Results 1 to 25 of 34
    Active Member Mike0123's Avatar
    May 2020
    Rhode Island
    Default Is it Zumo time???
    So, looking for some opinions here. I currently use my phone on a handlebar mount with Rever or maybe Waze. I don't use BRP Connect (or Go or whatever it is now). The big issue I have is seeing the phone screen with the glare from sunlight. The boss is suggesting a Zumo, but it's a fair chunk of money, so I have a few questions.
    Will using a Zumo eliminate the glare issue?
    Can I use Rever with the Zumo for turn-by-turn directions?
    If there is a specific destination punched into the Zumo, and we go off route, will it guide me from wherever I am to that destination, or will it try to direct me back to where I left the original route first?
    Is the screen clearer than a phone screen?
    How does it handle not having cell service?
    Any wiring or installation issues?
    Does it work with gloves?
    Integrate with the Cardo systems?
    Connect to Spotify?
    SO I'm wondering if it actually does this, do I need my phone at all except for calls....
    Anyway, thanks for your patience....
    Mike
    2021 RT Limited in Marsala Red & chrome (9/20)
    2006 Yamaha Royal Star Venture - Black Cherry
    2003 Suzuki Volusia - Black w/ Gold
    1973 Honda CL350 - Hawaiian Blue
    2021 Limited , MArsala Red & Chrome
    Active Member Two2Three's Avatar
    Mar 2023
    Missouri
    Love my Zumo and have used it for years.
    - nothing is perfect, but I've never had any issue.
    - yes, you can export from Rever and import to Zumo
    - It will try to direct you to your next shaping point or destination. Not to the point at which you left the route. You can also tell it to skip the next point if you wish.
    - Hard to answer. Depends on your phone, phone size, etc. It's certainly equal to any modern smart phone screen IMHO.
    - It's a GPS. It uses the global satellite system, not cellular networks.
    - No, and at least my 22 RT includes a dedicated plug just waiting to power a GPS.
    - Yes, perfectly.
    - Yes
    Connect to Spotify?
    - Never tried. It will pair to your phone though, and play whatever is playing there. I use Pandora, so Spotify should work the same I'd guess.
    Also... the Zumo "Adventurous Routing" is pretty cool. As is the option to just auto-create a route "north" for 2 hours or x miles, or whatever and return to the start point.
    2022 Spyder RT Ltd Petrol Metallic
    ________________________________
    Active Member RickWB's Avatar
    Jul 2019
    Duncan, British Columbia
    I have a Zumo XT. A friend of mine with a 3D printer, made a sun shade that clips on, and works great. I am pleased with the product.
    Rick
    2019 F3 base
    Shad saddlebags with Admore led light kit
    BajaRon swaybar
    Hopnel mini bra
    BRP driver's backrest
    Madstad windshield
    Ultimate floorboards
    CanAm Spyder accessories rear shelf with LinQ adapter
    May 2020
    Rhode Island
    Quote Originally Posted by Two2Three View Post
    <SNIP>
    Thanks so much.
    What do you use for a holder?
    Thanks again
    Mar 2023
    Missouri
    I use the mount on the handlebar risers from LaMonster
    Aug 2019
    Stoughton, WI
    Same here, with a Touratech locking mount and RAM locking knob.
    https://touratech-usa.com/store/Tour...Garmin-Zumo-XT
    https://rammount.com/products/ram-knob3lu
    2022 RT Sea To Sky
    Active Member PJveetwin's Avatar
    Oct 2022
    Peoples Republic of Calif. Upper Mojave Desert
    I have a Zumo 595 and a XT The XT is much better in bright sunlight. The 595 is designed to work directly with Spotify and Pandora. The XT will play anything on my phone to my 21 RTL via Bluetooth. Both should be used with Basecamp on a computer for creating routes and managing waypoints
    2021 RT LT
    Harrington, Australia
    Mike, Two2Three has answered your questions perfectly, but I am just curious. Why do you want to use Rever for turn by turn directions when that functionality is already built in to the XT?
    HeliBars Handlebars
    Kenda Kanine rear.
