Results 26 to 50 of 74
  1. #26
    Nov 2016
    Colorado Springs
    Quote Originally Posted by stmike 1800 View Post
    He had in his hand the only one to fail , yet i see many on this forum with problems .
    Most people have the red dust and a loose sprocket. It's a whole different thing when the sprocket completely fails and leaves you stranded without any drive. I'm the only one my mechanic had seen with a complete failure.
  2. #27
    Mar 2017
    Salisbury,NC
    the ONLY one at THAT dealership that HE replaced!!
  3. #28
    PA
    Here’s a question. I watched the video and he said the inner spline is deeper than the original. We’re also adding a washer to the inside. So basically we’re pushing that sprocket out 1/8 to 3/16 from factory setting correct? Isn’t everyone rear wheel going to have to be realigned since the belt will now really be tracked against the inside of the new sprocket? It’s going to squeak and squeal like a pig after 1000 miles if not. Maybe he meant the outside of the inner spline but still it will be min of 1/8 out now. Correct?
  4. #29
    Sep 2018
    Australia
    Quote Originally Posted by Wmoater View Post
    They've machined the thickness of the washer off the inner pulley surface so no everything will still line up ok. Less actual spline surface area now than previous.
  5. #30
    Harrington, Australia
    That wasn’t what I remembered from the video, Wmoater, so I just double checked and Smoaks says at 9:50 that the new spline is 35mm while the old is 40mm. That means the new sprocket, with the addition of the washer will be about the same as the old sprocket, not wider. Unless I have completely misunderstood what he is saying, which is quite possible in my dotage
    HeliBars Handlebars
    Kenda Kanine rear.
  6. #31
    Quote Originally Posted by ClayJ View Post
    Quote Originally Posted by Woodaddict View Post
    As other's have noted, not all sprocket issues are initially identified or present as complete & terminal failures to proceed... And another thing to bear in mind is that this Smoak fella is a company man thru & thru
    IIRC, as far as he was concerned, the Heat Issues with the 2013's were a figment of some people's imagination or deliberate attempts to denigrate BRP & the fires that were proven to have occurred were purely coincidental, until the recall for Heat issues came out! And again, IIRC, the DESS issues were a figment of some people's imagination or deliberate attempts to denigrate BRP & the failures that were proven to have occurred were purely coincidental, until the Service Bulletins & Warranty Replacements started happening! And from what I can remember of those vids of his I've watched, these sprocket failures are a figment o..... Hmmm, anyone else starting to detect a trend here?!?
    There's also been other things where he either completely ignored or otherwise refuted some clearly identified concerns early on, only to back-track or gloss over his earlier stance later on when the official recognition &/or fix came out! But in those of his vids I've watched, I reckon he's always been toe-ing the company line - whether that's cos he's just one of those types, or cos he's been warned off doing anything else, Who Knows?! Your guess is as good as mine on that one & AFAICan See, neither nor any guess we might come up with can be anything much more than a WAG or pure supposition!
    Still, more power to him & his Missus for putting in the effort of filming, editing, and putting all of the stuff they do out there! You can't deny that they share a lot of themselves, even some potentially embarrasing stuff, and there's a lot of potentially helpful info to be found in his vids, IF you have the patience to sit & sift thru all the other stuff to find & identify the good bits of valuable info - only as always, if it's not supported &/or verified by other trusted sources, it's probably best to treat it as you would (or at least should! ) treat anything else you've gleaned from a Social Media site that's basically there for entertainment purposes!
    So sure, watch the vids if that sorta stuff is what floats your goat, you'll probably find some helpful info in them - just don't necessarily drink any of & certainly not ALL the Kool-Aid; cos the stuff he serves up is very much flavoured by the 'BRP Official Corporate stance of the moment' and we all know that is rarely the full story! Or do we?!?
