Results 1 to 7 of 7
    Active Member TIMEMACHINE's Avatar
    Feb 2021
    King George, VA
    Default F4 Windshield installation - No loctite?
    The instructions for my new F4 Customs windshield say to not use any loctite. Can anyone confirm this? My impulse is to use some on the mounting bolts, but I was curious what others did?
    Feb 2020
    N. Wilkesboro, NC
    I've got a multitude of aftermarket windscreens (2 F4s and a 7Jurock). I've never put any Loctite on any of the windscreen bolts. The windscreen isn't going anywhere.
    Apr 2021
    Ky
    Fishing line works
    Feb 2019
    Portland, Oregon
    I never heard of putting thread locker on windshield fasteners. I want to be able to remove it occasionally to give it a good polishing.
    Sep 2016
    Chillicothe, Oh.
    Loctite can and will damage certain types of plastics as will some silicon sealer products. It can make the plastic around the area brittle. Better safe than sorry and forget the Loctite.
    2015 RT , Black
    Feb 2021
    King George, VA
    Thanks everyone. I really wanted to put a dab on the mounting screws, which are at the base of the windshield. The mounting bracket is metal and the screws go into the four empty screw holes already in the Ryker.
    I resisted the urge. Thanks again.
    Very Active Member Markubis's Avatar
    Jan 2018
    NH
    THIS ^^
    The solvents in the loctite can damage the chemical properties of the plastic....making it brittle and crack.
