Results 1 to 8 of 8
    Jan 2019
    Virginia
    Question CVT Transmission behaviour Questions - is this normal??
    Hello,
    I bought my Ryker Rally used and rode it for the first time yesterday. It has about 2,300 miles. I've never ridden anything with a CVT and I have a couple of questions about the way the transmission behaves. When I shift from forward to reverse or vice versa, there is a half second delay before the transmission engages and moves the bike. This wouldn't be too odd by itself except for the second thing. When moving the bike from a stop, I have to get the RPMs to build a bit before the bike moves. I equate this to having to rev a manual motorcycle a bit before you let out the clutch and get moving.
    If this is normal behavior, so be it. Otherwise, I guess I am in for a trip to the shop before its riding season again. I appreciate any insight.
    That sounds perfectly normal!
    See the Sig Line below...
    Quote Originally Posted by boone View Post
    Hello,
    The Ryker CVT works much like the old centrifugal clutches on go-carts, etc. Because the CVT is a centrifugal clutch. Just a much more sophisticated version. But the engagement process is pretty much the same.
    Jan 2019
    Virginia
    Thanks for the responses. This makes me feel better.
    Very Active Member Tslepebull's Avatar
    Dec 2018
    East Texas
    To elaborate on what has been said before, the clutches do not fully engage until engine speed reaches 1800 RPM.
    2019 Ryler Rally , Shock Yellow
    Very Active Member Markubis's Avatar
    Jan 2018
    NH
    Which leads to the problem. You won't be able to sit at a stoplight and rev your engine like other bikes do.
    Jan 2019
    Virginia
    Quote Originally Posted by Markubis View Post
    You just ruined my ownership experience.
    Very Active Member SportsterDoc's Avatar
    May 2020
    New Mexico
    No, but you can burn a lot of rubber and/or disappear very quickly!
Tags for this Thread
