Results 1 to 11 of 11
    Active Member Claire's Avatar
    Jul 2019
    Georgia
    Default Has anyone done a Y Pipe wrap?
    Has anyone wrapped the Y pipe on a 2009 GS SE5?
    2009 GS SE5: Stage 2 Elka front shocks, BajaRon sway bar, K&N air filter, kuryakyn foot pegs, TricLED rear and front lights.
    Aug 2020
    Omaha, NE
    Can't be sure of year or model, but I do recall watching some dude try to wrap a pipe on a spyder, on YouTube.
    HTH
    Quote Originally Posted by Claire View Post
    I'm sure there are .... However is the benefit worth the effort .... Some of the exhaust pipeing wouldn't be too difficult to do .... you could just do that much .... Mike
    Not an '09 GS, so I dunno if it'll help you any, but I've wrapped the 'Y' header pipes right down to the cat eliminator on my 2013 RT Ltd?!? Why do you ask?
    Jul 2019
    Georgia
    To eliminate more heat.
    This is my muffler as of nov 2021. Then added wrap this feb. Huge difference.
    Active Member Gilly's Avatar
    Dec 2019
    Musquash , New Brunswick , CANADA
    Not sure on the benefit either .. but I like the looks of it for sure .
    2009 Roadster SM5 , Silver and Black
    Oct 2020
    Dayton, Ohio
    Quote Originally Posted by Gilly View Post
    I wrapped everything from the block to the exhaust cans. I did not however wtap the 3 sections that the pipes go into each other.
    Dec 2019
    Kapolei, HI
    So for those who wrapped: did it make any difference in under tupperware heat?
    Quote Originally Posted by PhilY View Post
    I did .... and yes it helps a lot to contain the heat .... which improves / speeds up the exhaust gases ..... Mike
    Sep 2015
    Awendaw, SC
    Never wrapped the y-pipe but wrapped the two main pipes, it did help but I heard it can cause them to crack. So I went to a different level, cut the main pipes out ordered some stainless-steel exhaust couplings, had them welded, and sent the pipes including the cat delete ceramic coated inside and out.
    2014 RS+ , Excel 8.8 and NGK plugs Currently pearl white, Aircraft gray after rivets installed
    Faribault, MN
    I titanium wrapped my tuned pipe and cat delete on my '18 RTL, (excluding the junctions) and feel it dramatically reduced rider heat. Kudo's to Claire in Georgia, yours looks very neat and tidy.
    Safe Rides,
    David and Sharon Goebel
    Both Retired USAF Veterans
    IBA 70020
