Results 1 to 10 of 10
    Sep 2016
    surfside beach
    Default how much clarance is under a 2011 can-am spyder rt
    can any one tell me i would like to do my own oil change i was going to make a ramp to work on it //// note my cam-am is not at home it is in the shop thay are servicing the clutch slave cy
    Invalid Emails
    Oct 2015
    morgantown west virginia
    Quote Originally Posted by electricman View Post
    about 5" I believe.
    Sep 2016
    surfside beach
    Question clarance under my can-am
    Quote Originally Posted by quasi View Post
    about 5" I believe.
    Thanks for your info "Is this room to get a drain pan ,and to get at the drain plugs any one know
    minnesota
    I lift mine up with a motorcycle jack and put 8" wooden blocks under the tires. This is a nice working height to get a drain pan under and not be to cramped taking out the drain plugs.
    Jul 2010
    Las Vegas, NV
    Default Room
    My jack stands at the lowest setting is 12". Gives me room for the drain pan, and room to remove the drain plugs! Depending on your drain pan, I like 6" above it to work.
    Joe Meyer
    Apr 2015
    Brockville ONT
    I use 3 plastic ramps and back the Spyder up on them.Works great and lots of room to work.
    Bill
    2018 RT Anniversary , Brake pedal extended
    Sep 2012
    Dunmore Pa.
    Also use 3 plastic ramps, I haven't spilled oil on the ground since!
    Default Well....
    There is enough clearance to do an oil change. I do my oil changes on the ground but you do have to get down low...a full table lift would ge nice but I do have other lifts for other work that can be used if you prefer to raise the spyder for the oil change....
    Nov 2012
    North Las Vegas, NV
    I use 8" high car ramps under the front wheels. Plenty of room.
    2016 F3 Limited
    2019 Ryker Rally
    2014 Suzuki V Strom 650
    2020 CSC TT 250
    Sep 2016
    surfside beach
    Default ramps for oil change
    Quote Originally Posted by Ex Winger View Post
    Bill
    thanks great for that info
