Front Sprocket Correction at Dealership
I do not remember reading this, so if this was discussed prior I apologize for the duplication. My spyder went in for its yearly service - last year I had the sprocket replaced just prior to the recall. The dealer told me the replacement doen last year would be redone and replaced this servicing. I was told the sprocket was reworked and improved from what was done last year. Anyone else hear this?
Thanks,
Jim
that does sound a bit strange??? I never heard a word that they redid the sprocket. wonder when that was done if in fact it was??? Just had my 2018 RT Limited into my dealership last week and after waiting 6 months for the sprocket part the tech found that my sprocket was just fine and did not need replacement... Maybe I did not have enough miles (9,000) to create the problem. anyway, the tech did show me I needed tires so now thinking of trading for a 2023????? Yes, I know new tires are less costly than a trade but what the heck, we only go around once in this world... :-)
BIG F
There was a massive recall on the drive sprocket. You should have gotten something from BRP telling you this.
You probably had the temporary fix done last year. The final sprocket has been released to address this.
Call your dealer and make sure that they have one as it most likely will need to be ordered!
There are several post's covering this, use the search function on the top right of the forum page.
BIG F
My understanding of the New Repair sprocket is the metallurgy may have changed ..... I know the New sprocket now has a washer that the old one didn't have ..... Mike
BIG F
If your spyder was part of the recall then "You Do Need The New Sprocket". It was released toward the end of last year. Yours probably passed the inspection so no sprocket was replaced at the time but does ultimately need it now that the "Final" fix has been issued.
Not sure where you are in Pa but at my dealer the “new” sprockets ( sort of grey/greenish color) has not arrived yet. They were suppose to be in end of February first of March but was told they would be in starting the first week of April now. My dealer is taking service spots so they must be in or confirmed coming in. We’ve had off/on snow, rain, slush all season so no one is riding yet here. The dealer about 1 hour in Ohio can get them but they need ordered which takes a week or so. Not sure what the difference is between the 2 dealers why one has to order and the other has them on order. Mine goes in April 17th for the new sprocket. Was told it will take 2 days before I can pick up which is what the previous posts were saying to allow the lock tire to set. I’ll trailer it if I have to depending on the salt and brine.
And mine didn’t needed replaced last year either Big F but K80shooter is correct the new sprocket is to replace the older version no matter what. So you should have had it replaced. The dealer is required to replace the old style with new one as part of the recall.
BIG F
aannnnddddd, new tires????.........new bike???? The choice is clear!!!!
Tri-Axis Chrome Handlebars
Sena SM10 BT Dongle
Double USB Port/Volt meter
LaMonster Magic Mirrors
BajaRon Swaybar
HALO Skid Plate
Shorty Antenna
LaMonster Cat Delete
Akrapovic Muffler
FOBO2 TPMS
Rear Trunk Rack
Bruce Erickson
Chilliwack, BC
Canada
2014 RTS-SE6 - Cognac
That could be true. My 2016 F3T had the sprocket replaced with the white sprocket in early 2022 or late 2021. But in late 2022 a new replacement came through and the white one was replaced.
Which years/models does this sprocket recall affect? I've got to bring my 2021 Spyder RTL in for a firmware flash; maybe kill two birds with one stone?
Bill McGrath
1962 Matchless G80 500cc Single
1967 Norton Atlas 750 with Dunstall kit
1972 Honda CB450
1981 Honda XL500R
1983 Honda 750 Sabre
1987 Honda 1100 Sabre
2002 BMW K1200LT
2021 Can-Am Spyder RT Limited with BR anti-sway bar and Garmin Zumo XT
1969 Cessna 182 w/STOL kit, fully IFR
2020 and newer are not part of this recall.
2021 Spyder RT Limited (Sea-To-Sky)
2022 Ryker Rally
JimH, your BS meter with this dealer should be in the flaming red zone. If they don't know that there was a front sprocket recall, something is SERIOUSLY wrong. And I agree with Mike about the metallurgy of the new sprocket.
I have the utmost confidence in these guys, they fixed a couple of things another dealer could not. The first replacement was last year prior to the announced recall - several weeks before (red dust and ready to fail). It was replaced with the old faulty model - for yearly service since this was the faulty model, the updated version got put in. They understand Kenda tires are crap and listen to the customer.
Jim
I just called my dealer to schedule an oil change for my 2017 and had hoped the front sprocket would also be replaced. According to the service department they still haven't received any of the new sprockets. I know BRP says even in the recall notice that there are supply chain issues but this is getting a little frustrating having to wait this long. So for now I suppose the only recall option is the "interim repair procedure".
I know some people have been able to get the new sprocket so I was a little shocked that my dealer has yet to see a single one arrive at their shop. How many of you are still waiting on the part being available?
2017 Spyder RT Limited - Champagne Metallic Chrome
- Wolo Bad Boy Horn, SPYDERPOPS Next Gen LED Bumpskid, SPYDERPOPS Double Vision Daytime Running Lights
2021 Spyder RT Limited - Deep Marsala Metallic Dark
- Replaced 2021 Stock Handlebars with F3 Stock Handlebars, BRP Adjustable Driver Backrest, Wolo Bad Boy Horn, SPYDERPOPS Double Vision Daytime Running Lights, SPYDERPOPS ""BRAKER BARS" Brake/Run Lights
I have an appointment in April for a full service and sprocket replacement, my dealer got an order of them in about 3 weeks ago. If your shop said they put the new sprocket in last year I would suspect that they put in the temporary one and would clear it with the shop.
