Results 26 to 50 of 65
  1. #26
    Aug 2012
    Central Coast, CA
    I'm running the Evo's out front and am very satisfied with them. They wear well and handle just fine. They can be a little skittish if over inflated and cold. I've found they run best if inflated between 18-20 psi cold.
    2020 RTL SE6
  2. #27
    Very Active Member PaladinLV's Avatar
    Feb 2015
    Las Vegas
    Aren't the Formozas 14's rather then the stock 15's???
    Was all considering them
    AJ
    I ran two sets of them and got 30,000 miles out of them. They were okay on handling I'm now running the Federal Formoza and I love them. The handling is great. They are showing no signs of wear with 15,000 miles and I would recommend them. They are available in the stock size. Bought one set on newegg.com and another for a customer on e-bay.
    2014 RT-S
    Akrapovic Exhaust & Cat Bypass
    Bajaron Sway Bar w/links / Sena SM-10/Garmin 660
    Comfort Seat w Adjustable Backrest
    Decals by Purple Harley / Magic Strobe
    Kuryakyn Black Widow Pegs Rivco Highway Brackets
    Rivco Trunk Mounted Double Flag Holder
    FOBO / Spyder Cuff / XM Radio w MC Antenna
    2014 RT/S , Black
  3. #28
    Jun 2010
    Las Vegas
    Quote Originally Posted by PaladinLV View Post
    AJ
    No, I have them in 15" and I like them much better than the Evo. Like the Evo, the Formoza is available in the OEM tire size for 15" rims
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
  4. #29
    May 2014
    Benson, NY
    Default Great tires
    Just got my new federal's a couple days ago. I can't believe how great they are. I never realized how important the load carrying capability would be. Here they are in action.
    2015 RTS Special Series
    Russell Day Long seat
    F4 Customs windshield
    Sena 20s
  5. #30
    Very Active Member AeroPilot's Avatar
    Nov 2012
    Pueblo Colorado
    Default Good lookin' tires
    2015 RT , OEM Black Gloss
  6. #31
    Apr 2013
    Little Elm Texas
    I had them mounted on some F3 rims and put on my 2014 RT. I absolutely love them. They are so smooth that my bike feels better than new. I think part of the reason is because my stock tires may have been way out of balance from the factory. The wet weather handling is great and it appears that they might last a good while. I only have about 3k miles on them, but they look like new. I went with the stock size, and I had to loosen the front fender to install them, so I am glad I didn't go up a size. Ordered them online, and had them mounted at a local tire place for $20 mount and balance each. Probably going to look for that same tire in a 14 for my 2012 RSS when the time comes.
    They were delivered this morning, sure look to wide to fit within the 2014 RTL fenders. I'll mount them Friday to see how they fit.
    Sent from my iPhone using Tapatalk Pro
  7. #32
    May 2014
    Benson, NY
    Quote Originally Posted by shooter View Post
    Did you get the EVO's ?
    Sena 20s
  8. #33
    Apr 2013
    Little Elm Texas
    Yes
  9. #34
    Jun 2010
    Las Vegas
    Yes
    Why didnt you buy them in the factory size?
    2010 RT- 622
  10. #35
    Apr 2013
    Little Elm Texas
    I did, same as the factory size. 165/55/R15
  11. #36
    SpyderLovers Sponsor merlot's Avatar
    May 2015
    Tasmania
    Quote Originally Posted by Bensonoid View Post
    they seem to be carrying that load quite nicely
    will have to look into getting a set
    russ
  12. #37
    Default TIRE CHOICES
    Quote Originally Posted by merlot View Post
    russ
    I advise ...get the Formoza's ...... not the Evo's ..... the Evo's are favored by the " Drifter " crowd , because they SLIDE really well ............... Mike
  13. #38
    Jun 2015
    AZ
    Default this size will not fit
    Quote Originally Posted by DJFaninTN View Post
    you can order them thru Walmart and they are cheaper in the 175's
    https://www.walmart.com/ip/Federal-F...-84H/127829895
    i ordered these had them mounted and balanced and got them home will not fit not even close.
    lost half a day at the cost of mounting balancing and the cost of putting old ones back on the rims.
