Results 1 to 8 of 8
    Feb 2022
    New Zealand
    Default Site slowed down with loading noticed.
    I have noticed over recent days that this site has slowed down with loading.
    Its changed.
    I have checked my modem, rebooted it and done a speed test with data in and out.
    All good and normal.
    So I figure its not my end.
    Just FYI.
    2017 F3 Ltd
    Active Member linguine's Avatar
    Feb 2023
    AZ
    It's the server farms it goes thru before it gets to you. That changes each time you connect. But to/from kiwiland, I'm betting it wouldn't take much of a side trip to give you what you see.
    Ride safe; shiny side up, greasy side down.
    best,
    linguine
    2020 RT Limited , Chalk Gray
    Feb 2022
    New Zealand
    Himm. Didn't think of that.
    I logged into Canada via a vpn and it back to being fast again.
    Edit.
    Logged into Vancouver auto.
    This works well for this site.
    Speed test is
    Similar to Auto NZ
    but the upload to Vancouver is 25% of the Kiwi one.
    Must miss out some middlemen with the downloads.
    Warning , Computer Luddite ( but learning real fast) at large and online.
    2017 F3 Ltd
    Harrington, Australia
    Yes, I have noticed it too over the last few days, Iso. It happens from time to time.
    HeliBars Handlebars
    Kenda Kanine rear.
    Feb 2022
    New Zealand
    I guess we are at the end of the line down here. You blokes and all the others get first dibs.
    Big difference with the VPN change. why. But it works for me.
    2017 F3 Ltd
    NorCal - Northbay
    Quote Originally Posted by Isopedella View Post
    It most likely has to do with your ISP and how they handle your traffic... Some use a nefarious method called "traffic shaping" which is a fancy term for selective downloading depending on quantity, type etc. With a VPN all they see is an encrypted stream and cannot apply algorithms to it.
    Chuck
    I have McAffee with VPN. Mine takes a bit longer for the VPN to connect.
    May 2017
    Mesa, Arid-Zone-A
    Y'all may as well be talking is some alien language as far as I can understand! All I know is I turn my computer on, log in, and there you are!!! Likity splitily.....
    Semper Fi
