Results 1 to 25 of 29
    Active Member spyderfish's Avatar
    Jun 2014
    West Bloomfield, MI
    Default ACE 1330 - What RPM do you cruise??
    Talking flat and level, light wind. I am jaded by 7 years of 998, not sure how to detect 1330 is lugging because it seems good all the way down to 2500.
    Is steady 2500 RPM bad for engine?
    2021 RTL SE6 - Marsala Red Blackout
    BajaRon Nosway Bar
    Front CentraMatic Balancers
    Value Accessories HandleBar Riser
    Brake LED Flasher
    Customized SmoothSpyder Tensioner
    Phone Phang
    Smart Mount Backrest
    LaMonster Mirror Locks
    Hopnel Frunk Bag
    Ultraguard Cover
    INDIANA, USA
    Default Don't Lug the Spyder
    ....Trying to understand your question.
    I usually cruise around 3500 rpms in 5th or 6th gear.
    That being said, there is some information in your operating manual. Check it out and see what it has to say.
    Remember that Lugging your Spyder Engine is not a good thing to do.
    Enjoy your Ryde Time and Stay Safe. .....
    ENJOY YOUR LIFE WITH A SPYDER
    Durham,Maine
    I think it's more a trany issue if you lug it down than a engine issue!
    2012 RTL , Pearl
    Active Member FlyBoy2121's Avatar
    Aug 2018
    Canada
    I Guys
    My RTL 3400 has 3500 RPM on the highway.
    FlyBoy2121
    2014 RT ltd , original original Cognac
    Active Member Piratezz's Avatar
    May 2020
    Heesch Noord- Brabant The Netherlands
    Cruisin at 2500 rpm's is absolutely not harmfull for the engine, neither the clutch will suffer, but be prepared to shift down, when going uphill, or if you are passing a car, semi, or a fast cyclist....
    Spyder is the happiest round the 3500 to 5500 rpm mark...for shifting points, Me when in the city, I normally drive in 3rd or 4th gear, 45 to 65 km'h, when on highway cruiscontrol and a steady 100 km'h, the spyder runs at 3000 rpm.
    Just don't hit the throttle in a too low gear or rpm, that is what causes damage in the long run, better to shift down, and hit the gas... The spyder will reward you every time, with a big grin on your face
    Swaybar (Ron's)
    Pedalbox, Awesome Upgrade...
    2019 F3s , O.E.M. Black, Black, Black
    3500 is the sweet spot on my 1330's. When in sixth, at speeds over 60 mph...its going to be what its going to be. Otherwise, we keep it in the 3500 range for the gears.
    Vermont
    Quote Originally Posted by spyderfish View Post
    With the "1330 Ace" engines (Spyder years 2014 and up) you can cruise around comfortably at 3,300 RPM'S with the outstanding ride of the new 6-speed engine transmission. The new Spyder RT is optimized to deliver a smooth ride for you and your passenger, thanks to its long-ratio sixth gear and new hydraulic clutch activation system with electronic pressure control. Pass thru town without downshifting. Just relax and enjoy the scenery.
    I have a 2014 RTS-SE6, the Spyder cruises around @ 3,300 RPM's comfortably, I don't feel any lugging.
    Deanna
    Gremlin Bell
    SpyderPops Missing Guard Belt
    Ultimate F3 Floorboards
    Sway Bar with Links
    Rolo Laser Alignment
    Half Cover
    Show chrome Trunk Shock
    Northern Kalifornia
    3,000 is my sweet spot. Find I get my best MPG in that range and most of the sharper turns can be more easily done without braking by using engine deceleration to slow down a bit. Makes brake pads/rotors last longer. Also, obstacles are more easily avoided. Running 2 wheels, obstacles were not that great of a threat. But with 3 wheels and only 4" of ground clearance obstacles are a greater concern now.
    Aug 2019
    Stoughton, WI
    Having a F3S with 89t rear pulley, my cruising rpm's are a bit higher. Heck, on 80mph interstates, I'm at 4500+.
    2022 RT Sea To Sky
    The ECM controlling the 1330 ACE engine will not let you lug it. If your RPMs are not high enough it won't let you upshift; if you let the RPMs drop too low it automatically downshifts to the next gear(s). The Hydraulic Control Module locks up instantly so you don't have to keep the engine spinning like a V-twin with a centrifugal clutch.
