Results 1 to 5 of 5
    whitman mass.
    Default Rear hatch open idiot light
    My rear hatch idiot light keeps coming on.i replace the center latch assembly with no luck. Where to next ? 2012 rts
    Last edited by Peter Aawen; 03-09-2020 at 04:48 PM. Reason: Title - Idit - Idiot ;-)
    Oct 2014
    Fort Mill, SC
    I'm not 100% sure, but I think the side bags each have a switch that will indicate they are open.
    1998 Honda Valkyrie
    2006 Mustang GT. Varooooom!
    US Navy Veteran
    Member: American Legion
    It may be as simple as the compartment is actually not perfectly closed. They have to be shut "just so." If you can pull on the lid, and it opens, they were not shut good.
    Feb 2019
    Portland, Oregon
    It may not be the latch at all. I had the same problem and it was solved by shimming up the micro switch.
    Very Active Member Fat Baxter's Avatar
    Sep 2014
    Central Alabama
    Did you remove any rear end Tupperware recently, as in adding a farkle? I found out that, if you don't re-mount the Tupperware just right, it puts pressure on the latching mechanisms, enough so they pop open occasionally.
