Just finished upgrading my bike in a huge way. I'm looking for wiring to keep the turn signals constantly on and flash when turning. I've seen the wiring for some models but not for the F3. Does anyone know of a way to wire the turn lights to act as running lights on the F3
Thanks!
Robert
2022 Spyder RT SEA-TO-SKY Mystery Blue... (bought new May 2023, a work in progress...)
2015 Can-Am Red F3-S, SE6
CalSci shield, Elka stage 5 rear shock, stage 4 front shocks, Akrapovic silencer, BajaRon Bar, Roadster Renovations vibration dampener, Tricled LED headlights and auxiliary lights, driver floorboard, driver and passenger backrests, Tricled Safety Led package, Shad BRP/SH36 side cases, Baker built luggage rack, Tricled Rear run/brake/turn signal led, Tricled LED piezo brake bullet strobe, JDM Astar LED bulbs for rear and front lights, Airhawk seat pad, USB power outlet
Are you talking about the front turn signals on the back of the mirrors? I haven’t seen those made into running lights. Doc is referring to changing your fender refkectirs into running lights then using the turn signal module to make them operate as turns also. Www.tricledusa.com has everything you need. There is a link in my signature block.
2014 RTL-SE6 8,600 miles
2011 RTS-SM5 5,000 miles
2010 RTS-SM5 59,148 miles
2010 RT- 622
& Custom Dynamic has a triple play will work for the rear. https://www.customdynamics.com/unive...ay-unit?cat=60
not sure what would get the front blinkers to work as run & as long as you have the fender running lights, you should not have an issue
Yes, I'm talking about the lights that are on the back of the mirrors. Is this still possible to do? I do have several lights from Tricled but I didn't see any wiring to make those lamps running lights...
Yes it is easy to do and I was referring to the mirrors . I like the relay idea Bill mentioned. It is the cheapest way to go. Only issue could be hyper flash. I'm going to try it on my 2014 RTS mirrors tomorrow.
Couldn't this be done with two simple blocking diodes and a resistor? Pick up 12v from a keyed line and run it through a resistor to drop a little voltage, through a blocking diode then to the turn lamp. Run the turn signal line through another blocking diode to the lamp. I am running the same setup for a tailgate led strip I added to my truck for brake and running. The supply through the resistor has a lower voltage so the bulb isn't at full strength for illumination. The blocking diodes keep the voltage from back feeding when applying the brakes and vise versa for the keyed line.
