Results 1 to 8 of 8
    Invalid Emails
    Graham, WA.
    Default Kendra tires vs Kumho tires for the spyders
    Anyone have any luck using the Kumho brand ties on the their spyders yet?
    Invalid Emails
    May 2010
    Chelan, WA .. the dry side!!
    Default Yes
    Quote Originally Posted by spyderman051 View Post
    On my 2d Kumho rear....lots of threads on SL in regards to all things tires and Spyders. Tires and oil....unlimited disussions...
    Jun 2010
    Las Vegas
    Folks have been running the Kumho tire on Spyders for years. You can read for days about the subject, just search on Kumho.
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    Very Active Member jtoro1's Avatar
    Feb 2013
    port st lucie fl
    Default Kumho tire
    On my 2 kumho rear, I do not like it ,it hydroplanes on small puddles going to install a general altimax hp next
    Default For sure..!!
    posted to your other request. GTO (gas tires and oil) are a often discussed subject here. Search it out for days of confusing reading with end result being....choice is yours try and report...
    Jun 2013
    NE South Carolina
    For the last time there is no Kendra Tires. Kendra is bubblehead reality star Kenda makes tires.
    Gig Harbor, Washington
    Cool Tires
    I have over 6000 miles on a Kumho Tire on a 2013 RT Limited. No problems with Riding in the Rain, good Traction, nominal tire wear so far, very satisfied.
    Really happy now I'm running Kumho tires instead of the Kenda Krap!!
    Already travelled more distance on the Kumho's than the distance that wore the Kendas to the canvas, & the Kumhos still look brand new!! Of course, they are a heavier tire so they don't need quite as much air pressure in them in order to carry the same load or they'll have less traction &/or hydroplane in the wet, so I'm running 16-17 psi up front & 26 psi in the rear. Ride & handling is phenomenal, they stick like **** to a blanket, & they are much smoother & quieter than the Kendas too - and the look like last double or more distance than the Kendas did!!
    Just like fitting the BajaRon Swaybar, my only regret about the change is that I didn't swap to the Kumho's a lot sooner!!
