Oil change problems - moving the brake reservoir?
I have a F3 2020. I am changing the oil and filter. I can't get the brake fluid reservior to move to fit all things in place! I must be missing something. Any ideas!
Just what I needed. Thank you!
You may also want to replace the Torx drain plugs with hex ones such as Gold Plugs. They are magnetic and much easier to work with.