    Sep 2020
    Middletown, NJ
    All the above are true. A couple more advantage of a Zumo over the phone is Zumo is waterproof. Phones overheat in the sun and can be shaken to death. Save your phone for PHONE CALLS and let the Zumo be your workhorse on the road.
    2020 RT base , Chalk White
    Mar 2023
    Missouri
    Quote Originally Posted by RayBJ View Post
    Yes very true! And I’ve had it in the rain for multiple days in a row with no issues.
    Oct 2020
    Arizona
    I have a Zumo XT and it is very easy to 99 percent of the time. I have a Pixel 6 smartphone that goes in a mount also. The Zumo XT does a better job of given speed limit info and alerts for schools, speed cams, radar traps etc etc. I have had my smart phone overheat once or twice. I do like how easy it is to send goodge maps route to the phone, jump the trike and head out, but I am going to keep the Zumo turned on also. I play my music to Cardo helmet intercom from the Zumo XT. The Zumo XT work with a gloved hand where the smart phone will not.
    May 2020
    Rhode Island
    Hi Pete, I am asking simply because I am not familiar with the Zumo at all, but I am with Rever, so I was thinking about creating a route in Rever and importing it into the Zumo. I know my question didn't make that clear, but that's what I think I am thinking.
    I had completely forgotten to mention the phone overheating! Yes .. thats an issue.
    Aug 2019
    Stoughton, WI
    And, currently, Zumo XT/Zumo XT2 are now on sale for $100 off.
    https://blog.touratech-usa.com/2023/...-a-comparison/
    2022 RT Sea To Sky
    Jul 2023
    S.E. Pennsylvania
    I have Zumo mounts on both of our bikes and transfer the Zumo back and fourth between the bikes. My Cardo has two blue tooth links; one to my phone and the other to the Zumo.
    LaMonster has this wiring harness that makes installation a bit easier.
    https://www.lamonstergarage.com/gps-...-am-spyder-rt/
    Lee B
    2022 Can Am RT Limited
    2021 Honda NC750X DCT
    Oct 2021
    Wichita, KS
    I have heard this said about iPhones but Samsung phones don't suffer this fate. I run an S23 Ultra and have never had a problem.
    Peter Pan has struck again!
    Dec 2020
    Hartwell, Ga
    Quote Originally Posted by FrogmanDave View Post
    My S20+ will overheat here in the Ga summer.
    Feb 2020
    West Central Florida
    A few other quick points,
    If you are using a headset and paired with the Zumo and your phone, you can make and receive calls from your GPS, It shows incoming calls on the Zumo screen along with the ability to pull up your contact list from your phone for outgoing calls.
    You can add a SD memory card to the GPS and store a ton of music/audio files to listen to in the event you are outside of cell coverage.
    The Zumo has some nice features that keep you updated on upcoming traffic, weather, school zones, red light camaras and a bunch of other features to long to list.
    Download the users manual on their site for all the info
    https://support.garmin.com/en-US/?pa...00&tab=manuals
    I have ACP and AA on my Goldwing and the Zumo is still my first go to device when traveling.
    Like Troop stated The XT and XT2 are currently $100 off on almost all sites. I ordered a second unit for our new STS because who knows when Can Am will get their ACP update released.
    2018 Honda Goldwing Tour..."Mine"
    2019 Can-Am Spyder RT......."Her's"
    2024 Can-am Sea to Sky......"Ours"
    Danbury Connecticut
    Just a small additional point.
    I also have a Zumo XT installed on my 2020 RT Limited.
    I'm happy that you had no issues with wiring your Zumo. On my 2020 RT, the plug you indicate was wired backwards. The Zumo would not charge from the bike power.
    The solution was right out of Star Trek. Scotty had to "reverse the polarity". This required a little surgery on the wires. I chose to modify the wires on my Zumo.
    In the end, you wind up with the black wire from the Zumo connecting to the red wire from the Spyder, and again red from the Zumo to the black on the Spyder.
    This problem was happening on the 2020 and some of the earlier models.
    Sounds like BRP got it right for you on your 2022. Well done!
    https://www.spyderlovers.com/forums/...ght=gps+wiring
    As to the glare issue, I have the BRP mount that allows you to adjust the angle of view to the GPS. If the sun is glaring, I just change the angle of view a little up or down. A ram mount should allow the same flexibility.
