Page 14 of 17 FirstFirst ... 41011121314151617 LastLast
Results 326 to 350 of 405
  1. #326
    Active Member sKiZo's Avatar
    Mar 2021
    Michigan
    Quote Originally Posted by MudBug View Post
    I installed the comfort seat and managed to break off one mounting tab . BRP, please use a better plastic material or a metal tab system, because you know most people don't want to lift the body off to install a seat that *should* just snap into place. I never had to disassemble any motorcycle I had to remove the seat.
    Evarbody, DO heat the tabs when installing the seat. Makes them more flexible and reduces breakage.
    PS - seems to me somebody used heavy duty paper clips that still fit thru the mounting holes to squeeze the tabs - apparently they were able to remove the clips after installation .,,
    Half a million miles, and I ain't dead yet.
    See my album at https://www.spyderlovers.com/forums/...p?albumid=5190
  2. #327
    Mar 2021
    Michigan
    Got bored and went with the "angry bird" look ...
  3. #328
    Active Member EchoVictor's Avatar
    Aug 2021
    Milford, MI
    Added the adventure windshield.
    Later,
    EV
    2022 Ryker Sport, 2006 Buell Ulysses XB12X, 2007 Buell Firebolt XB9R, 2023 KTM 390 Duke
  4. #329
    Very Active Member Tslepebull's Avatar
    Dec 2018
    East Texas
    Just a mundane oil change for mine.
    2019 Ryler Rally , Shock Yellow
  5. #330
    Jan 2021
    Oklahoma City
    Quote Originally Posted by EchoVictor View Post
    Later,
    EV
    I'd be interested in knowing how you like the Adv Windshield after you get a few miles on it. I'm leaning towards the same windshield for mine.
    2021 Spyder RT Limited (Sea-To-Sky)
    2022 Ryker Rally
  6. #331
    Aug 2021
    Milford, MI
    Ryker is mostly my wife's ride, and she's 5'6". She asked me to put it on its highest position, as that allows her to look through the windshield. On the lowest position, she said the top edge was right in the middle of her sight line.
    When I sit on the bike (I'm 6'3"), I find the highest setting puts the edge in the middle of my eyeline, so I'd probably ride with it lowered....
    Will definitely let you know once the weather clears and we can get some miles on it.
    Later,
    EV
  7. #332
    Aug 2020
    Niceville, Florida
    Took a ride out to Wagner Field on Eglin Air Force base property, site of training activities for the W.W. II Doolittle raid on Tokyo - 80 years ago this week.
  8. #333
    Aug 2019
    AZ
    Last weekend I installed new 3D LED headlamps from Slingmods. I have only done a little night riding because I was not very impressed with the view the OEM headlights provide. I got instructions from the video on the Slingmods site, and also a couple of Youtube videos. I decided to make it easier and just completely remove the headlight assemblies, since it's only 3 additional screws. It made a nice improvement. Here are a couple of photos of the headlights shining on my garage door, first with the OEMs, second with the new 3Ds:
  9. #334
    Active Member ziggy's Avatar
    Apr 2021
    North Carolina
    Today is Sunday, changed the oil on Saturday. Took longer than expected first time and all.
  10. #335
    Aug 2021
    Netherlands
    Had my 1st group ride the other day .
    And today some TLC - ie putting some Gopro Sealant on the panels for weather & dirt protection.
    Ryker Rally 2022 - customized into a very special one of a kind touring edition .
    H&R swaybar + end links - F4 16" windshield - warning lights - scuff plate - jockey shifter - Commander floorboards - - Big Eye mirrors - BLR overflow - Spyderextras driver backrest - custom build racks - MoskoMoto backcountry panniers & Givi topcase
  11. #336
    Apr 2021
    North Carolina
    Well, I started this on Sunday finished Monday.
  12. #337
    Jan 2009
    austria
    time for a sunday ride - 24 T miles - still runs perfect !!
    https://www.youtube.com/watch?v=MYz0hvmCBNs
  13. #338
    Very Active Member Quickdraw's Avatar
    May 2021
    Upstate NY State
    Finally installed the BajaRon sway bar yesterday. Did it without removing the front end. It wasn't too bad. Just takes time is all. Haven't tested it though. It's the wife's bike and it's decked out in hot pink.
