Results 1 to 2 of 2
    Apr 2011
    Rogers, Arkansas
    Default 2011 RT DPS error - how to reset or cost to change unit?
    Have a engine trouble light with a check DPS alert. how to reset or cost to change unit. Happened years ago but reset after turning off and back on. This time no resets. Heard it could cost up to $1000 for dealer to change?
    Quote Originally Posted by yankeeDoolte View Post
    The early model Spyders had issues with the DPS units .... BRP had a re-call om them and re-placed them under warranty .... I think the cost is around $ 1800.00 ... Do a test try turning the handlebars with the engine OFF , then start engine and see if there is a difference , if there is then the code is probably a clitch ....JMHO ...... Mike
