Results 1 to 9 of 9
    May 2021
    Tennessee
    Default Any Suggestions on mounting Garmin XT onto '21 RT-L?
    Picking up the 2021 RTL next Thursday from Extreme Power Sports in Columbus Ga. Where is the best place to mount the Garmin XT and where to run the power cable? Are there any videos out yet for removing the Tupperware on the 21s?
    Clinton, MS
    2020 and 2021 tupperware removal is the same. Several vids out there, many referenced on this site. I think there is an install vid on the Lamonster site.
    Oct 2020
    KS
    I used the videos out there to wire my XT to the right side of my 21 RT where the outlet is intended for this purpose. I used a Posi-Tap connector and left the stock connector intact. Just run the wiring down beside the steering. Pop off the right speaker cover to help visualize. Tupperware removal was not an issue once I watched the videos several times.
    Can't comment on powering the Zumo but, IMO, your placement of the device should be based upon your assessment of how it may distract you from the safe operation of your Spyder. The best place for you to locate it may not be where another owner might place it.
    Sep 2020
    Middletown, NJ
    Quote Originally Posted by milryder View Post
    I did same on my 20 RT.
    1 - If you use the XT for guidance AND use BT instructions to helmet, you can mount off to the side and lower so it doesn't affect forward view.
    2 - If you don't get voice instructions to your lid, best to mount centered and slightly below dash display view so you can glance down occasionally to view route ahead.
    I have the GPS sound off due to intercom interruptions so mine is mounted like #2.
    2020 RT base , Chalk White
    Very Active Member pidjones's Avatar
    Mar 2021
    East TN
    Several vendors sell a RAM ball on a bolt that replaces one of the handlebar bolts ~$60. Then, you use standard RAM arm and adapter to the back of the Garmin mount and wire as the videos (Lamont's is great) show. If you are handy and have a lathe, you can buy 10mm stud and coupler nut from ACE hardware, cut down about half of the flats, and attach a 10mm x 1.5 RAM ball on it yourself for about $17.
    1976 RD400c
    Apr 2020
    Lebanon ohio
    I used the Lamont handle bar clamp mount really well made easy to install puts it in a good position.works very well for me
    Mar 2013
    I mounted my Garmin XT to the top of my dash just in front of the slot opening using a mount like this
    https://www.amazon.com/dp/B083G7MZPN...2s9dHJ1ZQ&th=1
    I used 3M dubbed back auto tape to mount it. Ran the cable end for the GPS through the dash slot down the right side to the Spyders GPS connection ( this connection is powered as soon as you turn on the key which makes it great for checking, or programming the GPS without having to start the Spyder)
    Having it mounted there allows me to not have to take my eyes off the view ahead to keep tract of directions.
    2021 Sea To Sky, 2020 RTL
    but our benefits don't?
    2015 F3S , White & Blue
    Active Member KenF's Avatar
    May 2019
    Lacey, WA
    I have a 2020 RTL with a Garmin XT and use the Lamonster Ram mount 2.0 for F3, RT, ST, RS (All Options). Attaches to the center handle bar clamp.
    2020 Spyder RT Limited
    2020 RT Limited , Marsala Red/Chrome