USMC RETIRED
2022 F3T Glacier Blue Metallic
I very strongly agree. The final repair was not available till the end of 2022. Theres no way it has the "FINAL" sprocket on it unless it was done at the end of the year.
Honestly I believe it has to do with the region and weather areas. I was told last fall that my dealer wouldn’t get them till March and not to even think about scheduling till April. While others were getting them last fall. I think BRP sent them based on weather areas. For me and probably even you in SD you can’t even start riding till late March to April. So I can see their logic, send the ones to the areas that can install now and if they don’t and the stock runs out in that time, to bad their fault in that area they had the chance. Rotate now to you my area now because it’s getting close to our starting time. therefore they are also not getting behind in stocking and eventually evenly distributing them to all the areas. I might be completely wrong but normally we still have a month left of snow still here. Whereas mid ohio, southern PA, mid and eastern PA are already in the 60’s and riding. I might be wrong but I was told the same thing happened in 2013 with the last major recall. They did it in regions and areas based on usage.
As a side note it’s good you aren’t the first for the dealer. Even with the training, videos etc…….The best tech in the world still learns from the first and second install even if they are the best. In my opinion the old pulley was holding together so even if I have to wait till May or even first of June as long as its only sitting for 2 days and the part is available I am still able to ride with the old pulley and feel safe about it. I am scheduled for April 17th but was told that could change if they didn’t arrive. So my dealer will be seeing the first pulleys this week or next. I guessing you will be seeing them in the next couple weeks starting to show in your area too.
Question: Has anyone that is not in the recall tried to buy the new sprocket?
Reason: in - is ;-)
Adj removable backrest, KOTT radiator screens
Double horn (118db), Lamonster mirror fix
FOBO 2, Trunk rack, Afterburnerz taillights
Drinks2go cup holder, replaced the seat strut
Garmin Drive Smart 71 GPS, Large brake pedal
White pulley, Pedal Commander, Trunk Strut
Laminar Lip wind deflector, side windshield wind deflectors
Home made belt guard, Shorty antenna
Show chrome wide windshield, Belt dampener
Top cuffs and Mirrors
7x12 enclosed trailer
2021 RTL Dark Chalk Metallic
Skip H.
According to Shawn Smoak, in his YouTube posts, if the dealer is using the proper and required Loctite number there is no need for it to set up. The unit should be rideable immediately.
Are you talking interim sprocket or replacement. If replacement you have the story arse about tit. He specifically warns to use the correct loctite and to follow the manufacturers guidelines or legal liabilities in the event of a malfunction could occur.
Post a link if you have the evidence.
MY RE-POST
THE NEW REPLACEMENT SPROCKET IS SILVER
I have a copy of the Warranty Bulletin #2019-10 rev 1 September29,2022
Required parts, front sprocket kit, (includes washer)219800553 needed 1
listed as screw 250001017 needed 1
use loctite 609 or 603 torque to 111 lbf-ft +-4
No cure time listed.
CHECK THE NUMBERS ON YOUR DEALER PAPERWORK!
Way too much misinformation on this issue since the start of the problem,
We need everyone on the same page in the same book.
T.P.
Originally Posted by T.P.
MY RE-POST
T.P.
The one I saw a couple weeks ago on my friends RT in another state was a very very flat silver more like pewter greenish color. I see pewter green but others might see silver. His new one (recall package) replaced the white one and there was definitely a different color from that one. It is raw metal flat maybe aluminum looking but I don’t consider it silver shine at all. His dealer had a cure time of 24 hours also. Even Lamont was and is doing A 24 rest before putting any hard use for cure time. Might not say cure time, but I have now heard of 3 different dealers or installers doing the 24 hour cure time and none of them are in the same state even.
MY RE-POST
T.P.
The cure time is listed on the Loctite website. Pointless using it if the instructions aren't followed. BRP could shift the blame to dealers if something occured. Shawn Smoak has seen it all happen before and put out the warning to all.
Had mine replaced today at Jim Potts in Woodstock Illinois, Took about 2 hours tech also aligned belt which was out of spec they used loctite #609 shop said it didn't need to sit for 24 hrs but just rode home 12 miles and parked it to let it sit 24hrs anyway. old sprocket didn't show any rust at over 20,000 miles. I put on over 4000 miles since interim check. 2015 RT L
Update from my dealer: They only received 12 new recall kits and all have been installed. They are now required to have the spyder come in, they verify vin number vs recall that it needs the sprocket, sprocket ordered, drive off the lot and the sprocket should be in 2 weeks later. Once the allotment is sent and used, dealers have to call in for replacements after they see and verify the bikes vin. Atleast that is what I was just told from my April 17th drop off. I don’t even have to leave the spyder. It’s a 5 minute in and out deal they said to order then bring it back when its arrived and leave for 24 hours.
Harrington, Australia
HeliBars Handlebars
Kenda Kanine rear.
