Results 1 to 24 of 24
    Jul 2021
    FL
    Default Anyone experimented with Windshield extensions?
    I wonder if any of you have experimented with windshield extensions.
    I don't know what else to do; my F3 came with the Blue Ridge screen, which in my case provided no solution to helmet buffeting.
    Soon enough I installed a 7Jurock windshield, 27", the buffeting diminished somewhat but it is still annoying at anything over 60/65 mph, at 75/80 I get blurred vision. I can deal with the noise but blurred vision is another matter altogether. Leaning forward a bit and lowering my head 3/4" makes everything quiet and smooth but it's very uncomfortable.
    I use a good quality, good fitting full face helmet and as I sit on the F3, I'm looking 4/5 in" above the top of the windshield. That's how I want it, I don't want to look through it.
    I am not a fan of the looks of an extension, but would not care it it helped a good amount. This is driving me nuts, I've been riding for years and never experienced buffeting of this magnitude, simply no fun.
    Granted, all my previous rides were sport bikes, those speeds or higher were never an issue but I know... different riding position.
    Any help, suggestions are greatly appreciated.
    Thank you.
    Last edited by Peter Aawen; 09-05-2022 at 05:18 PM. Reason: Expanded Title to briefly ask the question ;-)
    Oct 2015
    Lynden, WA
    Following this post.
    I have tried 7Jurock (17") windshield and CalSci (12.5") both sized to
    be 2" below my nose. Heavy buffeting starts a 60 mph.
    Still looking for improvement.
    David C
    2016 F3T
    Battery tender cable
    Rear IPS Pack Rack
    Mar 2019
    Fla/NJ
    i use a Puig extension. Adjustable angle works for me.
    Feb 2022
    New Zealand
    Been riding legally since 1979 and had a bunch of rides. Tried all manner of screens and screen extensions. Come to the conclusion that looking over the screen = some wind / buffeting. Dont want the wind and dont want to look through well im not sure thats possible. I came off a Goldwing with a 3XL F4 screen. Used it for over a decade. Had some stone chips, otherwise clear and scratch free. First thing I sorted on my new to me F3 was the wind. I fitted up a 3XL F4 screen with the winglets
    Works great at any speed. FWIW im a 3XL Smurf at 6'2".
    Faribault, MN
    I bought the Adjustable Clip-On Windshield Extension Spoiler Windscreen Deflector Motorcycle off Ebay, has made both mine and my wife's spyder rides much better. And it was inexpensive enough that if it didn't help, no great loss. Have ridden through Rain at 70mph and ridden at speeds far above posted limits with no problem, this picture is at maximum height for cleaning purposes, I never ride with it that high, though believe I could if needed.
    Safe Rides,
    David and Sharon Goebel
    Both Retired USAF Veterans
    IBA 70020
    Mar 2015
    forrest above Reno, Nv
    A vented screen works for me and my passenger at any speed. The wind screen creates a low-pressure area where you are. A vent moves this low-pressure area and its associated buffeting up and back. There are adjustable vents for sale on e bay. You do have to cut the opening, but I did not find it difficult at all.
    Lew L
    2014 RTS , Circuit Yellow
    Aug 2013
    SF Bay Area
    I have an MRA X-Creen extension. Really helps keep the winds off and redirects wind to the rider in summer. https://www.revzilla.com/motorcycle/...?sku_id=967500
    2021 F3 Ltd , Magna Red
    Feb 2020
    CT and ME
    Ditto with the MRA X-Creen. 2 years and over 23,000 miles now still going strong. Cured the buffeting with the Blue Ridge windshield and now I'm using it with a Madstad windshield.
    My Mods:
    Elka Stage 5 rear shock with spring preload adjust
    Monster Stage 2 ECU
    Pedal Commander
    RLS cat delete
    Baja Ron sway bar
    Baker Air Wings upper and lower
    Viking saddle bags
    Third pegs
    Vredestein tires front and rear
    Mad Stad windshield
    X-creen windshield deflector
    Front and rear drive cam
    Garmin Zumo XT
    Heated gear wiring
    Lamonster LED headlights
    Lamonster LED foglights
    Lamonster frame mount cupholder
    BRP heated handgrips
    Lamonster drivers backrest
    BRP passenger backrest
    Lidlock handlebar end helmet locks
    Barkbusters Storm handguards
    2020 F3S-SS , Titanium/Black
    Jul 2021
    FL
    Thanks everyone, the pictures were very helpful.
