Results 26 to 50 of 51
  1. #26
    Clinton, MS
    Haven't lost a helmet left on the seat yet, but did l have a pair of gloves removed. Going to eat or shopping or away from the bile over a few minutes I normally carry it in with me.
    2019 RTL Phoenix Orange
  2. #27
    Harrington, Australia
    What about helmets that don't use D rings, like Nolan and Shoei? Does the T bar fit through a ratchet clasp?
    Yes, that’s what the t-bar is designed to accommodate, Idaho…..along with odd shaped D rings.
    HeliBars Handlebars
    Kenda Kanine rear.
  3. #28
    Aug 2023
    Central Florida
    Set it on the seat and drape my crash jacket over it. Just because something isn't cheap doesn't mean it is a great target for thieves.
    I agree with you 100%. That is exactly what I do with my helmet(s). My sweaty helmet is not a rich target. In fact, I haven’t locked the ignition on my HD RoadKing for the last 18 years. We went on a week long trip and forgot the fob. I have’t used it since.
  4. #29
    Sep 2016
    Chillicothe, Oh.
    Mine does.
    2015 RT , Black
  5. #30
    Active Member mikthebik's Avatar
    May 2010
    Ramona, CA
    Yes. Lidlox website says it will and they work on my LS2 Valiant.
    Spyder daily driver - 2015 F3S magnesium - grocery getter
    BajaRon swaybar, Shad sidecases and Givi top case with Admore kits, adjustable brake rod, LaMonster LED headlights, Stebel Nautilus, Zumo 396, FOBO TPMS, F4 Customs windscreen and bump skid
    Front Tires - 175/55R-15 Yokohama AVID S34FA SL
    Rear - General Altima RT45
    Spyder touring buddy (White-Whale) - 2018 RTL pearlescent white - set up for touring and local dates with SWMBO.
    LaMonster LED headlights, Stebel Nautilus, Zumo 396, Spyder cuff, FOBO TPMS, driver adjustable backrest, rear view mirror LED turn signals, and Eastern Beaver PC-8R fuse box. Baja Ron Ultra Sway Bar on the way.
    Front Tires - Stock Kendas
    Other motorcycle transport - 2010 Honda NT700VA Deauville and assorted vintage Japanese bikes
  6. #31
    Active Member redrazor's Avatar
    Mar 2020
    Martinez, CA
    I drop my helmet (large or small) in the Frunk! Pleanty of room in the RTL along with my gloves and garmin.
    2014 RTL bought in 3/20 with only 6,000 mi.
    Came with Garmin 660
    Car tires in 5/20; Elka stage 2 front shocks in 10/21
  7. #32
    Member narygancy's Avatar
    Jul 2022
    Pennsylvania
    Like many others, we usually leave the helmets on the seats or handle bars. Never had a problem in 50+ years of riding. However, with that said, sometimes, depending on where we are, I'll use a thin bicycle cable with a combination lock. Run it through whatever's available on the helmet and the grab bar (when we rode 2 wheels I used the sissy bar). I don't use a heavy duty cable, just a thin one. Generally speaking, thieves don't mess with anything with a lock, they're looking for a quick steal. The one I use is small and easy to store when not being used.
    2016 S6E , Red
  8. #33
    Mar 2015
    forrest above Reno, Nv
    Mine often just sits on the seat. Wifes custom painted helmet always gets locked in the rt saddle bag. Poor old slow V-Max has a helmet lock from the factory.
    Lew L
    2014 RTS , Circuit Yellow
  9. #34
    Dec 2018
    Long Island
    By myself or on a ride with my bride into the frunk and saddlebag they go. If on a trip and compartments are loaded, I use lidlox but put the helmet or helmets in the bag that it came with to prevent anything from dropping into it or them.
