Power for lighting up BRP badges
Wanting to put aftermarket badges on front and back that lite-up. Any suggestion where to get power from?
Hopefully you'll get some helpful responses other than the only thing that came to mind: "Badges? We ain't got no badges. We don't need no badges. I don't have to show you any stinking badges!"
https://www.youtube.com/watch?v=VqomZQMZQCQ
Think it's time for me to call it a day. ("It's a day!")
Regards,
Bret
2017 RT-S Orbital Blue
BajaRon Anti-Sway Bar
SpyderPops LED Bumpskid, Spyclops II LED, Full View Turn Signals & Belt Guard
Sena 20S Bluetooth Headsets
Brake Free Helmet Light
FOBO Bike for Trike
Rugged Geek RG1000 Safety Plus Jump Starter/Air Compressor
Lamonster RAM mount/Techmount TechGripper
Drink2Go Cup Holders
UltraGard Half Cover
Look for Sue Hopper on Facebook. She does glowing badges with Luminor paint.
2020 Petrol Metallic RT-Limited Dark Edition
2014 Silver Platinum Satin RT-Limited SE6 Project Road Warrior Edition (previous ride)
2009 Red SM5 (Previous Ride)
Retired MSgt ('89-'13) U.S. Air Force - A-10 Crew Chief
I installed lighted badges on both the frunk and trunk. On the frunk, I drilled a hole under the badge ran wire along the outside of the funk opening under the tupperware for the fog lights, connected it to the wires running from the tip light under the lower air deflector. I have the tricled light ring on the trunk so was able to splice into that for power, only had to drill a hole in the trunk for the wires. If it wasn't for the light ring, I would have run the wires under the trunk shell, on the right side, down into the rear of the spyder at the hinge finally connecting the wires to the rear lights.
Pic 1 is the wire going into the rear of the trunk at the hinge, Pic 2 is the badge (it's lit but the ring overpowers it), Pic 3 is the frunk badge (custom made by Sue Hopper), Pic 4 shows the wire from the hood starting to run outside the frunk under the tupperware. Sorry the pics are sideways couldn't rotate them.