  7. #32
    Nov 2013
    Central Texas
    Well, there are some folks out there that have their heads so far up BRP's *** (no names) that they can see the sun rise in the West. The BRP corporate stance has always been deny, deny, deny, deflect, deflect, deflect, stall, stall, stall. Anybody ever wondered how many owners of 2013 RT's were offered payouts of some sort, and sometime years down the line for folks that held on to their 2013's for whatever reason, on the condition that they keep their mouths shut and not disclose ANYTHING about any sort of agreement or settlement? That includes posting on social media, Emails, word of mouth, or any disclosure of any kind under the signed NDA that BRP required in order to reach an agreement and get some sort monetary relief which, for the most part, was paltry. Sad, but true. I went through all of the NHTSA paperwork at the time and counted up the number of 2013 fires, and came up with 40+instances (don't recall the exact number, I got rid of all that paperwork when I got rid of my 2013 RTL). But is was way higher than what BRP alluded to at the time. Lord help me, I love my Spyder, but I really dislike BRP. My current one will be my last.
  8. #33
    Feb 2012
    Spring City,Utah
    This recall BRP is doing is no different than BMW 4 years ago. It just took longer to get enacted. BMW had to recall the entire fleet of certain models due to the direct shaft drive problem. I have a buddy who was really nervous. They literally took the entire bike apart to do the recall. BRP is minimal assembly. The BMW was all around the direct shaft system. So direct or belt both have their problems. I believe in lat 80’s, Honda had to do it with their shadow and nighthawk, or atleast I remember my stator and drive system was recalled back then.
    And Yamaha had to do it for the transmission and shaft drive on their early Ventures. The shaft drive is expensive and heavy and a power robber.
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
  9. #34
    INDIANA, USA
    Default Thanksgiving
    .....Seems like the older one gets the faster one forgets.
    Stay Healthy. ....
    ENJOY YOUR LIFE WITH A SPYDER
  10. #35
    Mar 2018
    Ontario ,way up north
    Default sprocket
    I guess i should have have chose my words better. Shawn only saw one failed, yet there have been more on this forum.
    2018 RTL , dark blue
  11. #36
    PA
    You’re right. I was not totally focused just casually listening. I thought I heard vise versa when he had the tape measure out.
  12. #37
    SoFlo
    Can Am once again gets an F in the engineering class. The solution of Loctite to glue the pulley on the shaft can work. Granted, the engineers never considered removal. At a minimum all the pulleys should have been drilled and tapped to allow a simple common bird foot puller to draw the pulley off the shaft with ease when needed.
    The shim, I suspect the engineers are placing bets that the pulley retaining bolt bottomed before reaching proper force into the assembly to prevent movement. Seems as the pulley splines wear, obviously the pulleys end mounting faces will wear against the gearbox shaft. That is why the pulleys that failed have a worn ridge where it mates to the step in the gearbox shaft. That shim washer probably has a larger OD than the shafts step, and will ensure complete tightness, even if the shaft has worn.
    The Loctite is the savior. Had they correctly redesigned the installation, utilizing two cones with split cuts to clamp the shaft, fretting would have been prevented, but typical Millenial Engineers...BTW, split cone spline drive setups have proven themselves reliable for over a century. Why even consider proven technology.
  13. #38
    Oct 2021
    Wichita, KS
    I personally think Shawn Smoak knows his stuff. He is a very knowledgeable mechanic. Spyder or otherwise. If you don't like the style of his videos, then don't watch them. He spends a lot of time recording and editing them so we all have what information he gives us. I just don't understand all the Smoak haters out there.
    As far as this recall is concerned, I believe all of you have concrete information on how your Spyder's will be fixed. I haven't seen any other information on the internet that explains it (at least in a video format). You owe that to him if nothing else.
    Peter Pan has struck again!
  14. #39
    Sep 2018
    Australia
    So do you think the new pulleys are still the same from a metallergical point of view and they've just painted them grey and skimmed a chunk off them to allow for the washer? Bloke should skim a few thou off the bolt end just to be sure too, either that or a dab of weld should secure the mongrel on there.
