Results 1 to 5 of 5
    Sep 2015
    Kansas city mo
    Default Charging a Garmin Drive Smart from USB
    Considering a Garmin Drive Smart model and would like to be able to run it off the USB port on the Ryker.
    Is this kosher? If not I'll stick with my phone as I'm not interested in doing any wiring.
    May 2014
    Benson, NY
    I run my drivesmart directly from a usb outlet that I installed on my RT. Has worked fine for a couple years now.
    2015 RTS Special Series
    Russell Day Long seat
    F4 Customs windshield
    Sena 20s
    Sep 2015
    Kansas city mo
    I wanted to be sure the Garmin wouldn't be using more juice than the USB port on the bike could supply.
    Aug 2013
    SF Bay Area
    The phone is a much better GPS than a Garmin. You can install TomTom, Genius Maps or Sygic for way less $$$.
    2021 F3 Ltd , Magna Red
    Dec 2022
    Florida - Wimauma
    Tested my Garmin Zumo XT with the SD ports. Worked fine. They ran both my phone and the Zumo at the same time.
    Later hot-wired the mount so not using it because of the waterproof issue with an open charge port using the SD cord.
