Results 1 to 8 of 8
    Mar 2018
    north georgia
    Default j&s jack with spyder adapter, where to place to lift
    got the adapter for the spyder for the j&s jack but no instructions and before lifting or attempting to lift can anyone give me an idea of the lifting points, thanks for any help
    Apr 2010
    Thorn Hill, TN
    As with any jack you are going to have to find the balance spot. You will be able to tell if the spot is correct with just a few pumps of the jack, adjust as needed.
    Mar 2018
    Massachusetts
    2018 RTL , Champagne
    Mar 2012
    Beaverton, Oregon
    There is a tiny square/rectangular piece with rubber on it. IT goes int the square/rectangular indentation behind the flat center frame rail.
    2015 RT Ltd , Canamspyderaccessories Brake pedal ext. Red
    Active Member JIM EVANS's Avatar
    Sep 2014
    GAFFNEY SC
    I USE A PITBULL NO ADAPTER ABOUT THREE INCHES BEHIND THE FR WHEEL FOR ME
    JIM EVANS
    2014 RTL, cb,all panels color matched over 300 LEDs, pass armrests sat radio chrome WS brkt, larger w.s, more to come
    May 2014
    Benson, NY
    Quote Originally Posted by bmwlarry View Post
    I think this shows that spot.
    2015 RTS Special Series
    Russell Day Long seat
    F4 Customs windshield
    Sena 20s
    Jun 2018
    Melissa, TX
    Quote Originally Posted by whitedog43 View Post
    Which Spyder do you have? J&S told me they don't make a jack for the F3..
    Mar 2012
    Beaverton, Oregon
    Mine is an RT. Not sure what the difference is between the two bikes in regard ti the subframe configuration
