Results 1 to 19 of 19
    Active Member JamesLaz's Avatar
    May 2023
    Arizona
    Default HHC (Hill Hold Control) - what am I doing wrong? Why won't it work?
    Hi all,
    I was reading in my manual that the Can-Am's have a HHC function. Per the manual it is automatic and there is no way to turn it off. My question is what am I doing wrong because my 2019 Can-Am Spyder F3 Limited doesn't seem to work for me. I can pull up to a light or stopping on a hill and if I release the brake, it just starts to roll in the downhill direction.
    I am hoping someone can help me figure this out. Not a big deal, just wondering why its not working per the manual.
    Thanks,
    James
    Last edited by Peter Aawen; 07-19-2023 at 05:03 PM. Reason: Expanded title to briefly ask the question/s... ;-)
    Very Active Member PaladinLV's Avatar
    Feb 2015
    Las Vegas
    Did you read the NOTE?
    AJ
    2014 RT-S
    Akrapovic Exhaust & Cat Bypass
    Bajaron Sway Bar w/links / Sena SM-10/Garmin 660
    Comfort Seat w Adjustable Backrest
    Decals by Purple Harley / Magic Strobe
    Kuryakyn Black Widow Pegs Rivco Highway Brackets
    Rivco Trunk Mounted Double Flag Holder
    FOBO / Spyder Cuff / XM Radio w MC Antenna
    2014 RT/S , Black
    Active Member Valkrocket's Avatar
    May 2018
    Murrells Inlet, SC
    Quote Originally Posted by PaladinLV View Post
    AJ
    And let me tell you, That's the quickest 1 second you can imagine.
    GLIDE-ON>>>>>>>>>>>>>>
    2021 RTL Chrome , Petrol Blue
    May 2023
    Arizona
    Well I guess I didn't understand the note, so what is the point of it. I can't really perceive the 1 second. It seems like I let off the brake and am rolling immediately but it must be holding for that one second. Thank you for your replies and help.
    Thanks,
    James
    Quote Originally Posted by JamesLaz View Post
    Thanks,
    James
    That's pretty much what everyone else has found with this 'feature'....
    It's gotta be a really flat 'Hill' for it to be noticeable; and it's the shortest '1 second' anyone's ever experienced!
    BRP Marketing at its finest!
    Feb 2016
    There is no mention anywhere, but there is some amount of "hill" required to trigger this feature. My 2020 RTL seems like it holds for 2 seconds when stopped on enough of a grade to trigger the feature.
    2020 RT Limited , Marsala Red
    Sep 2015
    Chilliwack, BC. Canada
    I don’t know, Peter..... I find that on my ‘14 RTS my bike holds pretty darn good on an incline on an overpass, and it sure doesn’t “run away” when the light turns red. I mean it’s got round wheels that are supposed to roll easily so you can get the best mileage possible, and now you want auto brakes to hold on a 10 degree hill also? Give me a break (brake)!
    Tri-Axis Chrome Handlebars
    Sena SM10 BT Dongle
    Double USB Port/Volt meter
    LaMonster Magic Mirrors
    BajaRon Swaybar
    HALO Skid Plate
    Shorty Antenna
    LaMonster Cat Delete
    Akrapovic Muffler
    FOBO2 TPMS
    Rear Trunk Rack
    Bruce Erickson
    Chilliwack, BC
    Canada
    2014 RTS-SE6 - Cognac
    Quote Originally Posted by bigbadbrucie View Post
    Like the play on words but are you sure your 2014 even has this Hill Hold Control?? I thought it came out somewhat later...
    Personally, I don't have this on my 2013 RT Ltd Spyder and I really don't miss it or want it... Still, I think you may have missed my point - this HHC thing is 'a feature' that BRP have told everyone their fairly expensive machines have got, and the Marketing/PR mob crow about how it's such a wonderful thing in the media releases and in the manuals; only out there in the real world, a fair proportion of the owners either have been taken in by what they thought it did by the media releases/manuals etc, or they can't seem to get it to work as advertised &/or as per the marketing blurb.... juuust like so many other things the BRP Marketing/PR Mob have told us over the years!
    https://www.spyderlovers.com/forums/...ight=Hill+Hold
    Sep 2015
    Quuite honestly, Peter, I don’t believe me ‘14 has it either, and like you I do not miss having it, nor do I want it. I do believe everything else that I said is true....the wheels are round for a reason; they ROLL. My ‘14 does sort of hold on the inclines....a lot better than the cars when I first started driving. Also, I did NOT realize that BRP advertised that they had HHC......and, you do realize that even though my comment was to your post, it was not really intended to cast a reflection on you...you were just in the way. Personally I think the HHC is a total waste of time. LEARN TO DRIVE
    just my 2 cents worth!
