Results 1 to 5 of 5
    Nov 2019
    Kansas
    Default Help with a phone mount please - can I simply get a longer bolt?
    So I bought this tackform phone mount for my F3L
    https://www.tackform.com/products/ph...pyder-tackform
    The bolt that came with it is too short. And using the OEM bolt is also too short. But barely.
    I attached two pics of my handlebars. So is it possible to go out and simply get a bolt that is slightly longer than will work with my handlebars?
    I am totally at a loss here.
    Last edited by Peter Aawen; 05-06-2023 at 03:12 PM. Reason: Expanded title to briefly ask the question... I think?? ;-)
    2018 F3 Limited
    Northern Kalifornia
    Call Motorcycle Dave at (209) 887-3283 or take your bolt to Ace Hardware and get a longer one.
    Nov 2013
    Central Texas
    Have you entertained contacting whoever you bought it from and asking them to send you the correct bolt? Might be easier than trying to find the correct one on your own.
    Feb 2017
    As I recall, Lamonster offers a pair of longer bolts as an "accessory" for his handlebar riser. I installed the riser on my wife's Sea to Sky and added the longer bolts because she has a center-mount GPS bracket. It's one source at least if others fail.
    2015 Spyder RT-S (Arion) and 2021 RTL Sea to Sky (charming wife)
    Mar 2019
    Ruidoso Downs, New Mexico
    I just took the original bolt to the hardware store and got one with the correct threads but longer. Mounted a RAM ball there for my GPS.
    2020 F3L; gone but not forgotten are all the good miles!
