Results 1 to 10 of 10
    Active Member RLS Exhaust's Avatar
    Mar 2019
    Waxahachie TX
    Default cat bypass would be for th 998 engine
    I trying to find out just how popular the bypass pipe would be for the 998 engine this would fit the 2013-2016 RS or ST and the 2010-2013 rt I have built one and I'm not sure if I should build these one at a time or should I turn my sample over to a partner company and buy volume .This product will be resonated so it is not to loud
    Jun 2013
    East Aurora N.Y. U.S.A.
    Nice work!
    While there are still quite a few 998 V-twin Spyders out there, I'd suspect that most original owners who were planning on fitting a cat eliminator will have already done so, which is probably why most of the retailers no longer carry them (& possibly also why some of the 'other manufacturers' have stopped producing them too!) So except for those 998 V-twin engined Spyders that change hands & go to someone who wants to drop the cat &/or fit a non-OE muffler, & those original owners who finally see the light & want to do the same, this very likely means the overall demand for your 998 engine cat bypass will be fairly slow.... altho it might pick up as those Spyders get older & their original mufflers/cat's/eliminators start to wear out?!?
    It might pay to spread the word about your 'resonated cat eliminator' & see if that attracts any buyers from the 'woulda fitted one except for the noise' crowd as well as the 'just get rid of the OE restriction & the weight' owners. Your call tho.... Good Luck!
    Active Member spyderfish's Avatar
    Jun 2014
    West Bloomfield, MI
    I assume it is all stainless, or what is the finish?
    I am interested, any idea on price?
    Would you provide installation at a Spyder event?
    2021 RTL SE6 - Marsala Red Blackout
    BajaRon Nosway Bar
    Front CentraMatic Balancers
    Value Accessories HandleBar Riser
    Brake LED Flasher
    Customized SmoothSpyder Tensioner
    Phone Phang
    Smart Mount Backrest
    LaMonster Mirror Locks
    Hopnel Frunk Bag
    Ultraguard Cover
    Active Member Richardv's Avatar
    Oct 2014
    Montreal north shore, QC
    Quote Originally Posted by RLS Exhaust View Post
    I would be interested, if it is stainless steel, and at a decent price.... Probably for 2 units
    Richard
    * 2012 RS SE5 (hers)
    * 2013 ST SM5 (mine)
    Daughter RSS SE5 2014
    Son in law RSS SM5 2013
    P.S. 3 Kumho AST 225/50R15 and 1 Toyo Proxies 4 225/50R15 rear tires
    2 sets of Kumho 175/55R15 front tires
    1 set of Hankook V4
    1 set of Canadian Tire General tire Evertrek RTX in 14" for the 2012 ...
    Jun 2017
    Crossville TN
    Quote Originally Posted by Richardv View Post
    same here
    2013 RT Limited
    Lamonster FBB with larger gripper pegs
    Value Accessories dah mount
    Custom Dynamics High Mount brake light
    BRP passenger arm rests
    Mar 2019
    Waxahachie TX
    Default RLS Exhaust bypass
    They are 304 Stainless steel and will also be offer with a Cerakote ceramic coating option . That is a radiant heat barrier that can run 400 degrees cooler. They will be priced $375 for polished and $425 for the black ceramic coated option , i will offer install at rally's but i don't have any on my calendar yet for next year .
    Mar 2019
    Waxahachie TX
    Now available on rlsexhaust.com
    Jan 2019
    Washington state
    So pardon my ignorance here. I've read a little about cat delete and the main advantage that stood out to me (as I understand it) was that you end up with a little more power. I pull a cargo trailer a few times a year so a bit more oomph is of interest.
    I have a 2010 RT SM5 and I might be interested as well but could you give me the pitch about the features and benefits of this mod, please.
    Many thanks.
    David in Wa.
    2019 Can-Am Spyder RTL SE6
    "The Ride is the reason. The destination is just the excuse."
    2019 RTL , Phoenix Orange Metalic
    Mar 2019
    Waxahachie TX
    Customers have been asking about this mod mainly for a heat reduction and a little more rumble .you do get more torque with my other cat delete pipe for the 1330 my customers say but i have not got a lot of feedback on this pipe yet.
Tags for this Thread