    Feb 2022
    very southern tip of Texas
    ^^^ But - if you have a lever in front of the left grip ... ????
    White 2015 F3-S SE6 - “Gypsy” (hers)
    Yellow 2017 F3-S Daytona 500 SM6 (his)
    IMHO only the V-twin engines ...... Mike
    Dec 2015
    Oakley Utah
    Quote Originally Posted by Piratezz View Post
    Exactly right
    2014 RTL Platinum
    Dec 2015
    Oakley Utah
    2014 RTL Platinum
    Jun 2011
    Alamogordo, NM
    Keep in mind that Lugging is low RPM with hi throttle settings You can cruise all day at low RPM's with corresponding low throttle settings.
    Dean O
    Gran Pa Hoon
    Founder San Jose BMW
    Alamogordo, NM
    '20 Spyder F3 L
    Oct 2011
    Kalamazoo, Mi
    Default 1330 what RPM do you cruise
    I normally travel @ 60MPH which correlates to 3400 RPM
    Al in Kazoo
    2018 F3-T
    2018 F3-T , Pearl White
    Jun 2014
    West Bloomfield, MI
    Great information, thanx all. Looks like 3,000 min is a good rule to use.
    BajaRon Nosway Bar
    Brake LED Flasher
    Phone Phang
    Hopnel Frunk Bag
    Ultraguard Cover
    Quote Originally Posted by BCNewell View Post
    Yes, the lever is there, but if you push it to upshift and the RPMs are not high enough the transmission will not upshift. Downshifting it will work at any RPM to allow the rider to take maximum advantage of engine braking.
    Errrmmm, I think he's talking about that alloy lever you pull back towards the handgrip before initiating any gear change that some of the earlier/less advanced Spyders still have JayBros - it's old technology I know; it doesn't work anywhere near as quickly/easily as the paddle shift most of us use these days; but I'm led to believe that there are still a few of the earlier Spyders with Manual clutches running around out there! Just as an aside tho, there are rev/road speed/gear selection situations where the SE might balk at making a downshift, altho you do hafta really work at it to find them!
    BC, if it is one of those old fashioned alloy clutch lever thingies in front of the left handlebar/hand grip that you're asking about, then you have my sympathy; but in that case, it's all up to you with no fail-safes!
    Sep 2020
    Middletown, NJ
    3000 is my low end with 35-3700 usual for cruising but the engine feels more ready to go at 4000+. If in traffic I'm at 4000 if a hasty maneuver is needed.
    2020 RT base , Chalk White
    Active Member mecsw500's Avatar
    Sep 2021
    UT
    I don't really look at the rev counter very often to be honest. On the freeway I usually cruise at 70 mph or so in top gear, perhaps 75-80 mph in the 80 mph speed limit sections, the engine seems happy enough - very smooth. On acceleration I think peak torque seems to be well below peak power so there isn't much point in revving it out to the redline. The 1330 seems to be all about mid range and that's where mine is happiest.
    Can Am Syder RT Limited (2021)
    Triumph Bonneville T120 (2018)
    2021 RT Limited , Silver
    Aug 2020
    Il
    I try to keep the RPM's at least 3-3500rpm. If its close to 2500 or less, I will downshift. I notice a bit of lugging or hesitation at 2500 or under.
    21 Spyder base F3
    May 2020
    Cruisin rpm's @2500, is not harming the spyder at all, just don't hit the gas in high gear/ low revs, I have mine custom tuned for low revs/cruisin, more bottom end torque, and missing some at the top end.
    Swaybar (Ron's)
    Sebring, FL
    With gas prices at all time highs, cruisin' at 2500 rpm makes a lot of sense. Just made a trip from FL to TN and return, my credit card was heating up something fierce.
    2020 RTL
    Sep 2020
    Middletown, NJ
    2020 RTL
    I'm not sure that's an accurate assessment. Low RPMs doesn't mean better gas mileage. The 'load' is the key. I watched the instant MPG cruising at steady speed and the engine was happier at 3000 than 2500 and the instant MPG was higher. Not a scientific experiment but it was a clear difference.
