Results 1 to 25 of 31
    Oct 2017
    Pennsylvania
    Cool Cat delete - my thoughts
    I just installed a cat delete pipe from Baldwin Iron Works on my F3-S - it came with a spring removal/installation tool and a baffle. I was reluctant to get this seemingly useless farkle, I've read all the research I could get my hands on about the exhaust back pressure, and everything that goes into designing the exhaust system, the importance of the catalytic-converters, and how countless engineers spent millions of dollars and spilled gallons of their brain matter over the design to make it perfect, and how nothing you can do will improve anything, because they are PhDs and you're nobody.
    What a bunch of B.S. !!!
    ...oh man, the sound! What a sound! I had a grin on my face the entire ride to work and back. I giggled like a little girl accelerating through the underpasses with a roaring exhaust reverberating under the bridges.
    The spyder now performs the same way in the "eco" mode as it did in normal mode. I'm actually scared to turn it off. There's a seriously noticeable performance boost. I can't wait to take it out for a ryde again.
    I left the stock muffler on, so the sound is not obnoxious, it's just enough louder and a lot deeper. The engine braking produces this deep gurgling sound that sends shivers down your spine and makes you want to engine brake again
    I swear that vibrations are almost completely gone, the machine now runs smooth like a butter.
    The only downside - the exhaust now stinks... but who cares, it's behind me!
    Aug 2015
    Crosby,Texas
    It will burn out
    a few good long rydes and those smells will be gone. It does give you a little boost in sound and performance...
    May 2019
    Tasmania, Ausralia
    Does the pipe from Lamonster garage do the same things.
    SoFlo
    Quote Originally Posted by Airborne View Post
    Some say no, I say yes. If you are a short shift type rider, skip the bypass pipe. I found ours truly helped the mid range a lot.
    Also, ours is a straight thru bypass pipe, no added baffle and runs the stock RT muffler.
    Mar 2015
    Tacoma WA.
    so your pipe came with a baffle to keep some back pressure. Some don't . I wonder which is better? i already have a Akropovic muffler on my F3-S.
    2017 F3-S Daytona , Yellow and black
    Mar 2015
    Tacoma WA.
    How would yours work with an Akrapovic muffler, which my F3-S has? I'm thinking of getting a cat delete with or without baffle and an ECM flash.
    Active Member RLS Exhaust's Avatar
    Mar 2019
    Waxahachie TX
    if the fuel smell gets to you consider an RLS Exhaust Cat delete you will not have that issue ,More power and less un burned fuel going out the exhaust pipe also a little deeper lower tone.
    Active Member 308gunner's Avatar
    Oct 2017
    covina california
    Quick question...don't panic...did you remapp your ECU?
    Oct 2017
    covina california
    Quote Originally Posted by TerryTheSpyderRyder View Post
    If you decide to do An ECU flash...don't add a baffle in your cat delete...the tune needs to breathe...believe it...monster fuel told me this and they are right..I run no baffles.
    Northern Kalifornia
    Did Jason tell you that?
    Apr 2015
    Green Bay, WI
    Same question I was considering, the last I heard he considered it "mouse power"
    Aug 2019
    Stoughton, WI
    Quote Originally Posted by Don'tPanic View Post
    Are you running the cat delete pipe with the supplied baffle in or out?
    Aug 2019
    Stoughton, WI
    Ebay is currently running a 20% ebucks credit thru tomorrow night. At $200, the Baldwin iron works will get you $20 in ebay credit. Just might do it. I like how some makers state "no warranty issue". You're removing a federally mandated piece of emissions equipment that the machine was programmed to run with. If you were to have a engine operating issue, I think Can-Am would sure bulk. Easy enough to swap out tho. And, yes, I am fully aware of the Magnuson-Moss warranty Act. Hmmmm ........
    Apr 2015
    Green Bay, WI
    I've read several members complain about the odor.. I had no such problem--with 2 different manufacturer "Cat Delete pipe
    Interesting that the same vehicle engine produces different results.???? Not Based on other exhaust components or similar.
    Darrell
    Aug 2019
    Stoughton, WI
    Heading down to the Ozarks this afternoon. I plan on passing thru Sparta, MO tomorrow to maybe take a peek at the cat delete pipe at Baldwin. Who knows, maybe I'll ride home with one installed...
    Oct 2017
    Pennsylvania
    Yes, with the baffle in.
    Oct 2017
    Pennsylvania
    Quote Originally Posted by 308gunner View Post
    No, I didn't re-map the ECU - that is something I don't want to mess with. I like Nanny. It keeps me safe. Keeps my kids fed and my wife happy. Developing software for a living I don't recommend anyone messing with an OEM firmware but then again, it's just me.
    I did, however, replace a stock air filter with a K&N. You know, larger volume (or air speed) of exhaust needs a larger volume of intake, or something like that
    Oct 2017
    Pennsylvania
    Quote Originally Posted by Wildrice View Post
    Darrell
    I expected the smell - you remove catalytic-converter, you will get the smell. There are no visible fumes though!
    Oct 2017
    Pennsylvania
    Motorcycles in my state don't need emission inspection, plus I only installed the pipe after the warranty expired, since I had the same concerns, but a lot of members here had no issues with warranty even with removed catalytic-converter.
    Oct 2017
    Pennsylvania
    If you take a look at Martin's videos - he compares different set-ups, like cat-delete pipe with Akropovic and stock muffler. Stock muffler sounds much better with the cat-delete pipe. The combination of Akropovic and cat-delete is way too loud, to the point of hurting your ears. You might want to invest in ear plugs if you decide to go that route
    Jan 2019
    SW Georgia
    I agree with not running a baffle with the Stage 2 tune. The baffle makes it much quieter, but also reduces performance. I’ve run it both ways and took the baffle out.
    Oct 2017
    covina california
    Dont Panic..theres a way to fix the loud problem...install an RLS cat delete....WHY?...because an RLS cat delete has a resonator built in it like in a car/truck. lamonster/ironworks etc. does not have that...it cut out the loud drone noise...that resonator is very important...you install an RLS with no baffles combined with an akra sinister pipe. That bike will run...and sound very good....but it will be much better with an ecu update..more fuel..youre no longer running lean...your air/fuel ratio will match..just something to ponder...I recommend DYNOJET for several reasons.
    Aug 2019
    Stoughton, WI
    Paul Baldwin installed my cat delete pipe at his shop on my way down to the Ozarks. He recommended baffle in/baffle plug out. I opted for baffle/plug both in. Volume was just a touch louder than the stock cat/muffler, with no real difference in feel of performance. That was 2 weeks/1500 miles ago. This past week, I installed a K&N air filter and pulled the baffle plug. In addition to nice exhaust tone, I certainly can feel some improved feel in throttle response. It is a nice improvement. Looking forward to the addition of the PV3 with this combo..
    2022 RT Sea To Sky
    Active Member Davgill2002's Avatar
    Apr 2017
    Brant Lake, SD (our Golden Pond)
    I disagree. I have a 2023 RT S2S with an Akrapovic and an RLS cat delete w SS baffle. The exhaust fume smell is persistent and sometimes overwhelming around town. Highway speeds its is ok. I have over 7,000 miles since the install, and fumes persist. Any solutions other than eliminating either part, is appreciated. I also have an F4 windscreen which is 1" taller and 5" wider, thought that might be causing the problem. I intend to replace the front donut gasket to see if that helps. Otherwise, I will have to find a way to move the muffler further back, e.g. extend the lead in pipe.
Tags for this Thread