    Current: 2022 RTL SE6 Red Marsala and 2012 622 Trailer Lava Bronze,
    Previous: 2014 RTL SE6 Black Currant - 58,746 miles,
    2012 RTL SE5 Lava Bronze - 19,675 miles
  10. #35
    Nov 2019
    Central Oregon
    We have two "helmet hooks," one on each end of the handlebar. If I'm feeling specially paranoid I have a padlock which slips in the hole in the hook, there for that purpose.
    Some with a hacksaw could quickly cut through the hook's plastic. A battery powered, hand-held cutter would work even better. But that same tool could cut the hinges off my Givi cases in short order, too.
    Paranoia has to meet reality somewhere, sometime.
    My top case sometimes has room for a helmet; same with the frunk.
    If all else fails, I carry the helmet(s).
    2015 ST Limited; Givi E52 Top Case; Baja Ron anti-sway bar; Cal Sci wind screen; Vredestein Quatracs (Front).
  11. #36
    Sep 2015
    Chilliwack, BC. Canada
    I do the same as many of you do. Usually I Get off the bike and set my lid on the seat, and go shopping, eating, have a cuppa. USUALLY! If I’m in a high crime area I’ll either lock it in the frunk or take it in with me. just my $0.02 worth!
    Tri-Axis Chrome Handlebars
    Sena SM10 BT Dongle
    Double USB Port/Volt meter
    LaMonster Magic Mirrors
    BajaRon Swaybar
    HALO Skid Plate
    Shorty Antenna
    LaMonster Cat Delete
    Akrapovic Muffler
    FOBO2 TPMS
    Rear Trunk Rack
    Bruce Erickson
    Chilliwack, BC
    Canada
    2014 RTS-SE6 - Cognac
  12. #37
    Active Member RickWB's Avatar
    Jul 2019
    Duncan, British Columbia
    My Schuberth modular helmet with comms fits in my Shad saddlebag, or Lidlox.
    2019 F3 base
    Shad saddlebags with Admore led light kit
    BajaRon swaybar
    Hopnel mini bra
    BRP driver's backrest
    Madstad windshield
    Ultimate floorboards
    CanAm Spyder accessories rear shelf with LinQ adapter
  13. #38
    SoFlo
    If riding two up, and pulling the RT622 trailer, helmets go inside the trailer. If not pulling the trailer, we just carry the helmets with us when needed. If riding single, a helmet fits in the frunk, but storing there is not preferred on account of the heat given off by the adjacent radiators.
  14. #39
    May 2021
    Camano Island, WA
    Quote Originally Posted by Lamonster View Post
    This is what we use if the trunk is full https://www.lamonstergarage.com/can-...ock-lamonster/
    That's what we use when the frunk is full.
  15. #40
    Active Member NorwegianRT's Avatar
    Apr 2022
    Southern Norway
    If alone, I put mine in the frunk. When wife is with me, hers go in the frunk and I carry mine with me. The seat lock wire has snapped,so it is now allways open and I seldom use the "hook" for the helmet under the seat.
    Brgds Martin
  16. #41
    Mar 2021
    Maryland
    I use a full face so I have a coated cable bicycle lock that I keep with me and just run it through the grab bars. I was thinking about a treestand lock as you can just pull the cable through and tighten it more.
    I only use it when in sketch areas. But that still doesn't keep people from screwing with your bluetooth. I worry more about that since I have a sena 50R which is with more than the helmet now.
    2020 F3 SE6
    2020 F3 , Black
  17. #42
    Jul 2021
    Alabama
    My full face Shoei won't fit in the frunk. It easily fits in the trunk. I figure out of sight is much less likely for it to come up missing. Folks like to have a close look at the spyder and I just prefer for all my pieces of it to remain intact. I live in a safe area yet still am in the habit of placing it out of sight which is helpful when I travel out of town that it is habit to lock it up out of view. A seven hundred dollar helmet, at least to me, is worth locking up.
    2023 RT limited
  18. #43
    Jun 2015
    Ritzville, Wa
    My modular helmet fits in the frunk. So depending on where I am and how long I'll be gone I'll stick there along with my gloves.
