Results 1 to 13 of 13
    Jul 2021
    IL
    Default Recommendation for cover that is reasonable in cost
    My Spyder is now put away for the winter in my garage. To keep it from being overly dusty come Spring, I would like to find a cover that will completely cover the RT, but I really do not want to spend a fortune. Right now I'm using the cover that I previously used for my Goldwing, but it certainly does not cover the whole bike.
    2021 Spyder RT
    2023 Royal Enfield Hunter 350
    Retired U.S. Army
    Life Member, NRA
    2021 RT , Petrol (blue)
    Active Member Tourer's Avatar
    Jul 2022
    North Carolina
    I use a fitted King sized bed sheet. If you want something fancy, how about a floral print.
    2015 F3S SE6
    Very Active Member jnt's Avatar
    May 2008
    Minneapolis
    Try www.bigbikeparts.com I know their 1/2 cover works with 20-22 Spyder; not sure about the full cover. Give them a try.
    08 RS/SM5 (Hers) (sold)
    15 RT-S (Mine)
    2015 RT-S , Metallic Black
    Sep 2016
    Chillicothe, Oh.
    Quote Originally Posted by Tourer View Post
    This is the way to go for indoor storage. Lightweight, breathable, inexpensive, and keeps dust off just fine.
    2015 RT , Black
    Jul 2021
    IL
    I found something that I think will work better than a sheet, which would be subject to blowing off when it is windy and the garage door is open. Its from a company called CarCoversFactory.com, and is intended for indoors for my RT. $65 with shipping included. Once it arrives and I put it on the RT I will post again.
    2021 Spyder RT
    Retired U.S. Army
    Life Member, NRA
    Dec 2020
    Hartwell, Ga
    Quote Originally Posted by jnt View Post
    I have their full cover for the 2020-2022 Spyder and it fits like a glove.
    May 2017
    Mesa, Arid-Zone-A
    Another vote for bed sheet. Just make sure the sheet you choose has the approval of the bed sheet warden..... Jim
    Semper Fi
    Northern Kalifornia
    The cover for my spyder is a 10X20 prefab barn. Fits perfectly with lots of extra room.
    Jul 2021
    IL
    I like a bike to be covered even when stored in a garage. Most years I just pull off the cover when Spring arrives, disconnect the Battery Tender and check the tire pressures then ride off on a relatively clean and shiny bike. Plus, it makes walking past the covered bike a little easier to keep out of mind when I know its still the dead of winter and I'm not going to be able to ride.
    2021 Spyder RT
    Retired U.S. Army
    Life Member, NRA
    Jul 2021
    IL
    The cover from the Carcoverfactory.com arrived and I put it over my RT. Its certainly large enough, easily covering the entire RT. It is not a tightly fitted cover, but that is OK and makes it easier to fit over the bike. It seems to be of good quality material and I am pleased with it, and consider it worth the $65 that it cost.
    2021 Spyder RT
    Retired U.S. Army
    Life Member, NRA
    Jan 2015
    southern WI
    Try an UltraGard cover. We have their half covers, but no full covers. The half cover doesn't keep everything off, but it does what it needs to for indoor coverage. And yes indeed, the bedsheet works just fine too. Been there n done that.
    2016 RTS , Pearl White
    Aug 2008
    MA & NH
    If you're going to cover use something that will breathe and is easy to check under (mice). I never cover our Spyder in the shed in the off season.
    Mar 2021
    Haven, Ks
    I agree with the leave it uncovered line of thought. Mice and cats(my wife is a cat lover) love a covered place to covey up under. If the bike is in a garage or otherwise out of the weather it is easier to hose off the dust than repair cat and mouse damage.
    Bartender
    2022 Spyder Sea to Sky
