Results 1 to 23 of 23
    Jan 2024
    Texas
    Question Do Waterless Washes work, or scratch the paint? eg. Buglside, etc.
    The whole concept of waterless wash scares me.
    It seems very unlikely that you aren't wiping dirt and other contaminates across the paint, causing anything from micro scratching to actual scratches.
    Personally, if I were to start using bugslide or something similar, I think I would do a wash first to remove all the surface crap.
    Someone educate me, please.
    2019 Spyder RT Ltd. Bought in Jan 2024. Can-Am states only.
    Slingmods USB and QuadLock phone mount with vibration dampener
    Highway pegs
    Rear GENERAL ALTIMAX RT45 SL 225/60R-15 tire
    Drink2Go front/rear Cupholders
    3D printed Turn Signal/Shifter caps
    KOTT Grill covers
    LED Headlights + LED Foglights
    High Mount Trunk brake/turn lights with brake strobe
    Pedal Box+ w/BT
    Show Chrome gas shock for rear trunk
    Foam Grips
    Red Rim Covers
    VIOFO T1 Front/Rear Dash Cam system
    Active Member AndysF3S's Avatar
    Jul 2023
    Alberta
    I have a bottle but have never used it for the same reason you state.
    Danbury Connecticut
    Quote Originally Posted by Allen42 View Post
    You are correct. If you've been off-roading on your Spyder, then yes, you need to hose it down with water to wash all the mud and grime off.
    The waterless cleaners are there for light duty cleaning. Watermarks from rain, light dust and bugs are the principal targets. Also, some of these cleaners leave a residue on the surface which makes it less likely to have subsequent dirt stick. This is particularly helpful for the windshield. Once coated, bugs are less likely to stick.
    Of course, the windshield gets a whole procedure itself.
    IBA #47122
    2020 RT Limited Asphalt Grey
    I agree with the scratch part on the paint surfaces.
    Here is a possible solution. All you need is a dryer sheet, a spray bottle, and fill with water. Put the dryer sheet in the bottle, fill with water, and you are ready to go. Spray the bike, a small section at a time. Wipe with a microfiber cloth. The results will amaze you.
    Oct 2021
    Wichita, KS
    Waterless is all the rage right now. I say hogwash (see what I did there). Anyway, just wash your Spyder like you have always washed everything else. On top of that today's paints are so soft they scratch much easier than in the past. The Spyder has incredibly soft paint. Don't leave bugs on there for long. They will etch right into the paint. Of course a ceramic coating will prevent this in the first place. Good luck with your decision.
    Peter Pan has struck again!
    Jul 2022
    California
    After a long trip, nothing can replace a good cleaning with soap and water. But after short trips, when you have just a few bugs to deal with. I have been using Bike Spirits Cleaner and Polish. I have been using this for years.
    https://www.amazon.com/Original-Spir...1021686&sr=8-2
    Forgot to mention that I have a good coat of Turtle Wax/Polish on it. I debated on going with a Ceramic but I have never used it. I have been using Turtle Wax on all my bikes forever and have always had great results.
    2022 RT Limited , Petrol Metallic
    Dec 2018
    Long Island
    I live in an apartment and access to washing by hand is limited. I have been using Maguires Ultimate Waterless Wash and Wax for several years and have great results.
    First, I use a feather duster to get the light dust, then a swifter duster cloth or 2, then the waterless wash. I apply the wash fairly heavily, to a section at a time, wipe with a microfiber cloth, then buff with another microfiber cloth. When the first one is saturated I use the buffer as to apply the wash then a dry cloth to continue. I use it on my entire Spyder, except for the windshield. After I use the wash, I wipe down all the black with Maguires Ultimate Black Plastic Restorer Cloth. I've gotten many complements on how she shines and the black looks new.
    Current: 2022 RTL SE6 Red Marsala and 2012 622 Trailer Lava Bronze,
    Previous: 2014 RTL SE6 Black Currant - 58,746 miles,
    2012 RTL SE5 Lava Bronze - 19,675 miles
    Aug 2019
    Stoughton, WI
    Can Am paint is so soft that if you roll your eyes at it, you will leave swirl marks...
    2022 RT Sea To Sky
    Feb 2020
    Minnesota,USA
    It's like they forgot the seal coat, Which I believe they did!
    If in Doubt, Don't Do It!
    Active Member BoatFixx's Avatar
    Oct 2023
    Port Hadlock, WA
    I've been using Griot's Spray-On CarWash since its inception. Part of our family business is auto/boat detailing.
    Look for a product with high lubricity.
    That stated, these products are not for really dirty substrates.
    Dusty to very dusty, yes but not loads of grit, grime and mud.
    Lay down a good polish (not wax) like a ceramic (hydrophobic coating) and then you can use the spray-on carwash in-between your major washes.
    I carry a bottle of spray-on car wash on my trips and tend to use it on long rides every few days. (user discretion advised)
    Addenda: Yes, Can-Am paint is what some people call, "soft" i.e. easily scratches.
    I am assuming it is a single component (acrylic) paint verses a two part (urethane) basecoat/clearcoat process which is much more resilient to minor abrasion.
    Harrington, Australia
    Similar to BoatFixx, I wash mine the regular way before putting a Meguiars ceramic coat on it, then use a Meguiars ceramic waterless on it until it is time to re coat in say 6 months. (Unless the RT is particularly grubby following a long trip.) I have seen zero adverse effects on the paint.
