Results 1 to 7 of 7
    Active Member Mike0123's Avatar
    May 2020
    Rhode Island
    Question Any way of Removing some 3M mounting tape without scratching the tupperware?
    Hi,
    I need to replace some LED strips and need to remove the dead ones. How do I remove that 3M mounting tape and goop without damaging or scratching Dudley?
    TIA
    Last edited by Peter Aawen; 12-18-2023 at 04:14 PM. Reason: Expanded title to briefly ask the question... ;-)
    2021 RT Limited in Marsala Red & chrome (9/20)
    2006 Yamaha Royal Star Venture - Black Cherry
    2003 Suzuki Volusia - Black w/ Gold
    1973 Honda CL350 - Hawaiian Blue
    2021 Limited , MArsala Red & Chrome
    Dec 2020
    Hartwell, Ga
    Try heating it with a hair dryer to pull it off, then clean with rubbing alcohol.
    Active Member Poppie65's Avatar
    Jul 2023
    Springfield, OH
    I've used this product for years, and it works perfectly.
    Remove as much of the tape that you can before applying.
    https://googone.com/original-adhesive-remover
    2023 S2S
    Shoei RF-1400 Helmets
    Cardo Freedom 4x comms
    Both riders USMC vets
    2023 Sea to Sky , Green Shadow
    Aug 2023
    Connecticut
    You don't say if it is foam based or clear VHB adhesive.
    Using a heat gun or hair dryer will help to release the adhesive bond on either.
    With the clear if you can get under a corner and pull (stretch) at a low angle while applying heat it should remove rather easily.
    The foam is tougher as it will separate when removing the LEDs leaving the adhesive buried under a foam layer. The best success I have had with this is low heat and starting at one edge push and roll the residue up over itself generating a "foam roll up" as you move along. Then use the adhesive remover to remove any residual glue.
    Googone is a great product for the adhesive removal, just test on painted surfaces. I use 3M Citrus Base Industrial Cleaner as it has yet to adversely effect a customers vehicle when removing emblems with foam based adhesives but it is expensive. Upside is it will float off any road tar, grease etc on your car as well, just don't let it drip onto an asphalt surface.
    The Isopropryl alcohol would be your final wash before installing the new VHB adhesive.
    2022 RTL , Silver
    Bossier LoUiSiAna
    & plenty good 'ol Elbow Grease. A coarse old rag (cloth, but tough, like with hemmed edges!) For the hard stuff, you might wrap a rag around a handle of something, just be careful of slips. If you use a heat source, keep back 3-4 inches as to not warp the plastic. Alcohol has worked better for me & with the foam, a combination of alcohol; & with additional help when pulling on foam, follow with dental floss - using it a as cutter & pulling/scraping between the foam & the surface.
    Quote Originally Posted by Poppie65 View Post
    I've good luck with WD-40, you might already have some ....Good luck ....Mike
    +1 Goo Gone!