    Greg Kamer
    USAF, 20 years, retired
    2018 Can Am Spyder RT-Limited
  19. #44
    Unless it's raining I wear5 a Half helmet and that fits easily anywhere in my 14 RT ... however it wasn't expensive and it's flat black so I usually leave it on the seat .....Mike
  20. #45
    Oct 2021
    Ontario
    Places that have helmet laws ( Ontario), if someone steals your helmet you are stuck.
    No helmet, no ride.
    Our helmets always come with us.
    If someone says I can't bring it with me I leave or ask for a $1000 deposit.
  21. #46
    Quote Originally Posted by Raven View Post
    No helmet, no ride.
    Yes, that’s my biggest worry about leaving the helmet on the Spyder, Raven.
    HeliBars Handlebars
    Kenda Kanine rear.
  22. #47
    Sep 2015
    I always carry my old 1/2 helmet in the frunk, for just that reason (I can still get home).
    Sena SM10 BT Dongle
    BajaRon Swaybar
    HALO Skid Plate
    Shorty Antenna
    Akrapovic Muffler
    FOBO2 TPMS
    Rear Trunk Rack
    Bruce Erickson
    Chilliwack, BC
    Canada
  23. #48
    Very Active Member vondalyn's Avatar
    Jun 2012
    Longmont, CO
    Lidlox. We've always been able to hang our hemets over the end of the bar, so it's not hanging upside down. There are longer "arms" available now that help with this.
    We now have His and Hers Spyders!
    Current Spyder: White 2015 F3-S SE6
    His Spyder: White 2015 F3 SE6
    Previous Spyder: 2012 RT Limited SE5 -- 30,300 miles
    Previous rides: Kawasaki & Honda
    2015 F3 , Pearl White
  24. #49
    Jul 2021
    IL
    I have an RT, not an RTL, and so the only place I have for a helmet to fit is in the frunk. No problem if I am alone, but if my wife is with me, we usually take both helmets with us into the restaurant or wherever we are going. Typically I use the frunk and one of the side cases for our jackets and gloves. I've been riding for over 40 years and have never lost a helmet to a thief or anyone else, but helmet cost is not like it once was. When I first started riding I think my first helmet was about $40. Even in those days that was not much of an expense. But with helmets now routinely costing $700 to $800 its just not worth taking the chance of some loser grabbing my, or our helmets and walking off.
    2021 Spyder RT
    2023 Royal Enfield Hunter 350
    Retired U.S. Army
    Life Member, NRA
    2021 RT , Petrol (blue)
  25. #50
    Very Active Member Peacekeeper6's Avatar
    Sep 2019
    Reno, NV
    I use my ski/snowboard retractable cable lock similar to this:
    https://www.amazon.com/Pacsafe-Retra...2&sr=8-13&th=1
    With the helmet on the seat, it keeps the seat cool when it's time to "mount up".
    I also sometimes place my helmet in the right saddlebag. I didn't realize that the right has just a tad bit more room than the left, thanks to Lew's wife for pointing that out, LOL.
    Last edited by Peter Aawen; 11-05-2023 at 10:46 PM. Reason: Exposed hidden URL per policy to minimise spam/scam opportunities...
    SIGNATURE PIC CURRENTLY UNDER CONSTRUCTION
    2016 Toyota Sienna SE - hers
    2002 BMW 325i - his
    1994 Chevrolet Silverado K1500 Sportside Z71 - whoevers vehicle is in the shop
    2009 Harley-Davidson Sportster XL883 Low (Vivid Black) - his
    2018 Can-Am Spyder RT Limited - hers
    2007 Harley-Davidson Sportster XL883 Low (Pearl White) - hers (SOLD 02/29/20)
    2011 Tao Tao 50 - whoevers bike is in the shop
    2007 Reinell 186 FNS - the dog's
    1995 Fleetwood Flair 27R - EVERYBODY'S !
