Post
    I have a full size 2x modular with a G9x bluetooth on the side. The helmet fits in the frunk and in the larger of the 2 saddlebags just fine. I can get a half helm in the other saddlebag.
    This was news to me. I thought they were the same size. I just went down stairs and tried getting my Fulmer modular helmet in. It fit on the right side, but not the left. Guess I learn something new every day. Thanks!
  6. #31
    Nov 2012
    North Las Vegas, NV
    1. Turn signal indicators that you can see.
    2. U-fit style system on all spyders.
    2016 F3 Limited
    2019 Ryker Rally
    2014 Suzuki V Strom 650
    2020 CSC TT 250
  7. #32
    Jan 2015
    Marana AZ
    Tupperware removal without mirror removal!
  8. #33
    Jun 2013
    queens ny
    boy oh boy, ask for 1 simple red head and people talk more about that then what the tread was about. OK I WILL ALSO TAKE ANY LADY WITH A PULSE
  9. #34
    The right side storage compartment is a bit deeper than the one on the left...
    This might be a throwback to when the battery was located at the left rear side of the bike.
  10. #35
    Very Active Member OverHillAndDale's Avatar
    Sep 2014
    United States
    I agree with a quicker warm-up time before the bike can start.
    Concerning the drive shaft - I've had bikes with a belt and bikes with a shaft and really couldn't tell a difference. The differential does soak up some energy and is in general less efficient, but it would require less maintenance.
    2020- RT Limited
    Chalk White, Can-Am rear passenger armrests, Comfort Seat, Grip puppies, RAM Cup Holders, Providence RAM Mount
    FOBO2 TPMS
    Aluma MCTXL trailer
    BRP hitch
    Big Bike Parts wiring harness
    Permanent Smile!!!
  11. #36
    Nov 2014
    Hammond LA
    What about alignment? It would be nice to have Spyder setup correctly.
  12. #37
    Nov 2014
    Hammond LA
    Quote Originally Posted by wiredgeorge View Post
    These are all nice ideas and practical. Good Job.
  13. #38
    Active Member SpyderCruiser's Avatar
    Nov 2014
    NJ
    Thumbs up
    Quote Originally Posted by Orange Spyder Man View Post
    osm
    I agree with all the posters comments. But high on the list would be the shaft drive like my 2 Vulcans had. I would give anything to get rid of that vibration between 70 - 80 mph.
    2015 RTL , Red
  14. #39
    Feb 2015
    McLain, MS..
    Default just a couple of things.,
    Better fuel economy would be nice on trips...and I sure wish there was an existing accessory wire behind that plug on the center of the handlebar, man that would be nice..Come to think of it the standard RT Would be much better with the adjustable handlebar as a stock item...maybe a longer lasting stock rear tire.....Overall I love this thing so it's shortcomings are not a real issue anyhow....
  15. #40
    Mar 2012
    Florida Space Coast
    I would NOT want a drive shaft on the Spyder. I much prefer the belt.
    I wish all Spyders came with a hand brake.
  16. #41
    Very Active Member Fat Baxter's Avatar
    Sep 2014
    Central Alabama
    I'd like to have 2 extra power outlets, one at the back seat (actually, there's already a plug for one under the left passenger handgrip) and one up around the dash. I'd use the rear one for heated clothing and the front one for any accessories (like a GPS or a heated vest). Either one would also be handy for plugging in a battery tender -- wouldn't have to open any lids. Extra power outlets are nickle and dime stuff.
    More positive turn signal switch. The existing one is pretty mushy.
    Better quality speakers. I have a slight hearing deficit, and I have to crank the current ones WAY up to hear anything (especially at speed), and at that setting, the sound breaks up.
    I think, for the RT-S and RT Limited, Tricled's front fender and saddlebag LEDs would be a nice touch.
    The stock seat doesn't bother me. I rode BMWs for 32 years, and their stock seats are hardwood planks compared to the Spyder's. For longer trips, I add a sheepskin pad, and sometimes I also add a swatch of bubblewrap under the sheepskin. (I'm cheap!)
  17. #42
    Jul 2010
    Las Vegas, NV
    Default Upgrades
    Power! 1330cc overhead cam engines should make more power! My KTM has a 1301cc motor with 160 hp. Bone stock! Rotax engines make plenty to power-add some! Add LED headlights, stronger saddlebag hinges, a hand brake, and side bags that hold a helmet (both sides!). Most of all, POWER! Looks fast, is not fast. Make it fast - like 10.5 in a quarter mile fast! Or, faster!
    Joe Meyer
  18. #43
    SpyderLovers Sponsor
    Mar 2014
    Myerstown, Pa
    Default just some smaller less expensive changes
    1. I would like to see a power source like a cigarette lighter up in the handlebar area instead of the trunk which is pretty much useless.
    2. A cup holder would be nice.
    3. a rear brake light in the top center storage box like the one Custom Dynamics makes
    4. a mud flap on the rear wheel
    5. A heavier sway bar like the others offer by aftermarket sources
    6. laser alignment from the factory
    7. better quality tires
    I'm happy with the belt drive and pretty much everything else.
  19. #44
    washington state
    I'm happy on mine
  20. #45
    May 2015
    VA
    Default Hand Brake
    think of the time it takes to recognize a problem, then lift your foot, position it, and finally compress.
    A hand brake is far safer, quicker and efficient which is what we seniors want and need. Safety please!
  21. #46
    Mar 2013
    Quote Originally Posted by flaggerphil View Post
    I agree 110%
    The number 1 thing I like to see on a Spyder is me on it going down the road
    2021 Sea To Sky, 2020 RTL
    but our benefits don't?
    2015 F3S , White & Blue
  22. #47
    Oct 2010
    Cincinnati Ohio
    A knob that turns on the radio to select stations instead of the lame push station selector.
  23. #48
    Active Member scarecrow's Avatar
    largo, florida
    Larger top load saddlebags
    Top brake light.
    Front fender turn lights.
    Full radio controls for passenger.
    Front brake lever.
    2014 RTS , Cognac
  24. #49
    Jan 2012
    Menlo, GA. 'Lookout Mountain'
    Because I have wanted one for over three years, and I attached with Sugru a 3" round flat mirror to the bottom right corner of the left hand mirror. Both our mirrors show vehicles farther away than they are.
    I can lean over a bit to see how far a vehicle is behind me. At last!
  25. #50
    Mar 2012
    Florida Space Coast
    Quote Originally Posted by granpa in Cincy View Post
    Actually, I really like that idea. I hate the push button station selector.
    And since I have a top rear brake light on my RT aftermarket, I really think they should have those on all RTs. It makes a huge difference.
