Page 1 of 4 1234 LastLast
Results 1 to 25 of 85
    Mar 2019
    Las Vegas
    Default Do you use motorcycle parking spaces?
    When you are out on a ride and want to stop at the store, mall, or where ever, do you use the M/C parking spaces?
    or regular car parking spaces?
    I use the car parking spaces, so far.
    Jun 2010
    Las Vegas
    It depends on how many there are, how much closer I can park if I use one and where they are. For instance I won’t use them at a Harley dealer.
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    Quote Originally Posted by VegasSpyder View Post
    It really depends (to me anyway) on how close they are to where I'm going, but more importantly, is the Mtc. space large enough for the Spyder ….. most I've seen aren't ……. Mike
    Mar 2015
    forrest above Reno, Nv
    Some of us still ride motorcycles ( Yamaha V-Max ) and I park front wheel out in motorcycle parking spaces ( if they are there for us ). On the ---- I always use an auto space ( nose out for a quick get away).
    Lew L
    2014 RTS , Circuit Yellow
    Very Active Member AeroPilot's Avatar
    Nov 2012
    Pueblo Colorado
    Usually I park in the car spaces, and especially when ryding with our group of 4 Spyders, we try to overlap by parking two Spyders to a car space. Usually two pull in and the last two back in to overlap rear wheels and save space.... and it seems to lessen the amount of Looky Loos climbing around them
    07 Shadows, Aero, Spirit gone but not forgotten
    03 Harley Sportster, 07 RK moved on
    11 RT- 76,000 mi, 15 RT-S- 44,000 mi, traded for current 15 base RT and 16 F3T
    2015 RT , OEM Black Gloss
    Mostly car spaces and we also double up on the parking when we are out riding.
    Active Member ozarkryder's Avatar
    Nov 2018
    Anderson Missouri
    Depends on circumstances. The Spyder is a motorcyle, so I can park in motorcycle spaces, but most places don't have dedicated motorcycle spaces so it it usually in the car spaces. The RTL has handicap plates as Gloria has bad knees and trouble from a former car wreck, so if she is along we park in the wheelchair zone.
    As opposed to SpyderAnn01, I find a small amount of perverse pleasure parking the Spyder, our Goldwing 1800 trike or my Triumph Bonneville right by the front door, where the motorcycle spaces generally are, at the Harley dealer when I am getting parts for my FLHS.
    2018 Can Am Spyder RT Limited, 2013 Triumph Bonneville T100
    Motorcycle Rights: AMA Charter Life Member, MRF, FORR Life Member Local 11 Southwest Missouri, Mid-South MILE organizing committee member
    2018 RT Limited , Got one, on, then off then on until Gloria decides if she likes it or not. blue
    Active Member FalconAF's Avatar
    Mar 2019
    North Las Vegas, NV, Third Rock From The Sun
    I live in Las Vegas. I will use car spaces normally, except when I go to a covered parking garage like at a hotel/casino and it has dedicated motorcycle parking in the garage. Then I will put the Spyder in the motorcycle parking area, primarily because that area will (normally) have surveillance cameras monitoring it. The casinos aren't stupid (I used to deal at them after I retired from the Air Force). If a customer rolls up on a Gold Wing, Harley, or equivalent $40K-ish Trike, that customer has money and wants their bike watched by security while they are in the casino or staying at the hotel. And seeing as most Valet Parking will not take a motorcycle (insurance reasons primarily), many (most) casinos will provide supervised (camera surveillance) motorcycle parking for you to use in the parking garages.
    2018 Spyder RT Limited
    Apr 2017
    North Central Florida
    It really depends ( to me anyway ) how close they are to wear I'm going , but more important , is the Mtc. space large enough for the Spyder ….. most I've seen aren't ……. Mike
    +1
    Or you can do it like the Harley riders do:
    Park right beside the front door.......on the sidewalk.......beside the bicycle rack if there is one.
    Jan 2015
    southern WI
    Very few M/C stalls in our area, so car stalls it is. I would use a car stall anyway due to the width of the Spyder
    2016 RTS , Pearl White
    Default Depends
    if it is a motorcycle designated area and not lined for two wheeler I will park there. If lined then in a car space.
    Jul 2011
    Mitchell, Ontario, Canada
    Always nice to have dedicated Spyder parking spaces.
    Bossier LoUiSiAna
    True parking POLE
    IMG_8547.JPG & depending on the security, weather, & purpose of visit, (emergency Pitt stops obviously as close as possible)
    Otherwise casually what's available IMG_8558.JPG (properly & not abused )when in car spots I do try to keep on exposed end, hopefully some one rushing for spot will see enough of to not just whip on in.
    Active Member ARNIE R's Avatar
    Mar 2017
    Leesburg, VA
    Wouldn't dare park anywhere where a Harley does.....already heard enough about getting a "real Motorcycle"........
    2014 ST-S Cognac
    2014 ST-S , OEM Yes Cognac
    Mar 2019
    Quote Originally Posted by ARNIE R View Post
    Show them your Veteran's License Plate, then your VA Disability documentation, then a picture of your neck X-Ray showing the 9 screws holding your head up.
    Then tell them where they can go with their "real motorcycle".
    Active Member Spyder Insyder's Avatar
    Sep 2018
    Payson, Arizona
    I always use the designated motorcycle parking at our local Walmart. Problem is, so do some of the car drivers.
    Sep 2018
    Payson, Arizona
    If that ever happened to me, I would just show them a picture of my H-D RoadKing.
    May 2012
    Panama City, FL
    If there is one I'll normally use it if it's large enough. Like others have said, not to many parking lots around here have dedicated motorcycle parking. Dale
    Mar 2019
    Las Vegas
    Quote Originally Posted by FalconAF View Post
    Me too.. born and raised...
    Very Active Member Desert Spyder's Avatar
    Oct 2008
    Barstow, California
    Anywhere but the blue zones. At a local Del Taco there is a MC parking spot set in a wedge and the end of a row. I fit there perfectly.
    Happy Spyder Owner
    States visited on the Spyder.
    And if we live life without a passion, then we're not living.
    Feb 2012
    Spring City,Utah
    I always park in a regular car stall, but I go in just far enough to clear the lane so another car wont think the stall is empty. I don't use motorcycle stalls as I think the Spyder is too big.
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
    Active Member Wahrsuul's Avatar
    Mar 2019
    Central SC
    I usually just reply; "I will when you do." Still wouldn't park where Harley's frequent - takes too long to burn the oil off the tires
    Spent my formative riding years in Daytona. Heard some of that while riding my RD350. For the most part we were treated like distant cousins - a member of the family, but not quite right.
    2014 RT-S , Orange
    Greenville Tx
    Unless Im parking at a MC dealer, I never see dedicated MC parking. I go to my local Home Depot and half the parking lot is for disabled, veterans, internet shoppers, emplyee of the month, contractors, or just taken up by rentals or inventory.
    2017 F3 Limited
    Greenville Tx
    What really gets my goat is looking at riding groups, The description would say all types of motorcycles and trikes welcome.... then at the end it would say no spyders.
    2017 F3 Limited
    Apr 2017
    Quote Originally Posted by AY4B View Post
    They are doing me a favor by putting that in the description.
    Even when I was on two wheels, I would avoid groups that said things like that........ because experience tells me that I wouldn't like most of the people in the group anyway.
Tags for this Thread
