Have you ridden other Spyders? Try relaxing your grip and your arms. The Spyder steering can be "touchy" but mostly needs less input from you so lighten up on the grips. BTW whart was wrong that you have only had it running a week?
Happy TRAils/NSD
Paul
2012 RT L
AMA 25 years Life Member
TRA
PGR
Rhino Riders Plate #83
Venturers #78
TOI
.... if this is your First Spyder, it's not an un-common complaint..... I like to use the term " GUIDED ". when I explain how I steer my Spyder. I've driven my 14 RT at well over 100 MPH, with barely touching the handlebars ( NEVER DO THAT ) .....however if you've owned Sp[yders for years then something might be mis-aligned .... good luck .... Mike