    This free advice comes to you complete with my standard double your money back guarantee.
    IBA #47122
    2020 RT Limited Asphalt Grey
    Active Member Poppie65's Avatar
    Jul 2023
    Springfield, OH
    Have either of you found that the Garmin head unit moves or settles from road vibration? I like the adjustability of the ball mount, just curious if it can be tightened enough to keep everything in place while riding.
    2023 S2S
    Shoei RF-1400 Helmets
    Cardo Freedom 4x comms
    Both riders USMC vets
    2023 Sea to Sky , Green Shadow
    Mar 2023
    Missouri
    Quote Originally Posted by Poppie65 View Post
    Mine stays rock solid.
    Feb 2024
    Tennesse
    I have a Garmin Zumo XT with an Arkon MC25MMB motorcycle mount.
    I bought the wiring kit from Lamonster, but have not been to get it to connect to power correctly.
    Currently the GPS is wired into the USB port in the glove box for power.
    The GPS does not move around at all.
    Last edited by Peter Aawen; 05-09-2024 at 09:47 AM. Reason: Removed Post title after merge ... ;-/
    racoon
    Middle Tennessee
    2024 CAN-AM Spyder RT Sea-to-Sky - Vegas White Satin
    2023 Honda Ridgeline Sport - Sonic Grey Pearl (aka Baby Blue)
    2024 RT Sea-to-Sky , Vegas White Satin
    Aug 2019
    Stoughton, WI
    I found that the Touratech mount does vibrate around a bit more due to its size and weight. Also, the longer the RAM arm, the more movement you're likely to get. On my new Zumo XT2, I now use a MotoPumps lock and the shorter RAM arm. I also have a RAM arm key lock, but I'm currently using the 5 pin RAM lock now. Much less movement, albeit not the vault like lock of the Touratech.
    RAP-S-KNOB3-5U RAM Pin-Lock™ Security Knob with 5-Pin Pattern for B Size Arms.
    2022 RT Sea To Sky
    Active Member WRCLVR's Avatar
    Nov 2022
    Georgia USA
    After reading this thread, as i was thinking about a GPS with a mount, I am not sure how difficult it is to use. Sounds much more difficult than Google Maps. Amazon reviews are also mixed on the XT2 as well. I have never had a GPS unit before and dont want something that is hard to program, causes issues during rides, or is using old data for restaurants etc from years past to direct you on the ride.
    Is there something else that is more user friendly (coming from Google Maps app) that uses the GPS satellite system?
    Oh, and it will be going on my 2024 S2S once I get it back from the screen issues - so if anyone has connected one to the 2024's, is there a power port connector on the right side under the panels like the older 2023's?
    Also pics of mounts would be great, not on the handlebars, maybe above tho, on the screen surround?
    2024 RT Sea to Sky screen now working but codes will remain until BRP releases the ACP update.
    Feb 2024
    Tennesse
    Quote Originally Posted by WRCLVR View Post
    Oh and it will be going on my 2024 S2S once I get it back from the screen issues....so if anyone has connected one to the 2024's is there a power port connector on the right side under the panels like the older 2023's?
    Also pics of mounts would be great..not on handle bars maybe above on the screen surround?
    The picture I posted above is the mount on my 2024 S2S and is used with a Garmin Zumo XT, which is a motorcycle specific GPS.
    Here's a picture of the Zumo on the mount. The picture was taken with my phone at head height, so you can see how it looks while I'm riding, and that it doesn't block the display.
    racoon
    Middle Tennessee
    Jun 2022
    Indiana
    Yes there is the GPS power port on the right side just like the 20 t0 23 rt's.
    2022 RTL Hyper Silver
    Sequential LED fender turn signals-Main and passenger floor boards running and turn signals
    Side view mirror stabilizers-Baja Ron sway bar-Can Am passenger arm rests and drivers back rest
    Garmin XT GPS-Top Cuff for GPS and Phone holder-Quick grip phone holder-Upper RT vent grilles
    Radiator vent grills-LED fog lamp with switch-Foam grip covers-Peddle box pro-Cardo Bold intercom-Big Blue-BUDS/BUD2 Megatech/Megatronic
