What do you use for under the front end?
Other than an expensive skidplate have any of found anything to help the bottoming out issue? I found these SLiPLO products, and have been amazed at how easy they were to install, excellent price, and now I can go in and out of my driveway without tearing up the underside! https://sliplo.com/191.html
2020 Can Am Spyder RT Limited "The Comet #2"
Baja Ron Sway Bar
Passenger Armrests From Can Am
Wolo Big Bad Max Airhorn
Lamonster Top Cuff W/Ram Ball
Lamonster Power Plate
Tackform Phone Mount
Key Cover from Ebay
Lamonster Mirror Locks
Ultragard Cover from Lamonster
Top Grills from Spyderpops
Garage Door Opener from Spyderpops
3.5mm Extension from Amazon
Lamonster USB Cable Holder & Cable
Foam Grips from Spyderpops
Tricled Strobe Brake Light module
Tricled Bag Lights (replace reflectors)
Tricled Turn/Brake/Run Signals Rear
Tricled Floorboard Lights
Tricled Sequential Run/Turn Fender Lights
Tricled A-Frame Run/Turn Lights
Tricled LED American Flag Mount & Flag
Showchrome American Flag
I've often wondered, since I first scraped my RT, why people just don't seem to watch where the heck they're going?
Spring stiffeners
I like the 3/8" thick, superior coverage, and yes, expensive bumpskid under the wimpy thin plastic under my Spyder. I also have spring stiffeners ( 2 per spring ) that did raise the about 1/2". I have seen a couple of gouges in the thick protective bumpskid and I am glad it's there.
Lew L
Hoping to see more people that have actually used the SLiPLO bumpskids comment on how they have worked for them.
Baja Ron Sway Bar
Key Cover from Ebay
I got stiffer springs for my elka shocks. problem solved. Although I do recommend a skid plate. Those Slipos dont do much.
2017 F3 Limited
If you have problems bottoming out and have elka shocks, they will send you stiffer springs free of charge.
2017 F3 Limited
Nothing. It has served me well for 25k miles
2014 RTL Platinum
Nothing. However, the Fox Shox are certainly firmer, and I take efforts to enter possible areas that can scrape at angle.
Fullsize bumpskid plus adjustable spring stiffeners.When I go offroading I turn the stiffeners up an inch or so.
: 2017 RTL ORBITAL BLUE
just soap & a sponge when in the shower
SpyderLovers Sponsor
This Protects your front end the best of all
I have them on sale right now, The price shown
is NOT your price I sell for much less...it's to late for Christmas deliv.
but I will extend the low pricing after Christmas
CALL ME 209-887-3283
Merry Christmas
Hey Dave, do U have those 4 a RS??? Thanks
Hi
Dave here motorcycledave.com
I am a Dealer / Dist. for Rivco and can save you money on this...WAY BETTER than anything else out there
and you will have a great place to mount lights. Call me for Discount Price
209-887-3283 Yes I am working from home like everyone else...
Originally Posted by Motorcycledave
Hi
Dave, I bought the aluminum skid plates from Rivco that are supposed to attach to those bumpers. I didn't read the fine print that says the plates ONLY attach to parts that come with the bumper. Color me PISSED, but my fault for buying excited. However, I did figure out a way to get them mounted. The plates work wonderfully. And to anyone that is considering buying the plates, read the installation instructions for the bumper and you'll see what part you'll need to fabricate. Or PM to me.
Tag-Along trailer
7' x 10' Cargo trailer
Garmin 396 LM GPS
New Banshee AGM
M3 TPMS on front tires
Loose Nut Behind Handlebars
elka shocks work for me no more bottoming out
richie spyder
If you get your Spyder returned to the original ride height (where it sits before loading it up). You will reduce or eliminate your ground strikes. The key is to recover that lost 2 inches or more of ground clearance. This also has the benefits of maintaining your aliment and giving you more control and better handling. It is a shame that BRP no longer mounts adjustable shock springs on current Spyder models.
Got a bump skid plate under there, but mostly got dried possum guts and a layer of armadillo parts under there.
Yeah, I had to upgrade my front shocks anyway, and haven’t bottomed out since the heavy duty Wilbers were installed.
Harrington, Australia
HeliBars Handlebars
Kenda Kanine rear.
The bumpskid will spread the shock of the hit across the full bottom of the frunk whereas the sliplo would let the force transfer to the area just above where it sits.I think the skid could take a much bigger whack without causing damage.
