Need some advice please
Took the back axle out to install a hitch, direction said to jack the back up to take pressure off, well I must of jacked it up too high because the rear wheel moved forward and now the holes won't line up to put the axle back in. Any tricks anyone knows that can help me. Thanks
I would call lamonsters and ask them. They know the bikes and could probably help.
Take off belt, pull it back so the holes line up, you will probably need to align belt and adjust tension, but no big deal.