    2021 RT Base - Petrol Blue
  14. #339
    Active Member Beanz1's Avatar
    Aug 2021
    Louisville,KY.
    I gave my Ryker Rally a good washing today, and sprayed it with Mother's Back to Black.
    Last edited by Peter Aawen; 06-07-2022 at 09:24 PM. Reason: ...y,a... - ...y, a... ;-)
    U.S.Marine Corps
    Vietnam-Veteran 68/69
  15. #340
    Feb 2021
    Gulf Coast
    I didn't realize how close I was to the truck turning into the garage. I ran the Shad hard saddlebag up against my truck, crapping it all up, plus rubbing off the logo, AND I scratched my truck bumper up. So, that's what I did to my Ryker today.
    -2021 Ryker 900
  16. #341
    Sep 2019
    illinois
    I had some 5mm thick "radiant barrier" insulation left over from doing the shed. So a cut out out a piece and put it up under the saddle. Not directly under the cushion, but wedged up in the framing underneath. Now if it ever warms up around here in N Illinois, I'll test it out.
  17. #342
    May 2021
    Upstate NY State
    With both the sway bar upgrade, and moving the front shocks to the #4 line, she handles much better. Well worth the investment.
    Also added more tufskin decals to her ride. I'll upload some pics soon.
  18. #343
    Very Active Member Markubis's Avatar
    Jan 2018
    NH
    Today I added the RFY 400mm front shocks that a lot of people have been getting. I noticed a HUGE improvement over the stock Rally front shocks. Much more responsive maneuvering and the bike appears to be less twitchy on the highway.
    I got the set that comes with the 10mm bushing option for $89.99 on Amazon.
    Later this afternoon I checked the air pressure in each shock and found that one was at 15 psi and the other at 30 psi so I balanced them out at around 15 to 18 psi. I like that I have the option to not only play with air pressure, but the set also came with shock spanner wrenches for adjusting the spring rate. Very cool.
    One thing I did notice while installing was the lower bushing is not as long as the oem bushing so the lower end of the spring could be allowed to move back and forth on its mounting bolt. I fixed this by buying some nylon washers at the hardware store and filling the gaps.
  19. #344
    Sep 2019
    illinois
    Today I went for about a 60 mile ride. Then decided to change the engine oil (4030 miles old) Odometer at 12,585 miles, CVT warning came on at 12,528 miles. So I changed the belt also. What a way to spend the 4th! But I got 'er done.
  20. #345
    May 2022
    CA
    Over the past 4 weeks I have upgraded my 2020 900 Ryker with a lot of stuff but the most enjoyable so far is the Pedal Commander. Got it when Slingmods had it on sale a couple of weeks ago. Setting is on Sport +3. Man the response time is awesome. Instantaneous. Still working on perfecting my wrist movement.
  21. #346
    Aug 2021
    Louisville,KY.
    I call her Boomer, I had to put the ole girl in the Hospital today for a fuel pump, I think? They are going to run a disgnostic test to see what the real problem is that's keeping it from starting. That's what I did to my Ryker Rally today.
    Last edited by Peter Aawen; 07-07-2022 at 08:17 PM. Reason: Caps & Fixed attach display
    U.S.Marine Corps
  22. #347
    May 2021
    Upstate NY State
    As promised, here's some pics of the wife's bike.
  23. #348
    Aug 2021
    Louisville,KY.
    I've been adding Mods to my Ryker Rally, aka Boomer. I got it back from the shop at the end of July. Here's a look at it now. I've still got to work on the ties next.
    Last edited by Peter Aawen; 08-25-2022 at 11:30 PM. Reason: Fixed ' 's & attach display
    U.S.Marine Corps
  24. #349
    Aug 2021
    Louisville,KY.
    I made T2 series LED Headlight conversion kit add today to my 2021 Ryker Rally.
    Last edited by Peter Aawen; 08-27-2022 at 09:52 PM. Reason: concersion - conversion ;-)
    U.S.Marine Corps
  25. #350
    Aug 2021
    Louisville,KY.
    U.S.Marine Corps