    Can't believe it's taken so long to get such a lame repair underway.
  15. #40
    SoFlo
    Quote Originally Posted by Cobwebs View Post
    Guess that is a question best answered by Shawn Smoak.
  16. #41
    Jun 2015
    Ritzville, Wa
    Quote Originally Posted by FrogmanDave View Post
    Greg Kamer
    USAF, 20 years, retired
    2018 Can Am Spyder RT-Limited
  17. #42
    Sep 2018
    Australia
    Leave it with me we'll see how corporate he is.He mentions dealer forum so I'm probably below his pay grade but we'll see.
  18. #43
    Aug 2020
    Il
    I like Shawn videos and think he is a competent Spyder tech, BUT I also know he tows the BRP line. Alot of Youtubers are like that. They want to curry favor with Corporate (BRP included) for ambassadorships/sponsorships, etc. so they aren't as critical of the company or product. I don't see it as hate but an observation/critique.
    21 Spyder base F3
  19. #44
    SoFlo
    Not sure what your intentions are, but whatever they may be, that is between you and Shawn.
  20. #45
    SoFlo
    If every Can Am Spyder dealership in the USA had a tech with the passion for Spyders, and apparent knowledge and skills that Shawn Smoak presents, BRP / Can Am would have an incredible, well supported product.
  21. #46
    Nov 2013
    Central Texas
    Add to that the necessary training for the tech (expensive), which I think BRP should pay for, and not the dealer. It would be in the best interests of BRP to do so, not to mention in ours as well.
  22. #47
    Very Active Member Peacekeeper6's Avatar
    Sep 2019
    Reno, NV
    Quote Originally Posted by Jdr00ejr View Post
    Why do people like this guy's videos so much? I find it painful to sit through his videos for the few scraps of knowledge he might toss in somewhere. He has a ton of subscribers and what seems like a cult like following - so clearly people love him/his videos - so am I the only one who doesn't get it or actually get annoyed by them?
    You DO know that he DOESN'T have to make those informative DIY videos, right ??
    He could just say, "F*ck it. I'm just gonna let those Spyder owners bring their Spyders to ME for easy maintenance and repair, and they'll be out a few bucks. Easy money for ME"
    Just skip the fluff and watch the meat of the video.
    Shees ....
    SIGNATURE PIC CURRENTLY UNDER CONSTRUCTION
    2016 Toyota Sienna SE - hers
    2002 BMW 325i - his
    1994 Chevrolet Silverado K1500 Sportside Z71 - whoevers vehicle is in the shop
    2009 Harley-Davidson Sportster XL883 Low (Vivid Black) - his
    2018 Can-Am Spyder RT Limited - hers
    2007 Harley-Davidson Sportster XL883 Low (Pearl White) - hers (SOLD 02/29/20)
    2011 Tao Tao 50 - whoevers bike is in the shop
    2007 Reinell 186 FNS - the dog's
    1995 Fleetwood Flair 27R - EVERYBODY'S !
  23. #48
    Aug 2020
    Il
    Quote Originally Posted by Peacekeeper6 View Post
    It's a lucrative revenue stream for those with tons of followers.
    21 Spyder base F3
  24. #49
    Clinton, MS
    Shees ....
    Have you noticed that most of his vids are not "how to" do something. Just info about something. I'm sure the dealership looks at is as an advertisement. BRP looks at it the same way. Have you noticed that he goes out of his way to mention that the BRP oil is the best. How crapenda tires are the only tire to run on a Spyder. etc, etc, etc. I think he is paid well for his services. A new demo Spyder to ride every year. The revenue he makes from YouTube.
    I like his vids, I subscribe to his vids, some I watch and some I don't. I'm very glad there is someone out there doing what he is doing.
    2019 RTL Phoenix Orange
  25. #50
    Sep 2018
    Australia
    To get an answer to the question for everyones benefit.