    Kenn
  14. #39
    Nov 2012
    North Las Vegas, NV
    Ann,
    tried finding the Formosa model, and ran out of patience...
    Do you have a link to a site where I can learn a bit about them?
    Or beter yet: a place to buy them?
    http://www.ebay.com/itm/1-New-165-55...NYm4VR&vxp=mtr
    2016 F3 Limited
    2019 Ryker Rally
    2014 Suzuki V Strom 650
    2020 CSC TT 250
  15. #40
    Apr 2013
    Little Elm Texas
    Quote Originally Posted by kbwitt View Post
    Kenn
    You ordered the wrong size, they should have been the P165/55R-15 which will fit your Spyder.
  16. #41
    I am running the Continental Contiprocontact Size 165/60 R15. My Spyder handles excellent in the rain. I don't hear any noise. Running @ 19 psi.
    I replaced the front tires last year@ 12,807 miles, I know have 16,000 miles on the spyder. I have 3,193 miles on the Continental Contiprocontact tires. Deanna
    Deanna, how tight of a fit width wise are those tires? Looking at the specs they look to be the same width as the Altimax RT43 that Mike is using and he said the RT43s are a real tight fit and he wouldn't recommend them because of that.
  17. #42
    Very Active Member Fat Baxter's Avatar
    Sep 2014
    Central Alabama
    Interesting how trends work. I bought a pair of Kumho Solus KH16s back when everyone thought they were the cat's pajamas. Now, everyone's favoring Federals.
    I'm not complaining. Replacing the Kendas with almost anything else will dramatically improve your ride. I'm more than satisfied with my choice. In my case, it made a bigger difference than replacing the stock sway bar.
  18. #43
    Default WELLLLLLL NOW THAT YOU MENTION IT
    Quote Originally Posted by Joel The Biker View Post
    You will love your EVOs!!! Drifter crowd? Really Mike? What are you smokin'? Is that stuff legal in Vermont? The EVO tires have excellent grip! I have pushed my spyder through the twisties with my EVOs and it will lift the inside front tire long before it will ever slide. Rock solid!! Even in the wet. I cant give an opinion on any other tires except the Kendas which are crap.
    ... I'm very Happy for Joel ..... you should get at least 75 to 90,000 miles from them ............ Mike
  19. #44
    Houston
    I avoid tires from 2nd and 3rd tier manufactures and 3rd world countries. Too much at stake.
    We sell and install Yokohamas, Continentals and Bridestones with excellent results. None are made in China.
    Blue Flame Spyder F3-S
    2015 F3S , Blue Flame
  20. #45
    Oct 2015
    Lynden, WA
    Default Front tires
    JC what do you recommend for front tires?
    Is anything available to match the Yokohama Rear Tire?
  21. #46
    Invalid Emails
    Jun 2014
    round rock texas
    Default tread pattern
    I was thinking the WalMart price wasn't cheaper than what I got them for on eBay but then I clicked on the link again and they went up $8.- apiece since I ordered mine.
    http://www.ebay.com/itm/142214760948...%3AMEBIDX%3AIT
    i noticed there is a Fed Formoza FD1 and also Fed. Formoza AZ01 tread pateern is different.. like the FD1 myself..
  22. #47
    Houston
    Quote Originally Posted by Haze View Post
    Yoko
    Avid S34FA 175/55-15
  23. #48
    South Okanagan, BC, Canada
    I opted for the Continental ContiProContact in 175/55R15 for our 2014 RTS. They went back on our Spyder fine but I have not had it out yet because waiting for the weather to improve a little more.
    Gary
  24. #49
    Default OMG
    I knew I could spark a response from you mike!
    Is that what it's all about for you Joel ..... Way back when you first arrived I commented to you because I thought you were selling stuff!!!!....and I knew Lamont was going to catch it and Spank you .... so it was a FRIENDLY - HEADS UP .............. when I found out you weren't ..... I - APOLOGIZED ..... which is something that others here can't / won't / are incapable of .................... Get Over It
  25. #50
    Active Member littledeer's Avatar
    sauk rapids mn
    Default front tires 2014 rt
    I am about to order new front tires for my rt and want to be sure this tire and size will fit.Federal Formoza AZ01 All Season Tire - 175/65R15 84H any help would be appreciated
