Page 2 of 2 FirstFirst 12
Results 26 to 29 of 29
  1. #26
    Quote Originally Posted by FrogmanDave View Post
    I disagree with the premise of the thread title 'Engineering Idiocy'.
    'Goof ups' would be a better term. Engineers do make goofs at times, but that doesn't make them idiotic.
  2. #27
    Jan 2015
    southern WI
    Quote Originally Posted by oldguyinTX View Post
    I got an Email from Can-Am recently that had a short video about doing an oil change on newer Spyders, so I thought I would watch it. Pretty straightforward about draining the engine oil, and then the transmission oil. THEN, it came to replacing the oil filter, and I was dumbfounded to see that you have to detach the brake fluid reservoir, pull it out, then secure it with a bungee cord to the right floorboard in order to get the old filter out and install a new one. Really? Whoever thought that one up gets the Darwin Award, yet another in a long line of Darwins that BRP has been awarded over the years.
    It sure beats taking a friggin mirror off to change the oil.....moving the reservoir to the side is a piece of cake.....seems dumb, and it is, but it's much better than the previous cluster #$%^ on our 2016RT
    2016 RTS , Pearl White
  3. #28
    Nov 2016
    Upstate NY
    I changed the filter on my 2021 RT and didnt have to remove the brake reservoir to do it. Im sure it makes it easier, but wasnt necessary.
  4. #29
    May 2017
    Mesa, Arid-Zone-A
    Quote Originally Posted by Cirhere View Post
    I worked in auto manufacturing for over 30 yrs and a lot of things are designed so that you will bring your Auto in to the service dept so you will be charged
    I had a DRL burn out on my Buick Enclave. The Owners Manual said to go to a dealership for replacement! Not an owner replaceable part. I looked on line for procedure and did BOTH sides myself in about 15 minutes. YouTube is our friend.....
    Semper Fi
