Page 70 of 78 FirstFirst ... 2060666768697071727374 ... LastLast
Results 1,726 to 1,750 of 1926
  1. #1726
    Active Member Dasmoetorhead's Avatar
    Jun 2023
    Tennessee
    Weather is good, so I did a 80 mile ride.
    Retired U.S. Coast Guard 76-97
    2022 F3S , Monolith black
  2. #1727
    Aug 2019
    Stoughton, WI
    Removed my OEM windshield as my new 7Jurock is arriving Tuesday.
    2022 RT Sea To Sky
  3. #1728
    Mar 2021
    Maryland
    Took the gauge spoiler off, put the windshield on and went for a ride to High Rock and Gambrill Park for the sunset.
    2020 F3 SE6
    2020 F3 , Black
  4. #1729
    Quote Originally Posted by CloverHillCrawler View Post
    And all went well??
  5. #1730
    Jun 2011
    Near Lexington, NC
    Put two Kenda Kanine's on the extra set of silver colored wheels I bought for my '22 RT. It came with black wheels and I wanted something different.
    Small local shop mounted and balanced them both for $30. Each wheel took one weight. Have only ridden the bike about 50 miles so there's not much to report other than they were super smooth, no shimmy.
    Two Wheelers from 1963-2011
    Three Wheelers:
    2011 RT(Red)
    2014 RT(white)
    2016 F3T(red)
    2022 RT current ride(silver)
    __________________
    2016 Slingshot
    2018 Vanderhall
    2019 Slingshot
  6. #1731
    Mar 2021
    Maryland
    And all went well??
    I didn't hit anything and anything didn't hit me!
    Didn't get busted while having a smoke break and watching the sun set over south mountain so yea ...all is good!
    2020 F3 SE6
    2020 F3 , Black
  7. #1732
    Jun 2017
    Rapid City, SD
    Put about 70 miles or so on ryding around town and the hills. It was near 70 here today.
    HE>I
    2017 RT , Asphalt Grey
  8. #1733
    Jul 2023
    S.E. Pennsylvania
    It was a gorgeous day to be out riding here in S.E. Pennsylvania. Temperatures climbed from the 50s to almost 70 during our ride. Cloudless blue sky the whole day. We rode back roads over to a little diner for lunch and then it was up to Cabela's to buy some rain/wind pants. Then we hit the back roads all the way home. 108 miles for the day. What a nice day!
    Lee B
    2022 Can Am RT Limited
    2021 Honda NC750X DCT
  9. #1734
    Aug 2019
    Stoughton, WI
    Gave in and tucked it away for its long winter nap
    2022 RT Sea To Sky
  10. #1735
    Active Member RickWB's Avatar
    Jul 2019
    Duncan, British Columbia
    Installed the wiring harness for my Venture heat jacket liner, and went for a ride. Worked well!
    2019 F3 base
    Shad saddlebags with Admore led light kit
    BajaRon swaybar
    Hopnel mini bra
    BRP driver's backrest
    Madstad windshield
    Ultimate floorboards
    CanAm Spyder accessories rear shelf with LinQ adapter
  11. #1736
    Jun 2023
    Tennessee
    Wiped it down, checked tire pressures, and went for a short 40 mi ride. It was 59° F.
  12. #1737
    Vermont
    Nothing. It is on a battery maintainer.
    It is in hibernation until April 2024.
    Deanna
    Gremlin Bell
    SpyderPops Missing Guard Belt
    Ultimate F3 Floorboards
    Sway Bar with Links
    Rolo Laser Alignment
    Half Cover
    Show chrome Trunk Shock
  13. #1738
    Mar 2021
    Maryland
    38 F - Sunny and No Salt ....time to bust out the "smurf suit" for a ride North on 194 into Pa.
    2020 F3 SE6
    2020 F3 , Black
  14. #1739
    Jun 2023
    Tennessee
    Took the F3S gauge spoiler off, and out the Route 129 shield on for Winter Ops. It's noisy but keeps me warm. I think it also looks good. Going to go for a ride later on. Supposed to be 55°F.
  15. #1740
    Aug 2023
    Connecticut
    Finally admitted I’m too old to ride in the cold weather when I wash my truck and ice is on it before I dry it.
    Covered exhaust, put the foam pads under wheels, hooked up tender and put cover over until spring.
    2022 RTL , Silver
  16. #1741
    Active Member 308gunner's Avatar
    Oct 2017
    covina california
    I brought a cupholder... from Lamonster... it's really nice.
  17. #1742
    Jun 2023
    Tennessee
    17° out, so the Spyder is resting with the umbilical cord attached.
  18. #1743
    Jul 2023
    S.E. Pennsylvania
    Filled up the gas tank, added fuel stabilizer, and took the bike for a ride to run the mixture through the system. The day was very pretty but had a stiff cross wind and a bit cool in the low 40s. Even so we stayed out for an hour and a half and enjoyed ourselves. This was probably the last ride of the year, maybe not.
