Results 1 to 2 of 2
    Very Active Member oldgoat's Avatar
    DDO, Montreal Island
    Default Need hints for installing throttle body
    Did a valve clearance check. 1st in 14yrs and 30,000 miles. All was ok
    Now having great difficulty in refitting the throttle body into the 2 rubber inlet sleeves. They seem flexible enough.
    All hints will be gratefully received.
    Done it.
    Opened the 2 clamps to their max. Applied a little grease to lips of the throttle body mouths and used a fine screwdriver to guide the rear one in. They just popped in then.
    2008 GS SM5, Full Moon Silver
    2007 Piaggio MP3 - 250cc
    Sep 2016
    Chillicothe, Oh.
    Some lubrication on the rubber? I have used a dab of liquid soap when mounting carbs on multi cylinder bikes. Dries and doesn't harm anything.
    2015 RT , Black
