Spyderpops signal lights
Very nice, those are on my list.
I installed the Lamonster Longhorn Mirror Light Kit on my RT. It looks to be the same as the Spyderpops lights. I do like them a lot. I did have to make an adjustment after installation though. Be sure not to install too far forward on the mirror or you will not be able to see them from the operator's position. I peeled back the ends and angled them back from the center on the ends of the mirror.
Spyderpops Turn Signals
Originally Posted by marty1096
Those look REALLY sharp! How I wish that they made them for a 2014 ST Limited. .... sigh .....
Bob - I haven't been on here for awhile, but love your new avatar.
the difference
I watched both videos of these - Lamonster garage version and Spderpops, it seems to me that they plug and play in a different spot ? Was the Spyderpops in just the mirror wiring ? Thanks for all the give me the heads up....
2016 RT-S Pearl White
BRP Driver Backrest
Lamonster Spyderdock, (2) Spydercuffs
Magic Mirror w/Doc Humphreys tethers
(2) Rokform phone mounts
FOBO
SpyderPops Bumpskid,missing belt guard,Rear strobe LEDs
Lamonster LED headlights & foglights
Spyder Pockets
LED front fender kit -running & turn signals
Custom Back off mudflap
Vinyl nameplate & 1330 triple decals by New Image Signs
Custom RLS exhaust
Hogtunes speakers 5 1/4 front and back
Memphis Powersports Amp
Her name is " Purl"
signal lights
plug and play into mirror wiring
It is interesting watching the video - you can see the LEDs come on instantly while the rear lights take just a moment to brighten up. Another plus for LEDs.
2020- RT Limited
Chalk White, Can-Am rear passenger armrests, Comfort Seat, Grip puppies, RAM Cup Holders, Providence RAM Mount
FOBO2 TPMS
Aluma MCTXL trailer
BRP hitch
Big Bike Parts wiring harness
Permanent Smile!!!
This is my concern. Can you see these from the driver's seat? That's my main motiviation - since the tiny dash blinkers are so hard to see.
Yes, Mine are from Spyderpops and they are visible to the driver.
Cruzr Joe
Order some SIDE EMITTING lights cut them to length you want splice them into the turn wiring and you got the same thing. That is exactly what I did on my 11 at about half the cost ot the pre-wired one sold (Try here).
Position of sig strip
[QUOTE=Spider-man;1263948]This is my concern. Can you see these from the driver's seat? That's my main motiviation - since the tiny dash blinkers are so hard to see.[/QUOTE
Position bottom of strip toward you. Spyderpops. Take off mirror installing becomes clear. Plug N play. No splicing.
I would also suggest favoring the back/driver side of the mirror housing. They're adhesive so they can be put on anywhere you please. If you put them too close to the "gap" on the bottom side of the mirror, you won't be able to see them from the seat. Put them on on the back edge of the mirror and you'll be able to see em.
The Longhorn mirror lights are NOT the same as the "full view" mirror mounted turn signal lights. I had the same questions and asked about it. The "full view" are turn signal only, and are plug and play with the mirror lighting only, no other connection needed. The Longhorn lights are run and turn signals. On all the time and then flash with the turn signals. In order to get power for the for the lights to be on all the time, requires a second connection under the front panel. That connection is also with a plug, and no wire cutting/splicing is needed. Lamonster's video is very helpful an shows how to do both connections. Hope that clears it up for you.
Bob
Bob
Thank you very much, for clearing that up, that clears up a lot for me....I will make a decision soon....thank you again
BRP Driver Backrest
FOBO
Spyder Pockets
Custom RLS exhaust
Her name is " Purl"
Very welcome.
Bob