    Lee B
  19. #1744
    Faribault, MN
    Took her out for some Fresh Non-oxygenated premium fill-up and a little November Winter in MN freeway time to get this shot
    Safe Rides,
    David and Sharon Goebel
    Both Retired USAF Veterans
    IBA 70020
  20. #1745
    Sep 2023
    MS
    Web boards modded; RLS Cat delete done
    Cut down the Web floorboards to work with the SM5. Adjusted the shifter and clearanced it so that it will upshift, even though it's up one notch on the shift shaft. My Foot fits under it properly now, so no need for a heel bar - so far. Got the replacement bolts at the hardware store for the RLS Cat Delete "Y" pipe; the provided bolts were too short to use with the donut. Finished the Cat delete; sounds nice, not too loud, very little heat coming up compared to the old cat. Found that the original cat pipe had a bad gasket on the RH side, which may have contributed to the heat. Replaced the crazed original windshield with the new Black Friday Special 4" wider one from SlingMods; a twenty-minute job. Removed the acoustic panels and installed the bars; vent kit will be installed when the weather clears up in a few days. Really looking forward to a good ride with those web boards installed; too bad they don't make them anymore. They are made of good steel and were hard to cut; at least the left side now resembles the right side. Full length boards on a manual, yea me! Best to all!
    Last edited by Peter Aawen; 11-30-2023 at 10:49 PM. Reason: Moved Post title - they mess with Searching! ;-)
    2012 Spyder RTS
    2012 RT-S , BajaRon's plugs and wires 1" spacer Silver
  21. #1746
    Active Member broderp's Avatar
    Jul 2023
    OHIO
    Nothing.
    I have a "whole" 20 miles on the odometer - the ride home from the dealer. Its been too cold, its been raining and I'm on the injured list. I have a ton of parts in hand to install and many more on the way but realize I need to clean out the garage so that I can make room for the work.
    I look into the garage door every few hours to stare at it. Yesterday I got dressed, put on a jacket and just sat on it thinking about the next ride.... seriously. Going through withdrawals over here...
    Now a few days ago (11/29/23) I installed my backrest and my new windshield. But did not ride.
    2023 Spyder F3-S, Manta Green
    2023 Ryker 600 ACE, Black on Black (The wife's toy )
    2020 Kawasaki Z900, Candy Plasma Blue
  22. #1747
    SoFlo
    Ready to give the Spyder a good wash and wax, flush and bleed brakes, make ride height setting changes, then dig out the ROLO laser alignment and BUDS / BUDS2 tools and reset the alignment for best handling and least rolling resistance.
    Got an oem oil filter and oem O rings, plus Mobil 1 10w40 motorcycle oil and will change oil also.
    The Lithium battery has been a great improvement over the previous Yuasa batteries. Excited to not have any worries about getting stranded with a failed battery.
    Also need to purge the RT622 trailer bearings with new grease.
    Winter here is riding season, summer gets a bit to toasty unless doing dinner rides after the sun goes down.
    Need to have the wife decide where we shall head out to see holiday lights.
    Also, will help my longtime neighbor and friend with his 2021 Spyder. His too will get a flush and bleed of the brakes. He bought Speed Bleeders for his, so those will get installed. Me, I remain old school and capable of not needing them. He may have more options to install, and then his gets the ROLO Laser alignment too. He also has a NoBoot windscreen arm upgrade, might wait on that for now.
    Couples hours of work, then it’s time to play.
  23. #1748
    SoFlo
    Interesting, I was under the impression that MTBE oxygenated fuel was no longer sold at consumer fuel pumps on account of serious health hazards (known very bad carcinogen). We still use it for race bikes at about $12 / gallon.
    Non ethanol gasoline we can buy at many gas stations. Typically sold for marine and off highway vehicles, including lawn equipment.
    For almost all the years of owning the Spyder since 2014, unless traveling and burning fuel in a short time, I always treat the fuel with Yamalube to prevent corrosion and phase separation of the ethanol.
    Ran leftover oxygenated gasoline in my lawnmower once. A week later, going to cut the grass again, the oxygenated gasoline had ruined the seams of the plastic fuel tank. Had to get a new fuel tank after that. Oh well, lesson learned.
  24. #1749
    Aug 2023
    Connecticut
    Doing O/C on daughters car today found signs chipmunks are back next to her coil packs, sons car had same acorn debris under coil cover…off to HW store for rodent repellant & mothballs.
    Added a few more mothball containers next to wheels and ended up with a sonic unit also to put next to spyder also, have to keep the priorities in order!
    2022 RTL , Silver
  25. #1750
    May 2014
    Cornish, Maine
    I've added a set of Ultimate FloorBoards from CanAm Spyder Accessories to our 2021 F3 Limited "Nugget". Sadly I have not uploaded pictures and Nugget is hibernating for the Winter here in Maine.
    2021 F3 Limited. 2013 RT Limited.
