Results 1 to 4 of 4
    Jan 2024
    Texas
    Question Can you identify this extra Spring - license plate maybe?
    So, I found a spring laying behind my bike today in the garage. Pic attached, key for scale. I *assume* that maybe it's some sort of tensioner the dealer put under the wing nut on the license plate bolts, as I finally received my license plate and swapped it out the other day. I didn't notice anything fall while doing that, but that's the only thing that makes any sense to me. If that's it, the other one is probably sprung somewhere in the garage, and I'll have to look for it. But, I wanted to see if any of you recognized it to put my mind at ease.
    2019 Spyder RT Ltd. Bought in Jan 2024. Can-Am states only.
    Slingmods USB and QuadLock phone mount with vibration dampener
    Highway pegs
    Rear GENERAL ALTIMAX RT45 SL 225/60R-15 tire
    Drink2Go front/rear Cupholders
    3D printed Turn Signal/Shifter caps
    KOTT Grill covers
    LED Headlights + LED Foglights
    High Mount Trunk brake/turn lights with brake strobe
    Pedal Box+ w/BT
    Show Chrome gas shock for rear trunk
    Foam Grips
    Red Rim Covers
    VIOFO MT1 Front/Rear Dash Cam system
    Upper Radiator Exhaust Block (SpyderPops)
    ShowChrome Heavy Duty seat shock
    Feb 2017
    I agree. It looks just like the spring tensioners on the reflective button license plate screws on our Spyders. As you said, it mounts on the rear side before screwing on the wing nut.
    2015 Spyder RT-S (Arion) and 2021 RTL Sea to Sky (charming wife)
    Apr 2020
    Lebanon ohio
    What you thought it was for the plate
    Jan 2024
    Texas
    Thanks guys. I found the other one and put them back where they belong.
    Highway pegs
    KOTT Grill covers
    Pedal Box+ w/BT
    Foam Grips
    Red Rim Covers
