Results 1 to 21 of 21
    Feb 2016
    US
    Default Heat Shield for my 2015 RT SE6
    We are installing heat shields in the hopes that my ankles will be cooler on our 14 day trip. I will let you know if it works.
    Feb 2014
    Wellsboro, PA
    we have had no problem with a hot foot on our 2015. Had a 2013 with heat problem.
    Jul 2016
    SE MA
    I'd be intrested to know how it works. I also have a 2015 RT, and find it hot in the crotch, so to speak, on warm days. Doing Something similar crossed my mind. Good luck with it and enjoy the trip.
    Steve
    Jun 2014
    People's Republic of NY
    You are seating on an internal combustion gasoline engine, just saying
    Nov 2012
    North Las Vegas, NV
    You can probably remove the plastic pans under the engine and put the 2013 RT recall scoops on to force some air in there.
    2016 F3 Limited
    2019 Ryker Rally
    2014 Suzuki V Strom 650
    2020 CSC TT 250
    Very Active Member zuni's Avatar
    Mar 2014
    JAX FL
    Quote Originally Posted by Uruzgan View Post
    Steve
    We put the scoops that they made up for the 2013's on our 2014. Actually made the glove box usable. Prior to the change you could almost heat your lunch in it. The kit was about $50.
    CJ JAX
    Very Active Member robmorg's Avatar
    Oct 2013
    Pottstown, PA
    Quote Originally Posted by debbiepalamar View Post
    Which panel is that you are holding up. I cannot tell from the picture? I applied that reflective heat shield to the back of both top side panels (next to your knees and the glove box) and also the underside of both black panels under the seat, on my 2013 RT prior to the recall. It did help a lot. The panels were actually comparatively cool to the touch after that.
    I also agree with the suggestion of adding the 2013 air intake scoops. Several 1330 owners have reported that has help to reduce heat.
    Rob
    2013 RT Limited
    My "Mods & Farkles" Link
    May ALL your roads be beautiful
    Greisemer's Mill Bridge, Oley, PA
    2013 RT Limited , Lava Bronze with Antler Brown Seat
    Feb 2016
    US
    Steve
    I got an Air Hawk seat pad. That took care of the crotch heat. My thighs are fine. It's my lower legs taking the brunt of the heat. One more to install, then I will test ryde it.
    Feb 2016
    US
    Quote Originally Posted by robmorg View Post
    Which panel is that you are holding up. I cannot tell from the picture? I applied that reflective heat shield to the back of both top side panels (next to your knees and the glove box) and also the underside of both black panels under the seat, on my 2013 RT prior to the recall. It did help a lot. The panels were actually comparatively cool to the touch after that. [emoji106]
    That's the bottom side panel.
    Bossier LoUiSiAna
    Looking forward to informed opinion & results. Was(am) considering doing exhaust wrap & same on my ST (even heat reflection around the gas tank) but cant justify the cost yet. The bike runs fine only real heat problem i had was fixed with warranty. I have noticed the gas cap be lil too warm very few times, bout it. Let us know how it goes. & dont loose any parts
    I wasn't there but I still care! POW /MIA VETS
    Feb 2016
    US
    This only cost $30 to try. Summit Racing sells it.
    Default HEAT ISSUES
    ....Debbie, if your fix isn't sufficient, you want to consider something to actually remove the heat from the engine area.......Go on E-Bay item # 121899358990 .....this is just one of many sizes this seller offers..... you can get other sizes. They use very little power and can move quite a bit of air. You will just have be inventive on the way to do it.......good luck DIY'er .....Mike
    Active Member RTL1330's Avatar
    Dec 2014
    Campbell River, BC, Canada
    Default Cool crotch and glove box.
    I installed the air scoop kit that was designed for the 2013 RT on to my 2014 RTL and now my glove box and surrounding area is a lot cooler. Dealer sells kits and has numbers. I did it mainly as I like the look but cooler is good too.
    2020 RTL - Petrol Blue Metalic / Black, dark model.
    Colour match rear tail cover, Garmin GPS.
    Heated Ultra Comfort driver seat & backrest.
    LED headlamps, LED Front corner lamps and lower front LED lamp.
    Baja Ron sway bar.
    Ride Til You Rot!
    Houston
    Steve
    Install the air scoops from the 2013 heat recall. They are less than $70 and your hot air at the crotch will be GONE and glove box will stay cool.
    Blue Flame Spyder F3-S
    2015 F3S , Blue Flame
    Very Active Member Devious56's Avatar
    Oct 2015
    N.E. Florida
    Default This works
    Quote Originally Posted by RTL1330 View Post
    I did this intalltion on my 2015 RT Limited, and for less than $70.00 is the best low cost mod. I've done to my Spyder. Search for Doc Riverside and you will find all the information you need to learn about where to get the kit, and how to do the installation.
    David
    Good luck, and please let us know how this experiment works out!
    (2014 RT, and not a hint of heat problems with it...)
    Feb 2016
    US
    Rode today with temperatures in the high 80s. My legs were comfortable no matter what speed I was going. I think this was a successful way to get rid of the burn!
    Bossier LoUiSiAna
    Thx for that info , now to figure out the square footage i would need.... I was quoted $500 +parts for the pipe wrap most of my shopping has been autozone & the like. Nothing to make me jump on just yet. Again no real heat problem on mine thankfully.
    Feb 2016
    US
    Wow! That's pretty expensive.
    Apr 2015
    Brockville ONT
    Must be because were up North.I have a 2015 RT-S with no heat problems at all.
    Bill
    2018 RT Anniversary , Brake pedal extended
    Active Member ricford's Avatar
    Jun 2015
    Calhoun, La
    I installed a Catalytic Converter Delete Pipe I got at Pitbull Power Sports in Springfield, MO. That totally fixed any heat problem. Runs really cool and I live in the South where the daily 'feels like' temp averages 103. Never a hot crotch. And it sounds cooler as well.