    HeliBars Handlebars
    Kenda Kanine rear.
    Vermont
    HI Allen 42,
    I use the following product( on my 2023 F3 LTD Special Series, it has a matte finish) https://www.chemicalguys.com/product...y-wipe-formula
    It has the following features: Hydrophobic Technology, Synthetic Gloss Enhancers.
    Chemical Guys Swift Wipe Waterless Car Wash is the next generation Waterless detailing system. In on step, Swift Wipe cleans, shines, and protects without installing any swirls or scratches. Swift wipe simply sprays on, then wipes off. The waterless system finishes with a coat of optical spray sealant to enhance shine with durable protection.
    I use the above on my windshield and the bug spats come off my bike.
    The Waterless Car Wash is a easy spray and wipe solution Wash your whole car/bike without water, cleans,shines, and protects.
    Deanna
    Gremlin Bell
    SpyderPops Missing Guard Belt
    Ultimate F3 Floorboards
    Sway Bar with Links
    Rolo Laser Alignment
    Half Cover
    Show chrome Trunk Shock
    Member Dusterdude's Avatar
    Feb 2024
    Virginia
    I use Meguiar's Waterless wash, works well.
    Aug 2012
    Central Coast, CA
    I also like Aero Cosmetics Wash Wax All.
    https://www.amazon.com/dp/B002N3RQYA...v_ov_lig_dp_it
    It was developed for airplanes and seems to work really well.
    2020 RTL SE6
    Bossier LoUiSiAna
    Quote Originally Posted by FrogmanDave View Post
    kinda agree. **kinda** did get some of the fast wax681C6124-B200-4340-A439-B9DAD043550A.jpeg
    & is good, especially when out on a trip & just wanna get some grime & bugs/pollen ~rain spots off(any elbow grease helps most anyway) least don’t have to try find an available/ free /friendly water spigot. Can do just about anywhere carry a can & some rags does fine. **note LIGHT grime, heavy stuff still waits till home & more dedicated cleaning **
    Mar 2021
    Maryland
    I just use rain-x car wash, If I'm not in a hurry I wax it with Meguiars Cleaner paste wax. If i'm in a hurry I use the Turtle wax spray on Graphene based wax.
    2020 F3 SE6
    2020 F3 , Black
    Apr 2012
    Florida
    This stuff is crazy good. And inexpensive. Tom
    2020 Petrol Blue Metallic RTL
    Feb 2023
    Florida
    I always wipe down with a duster or do a clear water rinse before "waterless washes"; keep a good coat of ceramic and the light gook will come right off.
    Jan 2024
    Texas
    -nevermind, please delete this post-
    Highway pegs
    KOTT Grill covers
    Pedal Box+ w/BT
    Foam Grips
    Red Rim Covers
    -nevermind, please delete-
    No, the mods won’t do that, Allen. Apart from affecting FB algorithms, there is a lot of useful info in here that someone may be looking for via a search at a later date. It is here to stay.
    Pere
    HeliBars Handlebars
    Kenda Kanine rear.
    Jan 2024
    Texas
    Pere
    I just meant delete that post only. I edited it to say that, as it wasn't relevant.
    Highway pegs
    KOTT Grill covers
    Pedal Box+ w/BT
    Foam Grips
    Red Rim Covers
    I can delete (well, hide anyway! ) your post Allen, the one quoted above, #19 (If you want me to, then please PM me) but doing that will not delete or hide the whole thread!
    Just to explain further, this is because, as Peteoz mentions, there's a lot of good info here that may well help others, if not now or soon, then maybe at some time in the (far??) future (this is one of the main benefits of Fora like this - they are much more 'searchable' than most other forms of social media, so nothing in the way of the shared knowledge or experience posted here is ever truly 'lost'! ); and deleting threads &/or too many posts seriously impacts the way the big search engines treat this Forum in their displayed search results - too many deletions means that we get dropped down or even completely off their displayed results! That means our sponsors get less or no return on their investment here, so there's significantly reduced benefit to them continuing sponsoring, and less/no sponsorship threatens the continued operation of the Forum.
    This seriously threatened the Forum's continued operation not too far back in the past, and despite asking members not to delete things needlessly, such deletions continued at a serious rate, so now YOU as a Registered Member no longer have the delete facility, and WE (the Mods) tend to simply hide posts &/or threads only when necessary; and actually delete either only in exceptional circumstances!
    Besides, unless you delete something immediately after posting, and often even then, there is every likelihood that it's already been crawled & copied by the big search engines so there's a record of it available if the operator knows how to search for it properly; which means that if you don't want whatever you want to go down in history and remain as part of the public record on the internet FOREVER, then you'd better not post it in the first place or at all, cos once you do post it, it's out there forever!
    Just Sayin'!!
    Jan 2024
    Texas
    Just Sayin'!!
    Well now it doesn’t much matter. I was just trying to have someone clean up my irrelevant post, not the whole thread. But between these last two replies, I think it makes sense to leave it all as is now. There’s good stuff in your replies!
    Last edited by Peter Aawen; 03-25-2024 at 11:53 PM. Reason: Fixed quote display ;-)
    Highway pegs
    KOTT Grill covers
    Pedal Box+ w/BT
    Foam Grips
    Red Rim Covers