    I've decided to get an extension from eBay or Amazon as DGoebel did. I hope it'll perform as well for me. If it doesn't, I'll vent the screen, one of these solutions better work because I don't want to give up on the F3.
    I'll post soon with results.
    Active Member GRHorst's Avatar
    Mar 2022
    PA
    Look forward to your results.
    I am 6'3" so I added one (sorry about the low quality picture inside my garage) with low expectations. My intent was a cheap (~$20) way to determine if a higher windshield would help. But it far exceeded my expectations and I am quite pleased with the results.
    _________________________________
    GR Horst - Reading, Pennsylvania, U.S.A.
    Jul 2021
    FL
    Quote Originally Posted by GRHorst View Post
    I'm 6'1" and installed one just like yours, what a difference: rode for about 60 miles at up to 90 mph( I know, sorry...), after some minor tweaking with the height and angle, it eliminated all the buffeting. I'm still not a fan of how it looks, but it's function over form and I'll get used to it. For anyone on the fence about adding an extension, go for it; it's not a lot of money, ~$30 and it can adjusted or removed in seconds.
    Mar 2019
    Ruidoso Downs, New Mexico
    I added a cheap Amazon extension, works for me.
    Goldfire Universal Motorcycle Windshield Extension.
    Still some buffeting but not near as much and the wind noise is much less.
    2020 F3L; gone but not forgotten are all the good miles!
    Member BigDH's Avatar
    Jul 2020
    MN
    Do you have to look through this? Would this help take the wind off the passenger.
    2021 Spyder F3 Limited
    If you can't fix it with a hammer you have an electrical problem
    Member mtnspdr's Avatar
    Sep 2016
    Colorado
    Jul 2021
    FL
    Quote Originally Posted by BigDH View Post
    I look just the over the top of mine, took a few tries but it's working well. Once in while I find myself looking through it but it's not bad with very little distortion.
    My wife never complained about excessive wind before the extension and hasn't ridden since I installed it, so I can't comment on that situation. I think it's safe to expect that it will be the same or better than before.
    Linden, CA
    Don't mess around just go to the original
    https://www.laminarlip.com
    Jun 2011
    Near Lexington, NC
    JMA57: What year model F3 do you have?
    Two Wheelers from 1963-2011
    Three Wheelers:
    2011 RT(Red)
    2014 RT(white)
    2016 F3T(red)
    2022 RT current ride(silver)
    __________________
    2016 Slingshot
    2018 Vanderhall
    2019 Slingshot
    Danbury Connecticut
    I'm with Dave on this one (and a bunch of other things as well).
    I have the RT limited, so the windshield is adjustable, but I remember adding a Laminar Lip to my ST1100, and it worked wonders
    I could still see over the shield and the wind was pushed over my head.
    Except for a bad knee, I miss that bike.
    IBA #47122
    2020 RT Limited Asphalt Grey
    Aug 2019
    Stoughton, WI
    I bought a $18 dark gray extension on ebay for my 14" Madstad. It's working good. Had it up to 80mph with no issues.
    2022 RT Sea To Sky
    Jul 2021
    FL
    2017 F3S manual.
    Active Member SkipH's Avatar
    Nov 2021
    Nevada
    I installed the Laminar Lip on my LTR and also some side deflectors on a show chrome windshield that really reduced the turbulence. I can look over and not have my head shaken off. The side deflectors need to be 4 inches longer and 1 inch wider.
    Adj removable backrest, KOTT radiator screens
    Double horn (118db), Lamonster mirror fix
    FOBO 2, Trunk rack, Afterburnerz taillights
    Drinks2go cup holder, replaced the seat strut
    Garmin Drive Smart 71 GPS, Large brake pedal
    White pulley, Pedal Commander, Trunk Strut
    Laminar Lip wind deflector, side windshield wind deflectors
    Home made belt guard, Shorty antenna
    Show chrome wide windshield, Belt dampener
    Top cuffs and Mirrors
    7x12 enclosed trailer
    2021 RTL Dark Chalk Metallic
    Skip H.
    Aug 2016
    Maine
    Active Member Woodswoman's Avatar
    Nov 2020
    Upstate NY
    I had a Laminar Lip in my garage from a prior bike, but unfortunately it wouldn't fit my Gustaffson, which has too much curvature.
    So I picked up a Puig extender from Amazon (open box at a fraction of the full price). It's small but mighty! If I had a passenger I might need a wider extender but this little gizmo does the job for me, and I can still see over the shield.
    2016 Spyder F3-S
    Linden, CA
    I have bad knees and I am OLD but I sure wish I had never sold my ST1100
