Results 1 to 4 of 4
    washington state
    Default wanted wider front tires
    where can I have info on wider tires for 2012 RT?
    Nov 2018
    Waynesboro, PA
    Try doing a search top right side search tires I'm sure you will find all kinds of information.
    My Spyder
    2012 RTL , Brown
    Quote Originally Posted by jerpinoy View Post
    Vredestein Quatrac 5 has two good choices in Your 14inch size wheels..... A 165/65-14 or 165/60-14 might be the best bet, they do sell a 185/55-14 but that might need shims/washers for the fender brackets. This wouldn't be an issue for me …. but that's me not you …...The Q - 5 imho is the best tire now available for any Spyder. …. many here who are using it - love it ….. Mike ...… PS, if you are seeking more lateral traction the first thing you will have to do is eliminate the VSS …. I am 99.999 % sure you won't be able to achieve that.
    It's been a while since we have heard from you.
