Results 1 to 10 of 10
    Apr 2013
    Hartsville, S.C.
    Default Top Case Removal
    Just traded my 2016 triple black F3 L on a 2018 Steel Black F3 L.
    My plan was to remove the top case when not needed. I've looked in the accessories catalog and don't see the necessary "cover" to install with top case removed.
    Anyone know if this is available?
    Where to obtain?
    How much $ ?
    Thanks, Rick
    Active Member Spyder601's Avatar
    Jun 2012
    Brandon, MS
    Here you are. you are in a better spot than me as I have a pearl white F3L and could only find a black rear fairing so I purchased it and plasti dipped it with white pearl. Its not a perfect match but it works.
    Here's a link for the steal black fairing. item #20 part # 708001786
    https://www.cheapcycleparts.com/oemp...-package-t-ltd
    I actually will sell you mine as I never use it I will take the plasti dip off of course. it is very slightly used I will sell it to you for 120 shipped if you want to save a little cash
    17 F3 Limited (Pearl White), Sena 10C intercom, X Grip iPhone mount, IPS key, spyder to go cup holder, Lamonster Highway Center Lane, TricLED engine lights, TricLED night rider, LS2 Helmets, Lamonster Bypass pipe, 2 Brothers Exhaust, mirror relocator kit, Bluetooth radio module, OEM Backrest, Rear LED Light Kit
    2017 F3-T , Pearl White
    Apr 2013
    Hartsville, S.C.
    What does it take to install it and do you have those parts?
    Jun 2012
    Brandon, MS
    There’s no additional hardware to install it snaps into place and the rear seat goes over it to snug it up.
    Oct 2013
    Farmington, Delaware
    What needs to be done about the antenna when doing this?
    SpyDel
    2017 F3 Limited
    Apr 2013
    Hartsville, S.C.
    Quote Originally Posted by Spyder601 View Post
    Thanks for the info but I found a black one.
    My fiancé is ordering a pearl white limited from Imotorsports. If she decides to remove the top case I'll get in touch with you.
    Jun 2012
    Brandon, MS
    10-4 but keep in mind the one i have is Black. Glad you found something!
    Nov 2012
    North Las Vegas, NV
    The black is available and so is the white. Part #708002045 for white. It's listed under a 2016 LTD.
    2016 F3 Limited
    2019 Ryker Rally
    2014 Suzuki V Strom 650
    2020 CSC TT 250
    Apr 2013
    Hartsville, S.C.
    Quote Originally Posted by Spydel View Post
    Good question. Hadn't thought about that.
    I have noticed that my 2018 radio reception is a lot better than on the 2016.
    I mostly plan on using my SiriusXM phone app bluetoothed to the radio,
    Nov 2018
    Yorktown Va
    do you still have the cover for sell?
