Results 1 to 13 of 13
    Very Active Member campermac's Avatar
    May 2015
    Etters PA
    Default LED Headlights on Spyder RT
    Has anyone out there performed a mod on changing out the Head Lights and Fog Lights with LED bulbs? Looking to do it, but want to see if anyone else has done it before I venture on
    2022 RT Limited , Silver w/ Black and Purple accents
    Knoxville, TN
    Default LED
    I did, no big problems. I like the result.
    Default OPTION " B "
    I went the El Cheapo route and put in 100 watt #9005 bright white halogen bulbs ( 1000 + hours to date ) ....A few people warned that the wiring might not hold ( over-heat ) and / or the plastic lens cover ( RT ) would melt ...it didn't .................I did do an Infra-red heat gun test on the cover after a day-time ride ( 90 degree's ) and the cover was 130 degree's , which is far from melting............cost of a pair on E-bay $ 5.00 shipped. The OEMs are 65 watts and yellow , mine are 100 watts and white......there is a big difference in brightness....... Mike
    Jul 2010
    Waterboro,ME
    KBcarstuuff a site sponsor has XENON Depot kits for HID and LED kits. Get a hold of them for info.
    Houston
    I also used the Xenon Depot LED kts on both Louse RT and my F3. They work GREAT
    Blue Flame Spyder F3-S
    2015 F3S , Blue Flame
    Apr 2015
    Mico TX
    Probably a good idea... one thing; I once bought a bunch of 100/60 bulbs (a dozen I think) on eBay and they turned out to be Chinese junk that were no brighter than a standard 60W (h8igh beam) bulb. I still have some of them. If you do buy 9005s, get decent quality bulbs; usually the autoparts store is a safe bet.
    Sep 2014
    Oklahoma City
    Quote Originally Posted by rogerb View Post
    Stay away from this company, they sell product they don't have in stock and lie about when it will be back in stock and when it was supposed to have shipped. Been waiting over 3 weeks for the other half of my order!
    Kb carstuff and Xenondepot are the same companies as far as I can tell.
    Active Member Tony8472's Avatar
    Gilbert, AZ
    Default LED
    Do I need to buy the whole LED kit or can I just swap out the OEM bulb with a new LED bulb?
    Tony
    2014 RT
    Mods: Adjustable side wind deflectors; Adjustable vented windshield; Rear and front trunk lights; Replaced the foot pegs with Web Boards; Gerbing heater controls; Garmin Zumo 390LM GPS; Fog lights; Front headlamp accent lights; Replaced the standard fender light bulbs with LEDs; BumpSkid; Frunk insert and stripes from WrapMySPyder; BajaRon Swaybar; Laser alignment.
    Jan 2011
    Titusville, Fl.
    Quote Originally Posted by campermac View Post
    I swapped both with Xenon Depot lites. No problems. Does not need a kit. Very happy with their service/
    May 2015
    Etters PA
    Quote Originally Posted by johnnyrocket View Post
    Where did you mount the driver/ballast?
    Do you have any part numbers you can share?
    thanks
    Active Member ricford's Avatar
    Jun 2015
    Calhoun, La
    There is a video on youtube. The video is pretty concise and demonstrates how to replace the light bulbs in the headlights. It is one hell of an ordeal. If you loosen just two more screws, the engine falls out. OK, maybe not. It is not difficult, just pretty time consuming. I have yet to do it but do want to replace the bulbs with brighter ones. And it might not be a bad idea, considering the amount of effort it takes, to replace both bulbs whether they both need replacing or not. Start off with same burn time on them. I'm thinkin' it might be better if you just removed the plastic and run naked. Not as elegant but when it's time to do maintenance....
    Aug 2015
    New Mexico
    I put LED lights on my old wing after it had HID's for over a year and the LED's were way brighter and there is no heat up time. I found cycle gear had/has a Awesome light replacement I will be doing my RT with LED' in a week or so myself . If you can check out cycle gear they also have a Great warranty as well
    GOS member (Girls On Spyders) pslawing's Avatar
    Jun 2012
    Kings Mountain, NC
    Quote Originally Posted by james199 View Post
    Do you know the part number for the RT headlight bulbs? 2012 from cycle gear?