    Sena SM10 BT Dongle
    BajaRon Swaybar
    HALO Skid Plate
    Shorty Antenna
    Akrapovic Muffler
    FOBO2 TPMS
    Rear Trunk Rack
    Bruce Erickson
    Chilliwack, BC
    Canada
    Sep 2008
    TX
    I've never heard of the HHC or read it in the manual. I have an electronic version of the 2018 F3 Owners Manual and did a search for "hold" and "hill": both came up with no reference to HHC. The manual did go into length about starting and stopping on hills, using appropriate brake and throttle, with no mention of the "feature".
    Maybe it's from my 2-wheels days, but I always cover the brake and release when I want to go. By holding down the brake pedal at a stop, the machine is less likely to be bumped out from under you from a rear end collision. I can vouch that it worked for me.
    Wayne
    pauly1 - SpyderDeb's 'wrench'
    IBA #48220 SS1000 BB1500
    Nov 2015
    Chardon, OH
    Spot checked a couple of online manuals. Looks like it first appeared in the 2019 F3 manual. The 2020 manual adds that a 5% grade is required. Only saw it in the F3 manuals. Could be an RT feature, though, if you feel it working. Go find yourself a slope over 5% and test it out if you have a 2019 and newer.
    Doug
    ”Freedom is not a loophole”
    Active Member Dasmoetorhead's Avatar
    Jun 2023
    Tennessee
    What a worthless feature as configured. The hill hd feature on my Ram 2500 actually works.
    Retired U.S. Coast Guard 76-97
    2022 F3S , Monolith black
    Feb 2020
    illinois
    My 2020 RTL had it as well as my 2022 F3L Limited. Works on slopes/hill when stopped. It basically let's one to take foot off brake and begin to accelerate before bike begins to roll back. I have found it to work ok.
    Jun 2021
    Bossier City, LA
    '21 RT-L
    Never noticed this feature. I don't really care either, as it's no trouble to roll in the throttle with my foot on the brake for a second or two, if needed.
    --Exco
    2021 RT-L only has a few cosmetic mods
    Dec 2018
    Long Island
    HHC or not I developed the habit of applying a little throttle when moving from a stopped position so I don't roll back.
    Current: 2022 RTL SE6 Red Marsala and 2012 622 Trailer Lava Bronze,
    Previous: 2014 RTL SE6 Black Currant - 58,746 miles,
    2012 RTL SE5 Lava Bronze - 19,675 miles
    Aug 2013
    SF Bay Area
    Not really needed as you can be giving it gas as you take your foot off the brake. Unlike a car where you remove your foot from the gas and need this before hitting the gas.
    2021 F3 Ltd , Magna Red
    Vermont
    I have the Hill Hold Control on my 2023 F3 LTD Special Series.
    I have not had to use it.
    Deanna
    Gremlin Bell
    SpyderPops Missing Guard Belt
    Ultimate F3 Floorboards
    Sway Bar with Links
    Rolo Laser Alignment
    Half Cover
    Show chrome Trunk Shock
    Jun 2011
    Near Lexington, NC
    I can think of a number of things they can do better other than a hill holder.
    Two Wheelers from 1963-2011
    Three Wheelers:
    2011 RT(Red)
    2014 RT(white)
    2016 F3T(red)
    2022 RT current ride(silver)
    __________________
    2016 Slingshot
    2018 Vanderhall
    2019 Slingshot
    Feb 2020
    illinois
    I have used it numerous times on both Spyders that I have had. It usually holds bike on incline for about two seconds which is enough reaction time from releasing brake and begin to accelerate.
