Results 1 to 17 of 17
    Sep 2015
    Chilliwack, BC. Canada
    Default Excess heat in the seat
    I realize there was/is a mod purchase for the 2013 Spyders that has been used by others on the later models, but I’m wondering if anyone has tried lifting their seat and putting foil wrapped insulation down. Seems to me that using that insulation under the seat plus having a sheepskin butt pad on top of the seat should make an immense difference. Anybody? 2014 RTS-SE6.
    Tri-Axis Chrome Handlebars
    Sena SM10 BT Dongle
    Double USB Port/Volt meter
    LaMonster Magic Mirrors
    BajaRon Swaybar
    HALO Skid Plate
    Shorty Antenna
    LaMonster Cat Delete
    Akrapovic Muffler
    FOBO2 TPMS
    Rear Trunk Rack
    Bruce Erickson
    Chilliwack, BC
    Canada
    2014 RTS-SE6 - Cognac
    I have 67K miles on my Spyder and I don't notice any excess heat in the BRP Comfort Seat, and I live in a lot warmer climate and always wear mesh pants and jacket spring through fall.
    Sep 2015
    I have 51,000 km on mine with the stock seat, and I honestly didn’t really notice it in previous years, but as I get older (now 77) I find that at 70* F all is well, but over 75* my butt starts to ache/burn after about 1 1/2 hours and getting off and walking around for 15 - 20 minutes helps but only for about 15 minutes. I purchased a butt pad from Alaska Leather, and it helps, but..... so I’m still not a happy ryder nd still looking for a solution.
    Sena SM10 BT Dongle
    BajaRon Swaybar
    HALO Skid Plate
    Shorty Antenna
    Akrapovic Muffler
    FOBO2 TPMS
    Rear Trunk Rack
    Bruce Erickson
    Chilliwack, BC
    Canada
    May 2017
    Mesa, Arid-Zone-A
    Well Bruce, I'm in the same age group as you. I think what you are experiencing is our inability to turn the clock back. Things happen with age. I had the stock seat on my Spyder and the best combination for me was an AirHawk seat pad with an Alaska Sheepskin on top of that. I don't think heat was the issue but rather my aging and aching bones..... Jim
    Semper Fi
    Sep 2015
    Quote Originally Posted by canamjhb View Post
    Thanks for that, Jim....I think ��. That’s a situation that I don’t like to consider, but....I totally agree with you as to age being a definite factor. I also think that my having Leukemia is also a consideration. Now, with all that said, I am looking for a solution, without spending an arm and a leg....I just can’t afford losing either one of those.
    Sena SM10 BT Dongle
    BajaRon Swaybar
    HALO Skid Plate
    Shorty Antenna
    Akrapovic Muffler
    FOBO2 TPMS
    Rear Trunk Rack
    Bruce Erickson
    Chilliwack, BC
    Canada
    Seat Beads. Looked uncomfortable to me. But got them anyway. Really lets a lot of air in between the bum and the seat. Works great in the rain as well because the water does not pool under you and soak through your rain gear.
    Quite comfortable, actually!
    No hot seat experiences here. Have 2014 and 2019 years. BRP comfort seat on the 2014 and BRP Cannonball seat on the 2019.
    We have temps in the high 90's most of the riding season.
    Linden, CA
    Take off the sheep skin and try this you will notice a difference right off
    Only $79.95 it's an easy to do yourself project.
    Quote Originally Posted by bigbadbrucie View Post
    Active Member furface90's Avatar
    May 2014
    Phoenix, Az
    Default Beads
    I have a 2013 with 55k miles on it. I added some insulation under the seat which helped a little, not much.
    I tried other solutions but found that the beads worked the best for me. Lets a lot of air move beneath you.
    Sep 2015
    I just found out that my son has an airhawk that he doesn’t use, so I’m going to give it a try. Thanks to all for their suggestions. Very much appreciated.
    Sena SM10 BT Dongle
    BajaRon Swaybar
    HALO Skid Plate
    Shorty Antenna
    Akrapovic Muffler
    FOBO2 TPMS
    Rear Trunk Rack
    Bruce Erickson
    Chilliwack, BC
    Canada
    That is a good solution. I used to use the Airhawk a lot for butt pain. It will most likely insulate against heat.
    Mar 2008
    Hesston, PA
    Do the vent kit mod...I will do wonders for your under the seat and glove box heat...Its inexpensive and relatively easy...
    Sep 2015
    I just came home from a day ride, where the temperatures ranged between 86*F and 100*F and with the airhawk and my sheepskin over top of it, I made out just fine. My butt started burning a bit towards the end, but it was still doable. Many thanks for suggesting the airhawk.
    Bruce
    Sena SM10 BT Dongle
    BajaRon Swaybar
    HALO Skid Plate
    Shorty Antenna
    Akrapovic Muffler
    FOBO2 TPMS
    Rear Trunk Rack
    Bruce Erickson
    Chilliwack, BC
    Canada
    Feb 2012
    Spring City,Utah
    I am just now reading this thread, hoping for some relief. I rode 375 miles yesterday, Spring City, Guardsman Pass, Mirror Lake Highway, Provo Canyon, Spanish Fork canyon. As you can tell much of the road was in the mountains. I have Dave's gel pad, I have the air scoops on a 2012, and I have beaded seat pad. I was still hot in the seat and by the end of that ride I was sore from those beads. I think I will try a sheep seat pad next. (say that 5 times real fast). I have not had that problem in the past, but have not been 74 before either, that may be the cause of all in the end(no pun intended)
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
    Sep 2015
    I’ e never had rhe problem before either, but I am now 77......hmmmmm, seems there may be a pattern.
    Good luck. Hope it works out for you!
    Sena SM10 BT Dongle
    BajaRon Swaybar
    HALO Skid Plate
    Shorty Antenna
    Akrapovic Muffler
    FOBO2 TPMS
    Rear Trunk Rack
    Bruce Erickson
    Chilliwack, BC
    Canada
    Active Member spyderfish's Avatar
    Jun 2014
    West Bloomfield, MI
    I made risers from 2x4 and lifted the entire seat up 1.5 inches. Metal edges friction grip the frame, easy to put in and out. You can hardly tell the seat is up unless you really look close. Much reduced best in seat.
    Take them out below 60 degrees, when heat is good. And they help with riding posture, more upright.
    More info here:
    https://www.spyderlovers.com/forums/...03#post1027403
    2021 RTL SE6 - Marsala Red Blackout
    BajaRon Nosway Bar
    Front CentraMatic Balancers
    Value Accessories HandleBar Riser
    Brake LED Flasher
    Customized SmoothSpyder Tensioner
    Phone Phang
    Smart Mount Backrest
    LaMonster Mirror Locks
    Hopnel Frunk Bag
    Ultraguard Cover
    Very Active Member Big F's Avatar
    Aug 2012
    Bellevue, NE
    I have a 2018 RTL and we put a sheepskin seat cover on a year ago and love it.. we can get on the seat and ride even during 100 degree days and no hot issues AND it is warmer during the cool season also..
    BIG F
