Results 1 to 4 of 4
    May 2023
    WI
    Default Are there any a/mkt heel/toe shifters for '08 GS?
    Looking for heel/toe shifter for my 2008 GS. I've just installed Rivco floorboards and they've discontinued theirs. Anyone with used or a knowledge of aftermarket would be very interested. Thanks!
    Hopefully you will get "lucky" with your request here.
    The 998's have been discontinued for a few years now, so aftermarket parts are slim to none. I had an 08 sm5, but did not have a heel/toe shifter on that one.
    Nov 2018
    Waynesboro, PA
    Motorcycle Dave use to carry them. You should give him a call and see if he still has some on hand. here is his contact info. below.
    Phone Hours (pacific time) | 9:00 AM – 8:00 PM
    CONTACT INFO
    MOTORCYCLEDAVE@MAC.COM
    (209) 887-3283
    My Spyder
    2012 RTL , Brown
    Active Member jmbiii's Avatar
    Dec 2008
    Louisa, Virginia
    I put on the RIVCO floorboards a few years ago and couldn't find any then. I have become very proficient in using my heel for the brakes. It's a lot easier to put pressure on the pedal with your heel.
    The shifter is a bit more difficult, but the very short "peg" that comes with the floorboards replaces the original peg and works fairly well. It folds up out of the way after you run through the gears
    Veni, vidi, discessit
    Potius sero quam nunquam
